 Old 04-27-2012, 05:10 PM   #1
maddocx240's Avatar
Posts: 823   (View Stats)
Default Hpfp internal/Cobb ap question
So I installed my pump internals today, and have a question. With the ap should I change the tune to the stage 1+ tune which is stock everything with upgraded fuel pump? I did a few wot runs and when the engine hits redline I get a bit of fuel cut, is this normal? I never really went wot to redline on stock internals so not to sure. I would figure with upgraded fuel pump it shouldn't have fuel cut right? unless I have to chage to the stage 1+ tune so the ecu recognizes the upgraded pump.. And looking on my ap the stage 1+ says all stock with tbe.. But on cobbs website stage 1+ is all stock with upgraded hpfp. Do I have to download the map on cobbs website to get it? Sorry door the long post just wanna do things right.. Ima about to buy my cs fmic next week so I want all this squared away..
 Old 04-27-2012, 05:42 PM   #2
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
Are you bone stock except AP and HPFP? No SRI or TIH?
 Old 04-27-2012, 05:42 PM   #3
maddocx240's Avatar
Yeah bone stock, just ap and hpfp
 Old 04-27-2012, 05:48 PM   #4
Blackrider's Avatar
Posts: 356   (View Stats)
Blackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the world
Groaned at 20 Times in 14 Posts
Stage 1 is for people with at least and intake.
2008 MazdaSpeed 3
Exhaust - Mazdaspeed & Ebay Downpipe
Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC
Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS
Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's
Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM
Random - Pontiac G8 Horns
2013 Ford Edge Sport AWD, the family car...
Blackrider is offline   Reply With Quote
 Old 04-27-2012, 05:52 PM   #5
Groans: 34
Thats what I had thought, but Cobb says otherwise... I really dont know because I had intake on already and went with that map.
AccessPORT Off The Shelf Maps
 Old 04-27-2012, 06:02 PM   #6
maddocx240's Avatar
Well I guess I meant to say stock stage 2. But yeah if you look at for both ms3 and ms6 they a have a ots for upgraded hpfp and everything else stock.. But on my ap they don't have it there, stage 2 is stock everything with tbe.. So I'm wondering if i have to download that map.. But as far as the fuel cut goes being the I wasn't paying to the rpms and looking at the ap, I think I was hitting the rev limiter , I did take it to like 6700rpms,lol.. Even tho it's pointless to rev that high on the mzr.. But my fuel pressure stayed above 1600psi throughout so I'm guessing it's ok. But im waiting for my cousin to come by with his laptop so I can do some datalogging, my comp is dead..
 Old 04-27-2012, 06:06 PM   #7
bigriver's Avatar
Posts: 1,123   (View Stats)
There are stage 1 and stage 2 maps for stock intake. Just go to cobbs site and look for stock intake and download the map.
To run stage 2 you need at least one of the stock cats deleted. So either dp or test pipe, or gutted oem cat.
bigriver is offline   Reply With Quote
The Following User Says Thank You to bigriver For This Useful Post:
09speedaddict (04-27-2012)
 Old 04-27-2012, 06:12 PM   #8
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
what makes you think you have fuel cut? Are you losing fuel pressure?
-Wetz
QFT
 Old 04-27-2012, 06:13 PM   #9
09speedaddict's Avatar
Posts: 223   (View Stats)
09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute
You are also going to need to up your commanded fuel psi in atr as well.
09speedaddict is offline   Reply With Quote
 Old 04-27-2012, 06:21 PM   #10
maddocx240's Avatar
During the wot run I made I hit like 6700 rpms and felt the car stutter a bit, but I was trying to look at the fuel pressure on the ap and didn't even figure it might have hit the rev limit.. I figure the what it was fuel pressure never dropped below 1600..
Oh, well Cobb should state that, lol.. Well ima do some logging when I get a chance to make sure all is good cause within the next month I'm installing do and cs fmic!
Last edited by maddocx240; 04-27-2012 at 06:21 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-27-2012, 06:24 PM   #11
bigriver's Avatar
Lol. They do say it, you are to lazy to search.
 Old 04-27-2012, 08:33 PM   #12
Blackrider's Avatar
Yeah, I honestly don't know why I said that. I can remember seeing them many times.
2008 MazdaSpeed 3
 Old 04-28-2012, 03:22 PM   #13
xfeejayx's Avatar
Groans: 78
soooooo.....there is no fuel cut.....
-Wetz
QFT
 Old 04-28-2012, 03:44 PM   #14
DickFitzwell's Avatar
Posts: 996   (View Stats)
DickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the worldDickFitzwell is the leader of the world
leg work has been done for you:
NOTE: i have no clue what year you have.......
2007-2008 MAZDASPEED3 - Stock Intake (you need stg2)
2009 MAZDASPEED3 - Stock Intake
2010 MAZDASPEED3 - Stock Intake
2011-2012 MAZDASPEED3 - Stock Intake
09 CWP MS3: COBB AP / MSD DH / AT HPFP / CPE SRI / CS TIP / CS BT-RH / M2 DP / CNT CBE / HKS BPV / EVO X / E85 PERMFREEKTUNE 330/380
07 TGM MS6: COBB AP / JBR PP SRI/TIP/ JBR BT-RH / CS CBE / FORGE V1 / JBR RMM / H&R CO Stratified OTS
07 BM MS6: DREADNAUGHT / JUGGERNAUT / SU DMM*PMM*TMM / JBR RMM / BC CO / MAGNAFLOW CBE / JBR OCC / SURE BSD / PRODRIVE GC06-H
Long Signature made especially for Micha
DickFitzwell is offline   Reply With Quote
The Following User Says Thank You to DickFitzwell For This Useful Post:
Micha (04-28-2012)
 Old 04-28-2012, 08:27 PM   #15
maddocx240's Avatar
Thanks for finding me ms3 links for my ms6!
Nah no fuel cut, just my noobness, lol.. did some runs last night all was good, fuel pressure held up, logged some data on the ap, just gotta put on my cousins CPU..
Last edited by maddocx240; 04-28-2012 at 08:27 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says NO Thank You to maddocx240 For This Un-useful Post:
Whiteboy (04-29-2012)
 Old 04-28-2012, 09:01 PM   #16
you never mentioned shit, so you got what you got!
Here you go you ungrateful punk
xfeejayx (04-29-2012)
 Old 04-29-2012, 08:36 AM   #17
maddocx240's Avatar
Watch those harsh words, I'm a very sensitive guy, lol.. but I spoke with Cobb tuning and they said any stage 2 tune involves a having a dp or deleted cat. So thanks for looking up the ms6 info for me..
 Old 04-29-2012, 08:40 AM   #18
then they should update their info on the AP maps page to reflect what you are saying... but as long you get it running right, thats all that matters i suppose. at the very least you now have the location for the maps when you get to that venture
 Old 04-29-2012, 09:09 AM   #19
bieberhole69's Avatar
Posts: 548   (View Stats)
bieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the worldbieberhole69 is the leader of the world
Groaned at 74 Times in 21 Posts
Wait! They have more maps to download on their site!?
Sent from me using Tapshoes
bieberhole69 is offline   Reply With Quote
 Old 04-29-2012, 10:14 AM   #20
Just the various stg1 stg2 safe mode and valet...
OP is all stock minus hpfp; so according to combs maps he would use stg2 91/93 whichever octane he runs, however; Op contact Cobb and they said stg2 is for DP... So the map reads wrong according to the site
Sent from my iFail
 Old 04-29-2012, 10:35 AM   #21
bigriver's Avatar
Sent from my iFail
The cobb discussion forum talks about whats required for stage 2. Just need one oem cat removed so either dp or test pipe or gutted oem cat is okay.
 Old 04-29-2012, 10:39 AM   #22
^^^ yea I was just reading that ^^^
Sent from my iFail
 Old 04-29-2012, 12:18 PM   #23
maddocx240's Avatar
Exactly, they need to update the list.. Cause looking at the chart it says nothing about dp or deleted cat on any stage 2 tune.. But if you download the map and look at the tune on the ap itself stage 2+ has tbe on it. So it's pretty confusing.. But Cobb said they did need to include the dp on the tune chart to make things simpler..
 Old 04-29-2012, 07:18 PM   #24
Ah gotcha, make sense to have it listed
Sent from my iFail
 Old 04-29-2012, 09:30 PM   #25
bigriver's Avatar
No they just want people to buy their dp.
HPFP Question speed31982 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 10-10-2013 03:33 PM
Fuel pump internal/HPFP,really necessary? RMCAT MazdaSpeed 6 - Engine, Transmission & Driveline 13 08-09-2013 09:22 AM
Should you upgrade the cam follower when putting in internal for the HPFP? daztdMS6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 07-27-2011 07:12 PM
Rust on HPFP internal parts??? Keemo577 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 07-21-2011 02:02 PM
Page generated in 0.42949 seconds with 27 queries
