  • 1 Post By G26
  • 1 Post By EdgeAutosport.com
 Old 07-26-2012, 02:41 PM   #1
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Default injector seals help
Is it possible to run just the PTP seals without the studs/washers? Also, what is the point of using the new stud kit? CP-E only sells the seals by themselves, so I am a bit confused....
mczimer is offline   Reply With Quote
 Old 07-26-2012, 02:44 PM   #2
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
sigh here noob go buy and stfu
SURE Injector Halos & Studs for DISI MZR 2.3L
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
The Following 2 Users Say Thank You to Captain KR For This Useful Post:
amggilly305 (07-26-2012), jracer (07-27-2012)
 Old 07-26-2012, 02:51 PM   #3
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
The purpose of the stud kit is because the stock torx shit strips easily, and doesnt provide even pressure on the crows feet holding the injectors in.
Alejo_NIN likes this.
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline   Reply With Quote
The Following 2 Users Say Thank You to G26 For This Useful Post:
Don06speed6 (07-26-2012), mczimer (07-26-2012)
 Old 07-26-2012, 03:00 PM   #4
mczimer's Avatar
When you say the torx strips, do you mean the thread?
What is the result of uneven pressure? I have never heard of this before?
I pre-ordered a set of SURE seals, and they got stolen off my porch yesterday, so I am installing the PTP seals instead, so spare me the "noob" comments, I just want help
 Old 07-26-2012, 03:02 PM   #5
Captain KR's Avatar
Groans: 391
did you not see my smiley face
i reuse my stock bolts with no issue but obviously t40 torx is harder to use than an socket on a hex nut hence the reason people do the switch!
Killah Built
The Following User Says Thank You to Captain KR For This Useful Post:
 Old 07-26-2012, 03:03 PM   #6
The reason people replace the studs and nuts is because the bit used to remove the bolt holding in the crows feet can easily be shredded if (its a crappy bit) I have never had any problems with this bit so I just reuse the stock hardware and omit using a different stud nut combo.
The way I see it, if you are never going to be touching the seals again whats the point of replacing the hardware if it didnt give you problems the first go round?
To each his own I guess
Captain KR likes this.
 Old 07-26-2012, 03:05 PM   #7
Captain KR's Avatar
Groans: 391
freaking mexicans always trying to do what i do
Killah Built
EdgeAutosport.com (07-26-2012)
 Old 07-26-2012, 03:09 PM   #8
Will, I know you want to come visit and be full of win. Bring your fail boat so we can actually fix it
you sir have just cursed yourself haha
you might as well replace it all while your in there and tq that shit down harder to it provides more clamping force. you wont be able to tq the stock bolts any more then stock values before they snap.
Meh ive done 4 sets without issue. Just make sure the bit isnt a crappy brand and you will be fine
Last edited by EdgeAutosport.com; 07-26-2012 at 03:09 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-26-2012, 03:09 PM   #9
Captain KR's Avatar
Groans: 391
you are right my fail is killing my e peen
but
pablo > eric
Killah Built
 Old 07-26-2012, 03:10 PM   #10
but
pablo > eric
Pablo> me anyday obviously but yet again you only make me money when you are winning races so get on it
 Old 07-26-2012, 03:06 PM   #11
 Old 07-26-2012, 03:18 PM   #12
mczimer's Avatar
thanks for your comments, I appreciate it; @Captain KR I missed your smiley! I will be using PB blaster on the torx fuckers prior to touching them, to alleviate any potential issues. My major concern was just that it would be possible to do this, and I would not regret it down the road.
From the workshop manual it looks like: (have not seen this mentioned in any how-to, but feel it is important)
Torx are torqued to 15.9-18.8 ft/lbs
Rail bolts 13-16 ft/lbs
TB is apparently torqued all the way to 71-101
IM 13-16 ft/lbs
PS pump 14-18ft/lbs
Any tips appreciated. Also, I have two ideas for cleaning the valves which I will be documenting and taking plenty of pictures of. One method involves media lasting, and the other uses a variation on the manual scrubbing-will make a thread upon completion of course!
 Old 07-26-2012, 03:25 PM   #13
Just use a breaker bar when taking those bolts off and it wont be an issue. IIRC they are only torqued to 13-16ft lbs
IMASA (07-26-2012)
 Old 07-27-2012, 09:11 AM   #14
mczimer's Avatar
Why does @jbarone say to loosen the fuel rail cover? None of the how to's mention this...
"Install ONLY bolts 1-5 and #8
a. Snug ONLY bolts 1-5 and #8
23. Torque ONLY bolts 1-5 and #8 to 16FT-lbs
24. Loosen rear fuel rail cover bolts 2x 10mm
a. This is an important step don’t skip it
25. Install and torque bolts 6 & 7 to 16FT-lbs"
from here: http://jamesbaroneracing.com/support...structions.pdf
 Old 07-27-2012, 09:22 AM   #15
its to take the stress off the IM when bolting everything down.
JBR (07-27-2012), mczimer (07-27-2012)
 Old 07-27-2012, 10:21 AM   #16
mczimer's Avatar
CPE's instructions say to loosen the pressure on the fuel pressure sensor, then removing the line off the relief valve. Is this "needed", or is simply to avoid spilling some fuel? If I recall correctly, I think that vacuum line was removed during my HPFP swap.
Lastly, does anyone recommend cleaning the injectors in any way prior to re-installing them? (soaking them in seafoam over night?)
Thanks for all the help thus far, I will be sure to take a lot of pictures to possibly help enhance Douge/Anthony's CPE how to!
CP-e Injector Seals ak_spray Revolution Performance Motorsports 11 01-25-2012 10:20 PM
Injector seals essejkcamraw MazdaSpeed 3/6 - Turbo Induction 703 05-17-2011 09:12 PM
Injector Seals! ptperformance Mazdaspeed3/6 General Discussion 71 06-02-2010 10:13 PM
Page generated in 0.37284 seconds with 24 queries
