![]() Join Date: Nov 2018
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Can you plug and play a sub into a 2010 speed3 with the wires that are already there for the stock sub? Sent from my iPhone using Tapatalk |
![]() | Not Ranked : 0 score updates on this? |
![]() Join Date: Oct 2018
Rep Power: 0 ![]() Thanks: 30
| Not Ranked : 0 score Someone was selli g a wire harness on FB mazdaspeed forum for this recently
__________________ 06 MS6 GT SP63 Stage 1, bnr s3, hpfp, cai, cs tmic, southbend stage 2, E30 tune |
![]() Join Date: May 2016 Location: Sarastoa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score Any amp with a high pass input will allow you to splice into factory speaker wiring. Then set LPF to 70-100 depending on preference. Not the best solution, but relatively easy with factory wiring.
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score My .02 on this subject just for the hell of it. The oem sub is dvc. I think there dual 1 ohm. So the amp puts power out at .5 ohm load. Anything above that and the power output drops. Any 1 ohm dvc sub that you find will have such a high power rateing that the power out from the amp into this sub will be like throwing a cup of water into a well. At that point just get a self powered sub and use the amp output as a signal input.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following User Says Thank You to 5doorsoffury For This Useful Post: | 2010mps (01-14-2019) |
Do you know if door speaker are the same low impedance with bose system?
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
Groans: 74
The big suck with a high level in from the stock amps output is very filtered/ crappy bass . I believed i just tapped rca's on the bose amp inputs before i did my full system. I want to say the amp is 200w so @80% efficiency thats about 20amps. Edit: as far as the voltage stepup comment is concerned i am pretty sure there is a dc to dc converter vs coils if you were talking about the amps power stage. I dont see how looking at the sub being connected to a multi channel bose amp would make you come to that conclusion.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra Last edited by 5doorsoffury; 02-08-2019 at 03:45 AM. | |
![]() Join Date: Jan 2019
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Easiest way is the splice into the rear speaker wires just as others have suggested. Just make sure your amp has a low pass filter. You will have to run a power wire from the battery and a ground wire to the nearest ground by the amp. While one this topic does anyone have an elegant solution to positioning a remote sub level control somewhere around the dash? Sent from my Moto G (5) Plus using Tapatalk |
| Not Ranked : 0 score You definitely need an amp + a sub, i personally prefer to have an amp that is more powerfull than the sub or at least equal to keep better control of it. I did put a 10inch on the side using some of the jack holder space in my 2007 ms3. My FG amp did not had high level input so i just added a LOC adapter to make it work. It isn't as best as an RCA signal from an aftermarket unit but it isn't that bad for a sub.
| Not Ranked : 0 score I'm an electronic tech and used to be active in car audio before...i'm still curious about everything around this even if i stopped buying audio parts to save for performance parts.....(loading the trunk with a lot of heavy subs won't help 1/4 mile times...) So With a 12v nominal at the amplifier stage and 4ohm load, you can expect at best 22w from the best IC chip...Any aftermarket head unit claiming anything above this is peak power or bullshit because i didn't see any yet with a voltage booster. To increase power you either need to increase voltage or decrease impedance. My point was: If bose used very low impedance woofer in the range of 0.5ohms instead of the usual 4ohms/2ohms it could have been to use a simplified amplifier device. With an added power stage after the ic, you can get 100+w at 0.5 ohms with just 12v... You can also combine to feed a 2 ohms load under 12v and get something like a 40+w rms that would be about what we have with the bose system.... I also found that old thread about the 3 Factory Bose Specs and Diagram
| CEL after installing CS SRI+TIP | Nefarion | 2010 MS3 - Troubleshoot/Diagnostics | 38 | 11-01-2011 09:47 AM |
| need help installing ddm hid kit | Dfresh619 | Exterior | 8 | 04-03-2010 11:28 AM |
| need hlp after installing SU BPV | camdensms6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 11-02-2009 02:54 PM |
| help on installing MBC | tburton101 | MazdaSpeed 3 - How-To's | 1 | 08-27-2009 02:35 PM |
