Like Tree3Likes
  • 2 Post By TWOptSL0W
  • 1 Post By Manny
 Old 11-15-2012, 05:11 PM   #1
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Default If your car does not start
I've been seeing more and more of these threads come up as the weather gets colder, so I figured I would just tell you how to fix your problem.
When you turn the key and everything is working like normal and then "oh no! my car isn't even cranking", it is most likely the starter wire. This is a common issue where the starter positive wire loses connection with the starter. The fix for this is very simple
reach under the intake manifold and wiggle the only wire that is on the starter
this will most likely make a connection and fix your problem. next time you are under your car, take off the plug and put some of that dielectric grease on it so it has a better connection.
if this fixed your problem, thank me and give raider a blow job.
@Raider; sticky this please and delete the other one you have there because this title is better
The Following 4 Users Say Thank You to TWOptSL0W For This Useful Post:
802MS3 (03-26-2013), blackms3_71 (10-18-2013), Cdnspeed6 (07-05-2016), KusteLokal (11-15-2012)
 Old 11-15-2012, 05:13 PM   #2
Manny's Avatar
Posts: 1,185   (View Stats)
Groans: 320
do you accept reach arounds as payment?
SpeedThrills likes this.
The Following 2 Users Say Thank You to Manny For This Useful Post:
Notorious AMA (01-08-2014), TWOptSL0W (11-15-2012)
 Old 11-15-2012, 05:15 PM   #3
TWOptSL0W's Avatar
Groans: 125
of course
 Old 11-15-2012, 05:15 PM   #4
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
This thread == ¿que?
@Raider;
2008 MS3 gt
470hp/463tq on GT35r at 29psi
burn813 is offline   Reply With Quote
The Following User Says Thank You to burn813 For This Useful Post:
Alejo_NIN (11-15-2012)
 Old 11-15-2012, 05:49 PM   #5
Alejo_NIN's Avatar
Posts: 1,700   (View Stats)
Alejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the world
Groans: 88
Groaned at 186 Times in 83 Posts
@Raider; get to it buddy....ASAP, OP Commands!
radonelement.com
Alejo_NIN is offline   Reply With Quote
The Following User Says Thank You to Alejo_NIN For This Useful Post:
 Old 11-15-2012, 06:32 PM   #6
Done.
edowney4711 (03-16-2013), TWOptSL0W (11-15-2012)
 Old 03-26-2013, 07:34 AM   #7
maniospeed6's Avatar
Posts: 7   (View Stats)
maniospeed6 has a little shameless behaviour in the past
Default Ms6 wont start
I bought a 06 ms6 for 3500 so ill worth to fix it , car cranks but no spark , guy i bought from say he broke the transfer ect , i dont think it has to do anithing with the starting prob ,, need help asap please
maniospeed6 is offline   Reply With Quote
 Old 03-26-2013, 07:48 AM   #8
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
1. Make a new thread somewhere else, in the appropriate section.
2. Try damn hard to use proper english.
3. Provide as many details as possible.
4. Donate to get VIP access. There is a factory service manual in the VIP section here - http://www.mazdaspeedforum.org/forum/foru...ual-pdf-49723/
'08 CWP MS3 w/ T3 3071r
 Old 03-26-2013, 08:07 AM   #9
Sorry I am new here ,thanks for the help anyway got blessed u
 Old 10-06-2013, 10:09 AM   #10
ohioan's Avatar
Posts: 14   (View Stats)
ohioan is on a distinguished road
I owe two blow jobs.
Thanks.
ohioan is offline   Reply With Quote
 Old 01-23-2014, 06:55 AM   #11
Rcimp's Avatar
Posts: 129   (View Stats)
Rcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond reputeRcimp has a reputation beyond repute
Good tip
07 Cosmic Blue Speed 3,
BNR S2 Turbo
Cobb AP
BEGI SRI
CNT Catted Downpipe
Forge BOV
CorkSport Turbo Inlet Pipe / Silicone BPH / Boost Tubes / Dry Flow Air Filter
Fidanza Aluminum Flywheel
CPE Xflex Stage 2 Driver Side MM
CPE Xflex Stafge 2 Rear MM
AWR Passenger Mount 88 Duro
Power Slot Rotors
Rcimp is offline   Reply With Quote
 Old 10-05-2015, 04:43 AM   #12
aviator79's Avatar
Posts: 3,934   (View Stats)
Pics:
Engine Won't Crank
CX-7 Won't Start When Hot trf5000 CX-7 > Issues & Troubleshooting 3 07-24-2013 03:58 PM
Help Car Won't Start j.ferger MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 07-30-2012 06:37 AM
Please Help - Car Won't Start! Rampage MazdaSpeed 6 - Engine, Transmission & Driveline 5 06-24-2012 07:56 PM
Car won't start... ahfunaki Gen2 MS3 General Discussion 17 03-29-2012 10:48 AM
Car will not start Mikey MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 09-08-2011 04:54 AM
Page generated in 0.32534 seconds with 29 queries
