![]() Join Date: Mar 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hey guys. I never actually post in forums but i’m stumped. There isn’t a single video i could find with a similer sounding problem. I have a 2007 speed3 with 191k. I bought it used with an upgraded motor mount, cobb cai, and forge bov. Not sure if any of these mods are relevent, basically only when the car is under load in boost, this strange intermittent knock sound comes from the Engine bay area. It can be one knock every second, or a hundred a second and anywhere in between as i travel up the rpms. There’s really no way to know when it’s going to knock and i have no idea where to start. My friend suggested the wastegate but i doubt it since i found no posts at all concerning the wastegate. Another thought it was uneven chain tension (i recently changed the vvt actuator chain and washers myself. It was making the noise before the job, then went away for about 2-3k km, and came back. Any help would be appreciated. I could get a video if need be. Just wondering if anyone ever had this problem before. Thanks! |
![]() Join Date: Jan 2016
| Not Ranked : 0 score if you are a stop and u rev ur engine and you dont hear that "knock" sound but you drive and hit the gas and boost up and hear it. i bet its your fuel injector seals. That was what my issue was long ago. i try to find the video and send you a link to see if its the same as yours. Are you getting KR? Last edited by Ripcord291; 03-28-2019 at 09:51 PM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score My accessport says the kr is 0. I will check on the injectors but a lot of people said the wastegate is an issue, as it happens quite often with the K04s. |
| Not Ranked : 0 score well if your not getting KR then probly not injector seals. good luck! |
| Not Ranked : 0 score Misread previous post. Please delete.
| Intermittent knock/rattle/chatter at idle (youtube) | jaugustavo | Gen2 MS3 General Discussion | 0 | 11-20-2017 06:59 PM |
| lifter noise/ 8.05 on knock | hmmmm | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 05-01-2015 09:10 AM |
| Knock Noise, No codes. | Dream20b | 2010 MS3 - Troubleshoot/Diagnostics | 17 | 04-11-2013 07:36 PM |
| 2007 MS3 Intermittent knocking noise while idling (Video) | metalmatt | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 09-29-2011 09:29 PM |
| Intermittent Boost Leak? | phantom6294 | MazdaSpeed 3/6 - Turbo Induction | 2 | 08-28-2008 06:04 PM |
