 Old 03-25-2018, 04:46 AM   #1
H1ghguy872's Avatar
Posts: 7   (View Stats)
H1ghguy872 is an unknown quantity at this point
Default If I change the headgasket
If I change the headgasket is there a way to keep the timing in check without retiming the engine? or once i take the head off i'll need to retime? I'm wondering if there's a way to just mark everything and line it all back up when i put the head back on
H1ghguy872 is offline   Reply With Quote
 Old 03-25-2018, 06:02 AM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
You can mark it, but if you're a few degrees off, you'll get a CEL.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 03-25-2018, 07:06 AM   #3
Djohns's Avatar
Posts: 3,944   (View Stats)
More than likely you’ll end up needing to time it again.
2010 black mica speed3
Soon:built motor
 Old 03-25-2018, 07:34 AM   #4
H1ghguy872's Avatar
Thank you all <3
Injector Seals or Headgasket? Mazdaspeedler MazdaSpeed 3 - Engine, Transmission & Driveline 15 04-13-2015 09:07 AM
wrong headgasket??? burntmushu MazdaSpeed 6 - Engine, Transmission & Driveline 12 01-18-2012 07:00 PM
Has anyone done a Headgasket repair? gt5 MazdaSpeed 3 - Engine, Transmission & Driveline 7 01-02-2011 05:22 PM
Page generated in 0.23942 seconds with 22 queries
