| TWOptSL0W | 11-15-2012 05:11 PM | If your car does not start I've been seeing more and more of these threads come up as the weather gets colder, so I figured I would just tell you how to fix your problem.
When you turn the key and everything is working like normal and then "oh no! my car isn't even cranking", it is most likely the starter wire. This is a common issue where the starter positive wire loses connection with the starter. The fix for this is very simple reach under the intake manifold and wiggle the only wire that is on the starter
this will most likely make a connection and fix your problem. next time you are under your car, take off the plug and put some of that dielectric grease on it so it has a better connection.
if this fixed your problem, thank me and give raider a blow job.
@ Raider; sticky this please and delete the other one you have there because this title is better |
