 Old 06-05-2011, 07:16 PM   #1
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Default I've got an oil question.
I want to switch to the rotella t6 5w40, but I cannot find it in one litre jugs. Could I mix the .25 litres remaining after the 5L jug goes in, with another high quality synthetic of the same weight? Or should I just invest in two jugs for the change over and then use the second jug for topping off and every subsequent oil change?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-05-2011, 07:18 PM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
man are u seriously asking this dumb of a question????
are u gonna only do one oil change ever again????
then think motherfucker....god gave u a brain...use it
 Old 06-05-2011, 07:20 PM   #3
Tokay444's Avatar
Groans: 793
Demodded.
The Seals
 Old 06-05-2011, 07:22 PM   #4
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
use the same oil.....and guess what...when u do the next...u use it again...and again and again.....and again....
lifeownedme (06-05-2011)
 Old 06-05-2011, 07:26 PM   #5
Tokay444's Avatar
Groans: 793
Fine! That's almost $90 bucks for that initial change over just in oil, and I'm a cheap fuck. Not Jew cheap or Dutch cheap, but cheap. But whateves. It'll get used eventually.
Anyone one use the fram filter cartridge? I've just been getting the Mazda replacements so far.
Demodded.
The Seals
 Old 06-05-2011, 07:55 PM   #6
Giggles's Avatar
Posts: 1,019   (View Stats)
Giggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the worldGiggles is the leader of the world
Don't use fram. Spend the 3$ more on Mazda
Giggles is offline   Reply With Quote
 Old 06-05-2011, 07:57 PM   #7
Tokay444's Avatar
Groans: 793
Thanks toots. <3
Demodded.
The Seals
 Old 06-05-2011, 09:38 PM   #8
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
A guy from Mazda told me that when you use an aftermarket filter, they are usually longer in length. He said when you tighten the caps on, it actually twist the filter and can cause flow restriction. Caused a motor to sieze and needed to be rebuilt... Not sure how much of that is true... I think they are just trying to make a sale. I ran fram filters in my mazda 6i for 100k miles with no issues.
Sorry for thread jack OP.
The Following User Says Thank You to speed_freak91 For This Useful Post:
Tokay444 (06-06-2011)
The Following User Says NO Thank You to speed_freak91 For This Un-useful Post:
Tommy (06-05-2011)
 Old 06-05-2011, 09:41 PM   #9
Tommy's Avatar
Posts: 2,309   (View Stats)
Tommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the world
Groans: 155
Groaned at 44 Times in 37 Posts
That's some bulshit. Just make sure the new one is the right size. I've been using either Mobil1 or Purolator PureOne. 81k miles sez I'm doing something right.
Tommy is offline   Reply With Quote
 Old 06-06-2011, 03:45 AM   #10
Tokay444's Avatar
Groans: 793
The last OE filter I switched out was twisted. Lol.
Demodded.
The Seals
 Old 06-06-2011, 06:27 AM   #11
Walkman's Avatar
Posts: 247   (View Stats)
Walkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the worldWalkman is the leader of the world
All the filters are about the same. Have no problem with aftermarket filters jsut be smart with how much you tighten it. also Use the Damn oil Quick being cheap.
Walkman is offline   Reply With Quote
 Old 06-06-2011, 07:10 AM   #12
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i used a fram filter and it was just fine, cartridge filters are all basically the same.
if you buy your rotella at walmart they usually have 1qt bottles of it next to the 4qt ones, but i just buy (2) 4qt bottles and then the next time I only need to buy 1 bottle and so the trend continues.
The Following User Says Thank You to bova For This Useful Post:
jracer (06-06-2011)
 Old 06-06-2011, 07:22 AM   #13
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
I've used Fram filters and yesterday did my 14th oil change. Never came out twisted, unlike the owner.
OP, buy the oil and stop thinking like a Canuck....oh wait, nevermind.
What a lovable bunch we are!!
 Old 06-06-2011, 07:24 AM   #14
Tokay444's Avatar
Groans: 793
I looked at Canadian tire, partsource, and walmart. All of which only have the 5L bottles. No problem. I'll get two the first time. Then I'll always use the older bottle at home to do the fill, and the new bottle for top up.
Demodded.
The Seals
predapio (06-06-2011)
 Old 06-06-2011, 07:43 AM   #15
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
we have the gallon jugs at walmart, but they only sell fram and motorcraft filters. i end up going to advance for a big spin-on purolator pureone.
 Old 06-06-2011, 07:46 AM   #16
Tokay444's Avatar
Groans: 793
Spin on conversion is on the list of things to do.
Demodded.
The Seals
 Old 06-06-2011, 07:51 AM   #17
patrick failman
Groans: 74
perform the trifecta (spin-on, occ & bsd) and live to tell the tale.
 Old 06-06-2011, 08:19 AM   #18
FUB4R3D's Avatar
Posts: 145   (View Stats)
FUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the world
I don't think you'll find the quart bottles anywhere in Ontario... I've checked out any place that I can think of that sells oil and you're stuck getting a pair of the bigger ones. Just hit up a Wallyworld in Barfalo next time you're in the area and pick up a few single quarts. Hell, get all the oil in the US, its considerably cheaper.
FUB4R3D is offline   Reply With Quote
The Following User Says Thank You to FUB4R3D For This Useful Post:
gap question goodfella16 Gen2 MS3 General Discussion 6 04-18-2011 05:23 PM
question zoomzoom MazdaSpeed 3/6 - Suspension & Brakes 6 01-19-2011 04:44 PM
v1.05 question wolverine81 MazdaSpeed 3/6 - ECU Computer Tuning 2 09-14-2009 08:36 PM
A/F question speed_3
Cobb Access Port/Maps
3 09-20-2008 09:17 AM
Page generated in 0.36713 seconds with 29 queries
