![]() Join Date: Nov 2014 Location: Sunrise, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score 2 weeks ago I had my mechanic install DP (I tried and failed to myself), and since then, if I start the car and drive a short distance, shut it off, and restart it within under 30 mins, the car smokes pretty heavy for about 5 mins then goes away. However, if I start the car, drive it until fully warmed up (15+ mins), turn it off, and LET IT SIT (for an hour or more), car doesn't smoke upon starting up again. So the car is only ever smoking after a quick trip and then restart. Confusing, tried searching/reading a bunch about smoky turbo stuff and this specific issue didn't seem to come up. She's got 57,000 with mods listed in signature. Any thoughts?
__________________ Current: 07 ms3, JBR: TIP SRI, ETS: TMIC, CORKSPORT: RMM & HPFP, Hypertech Tune, EBay DP + Test Pipe & into stock CB Planning/Dreaming: Cobb AP, Koni Yellows |
![]() Join Date: Oct 2014 Location: sugar land, texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score this is not an uncommon issue and i'm not sure the way in which you're producing is all that different from others. it's likely that your previous setup was just masking the issue, and now that you've opened it up a bit it's become unmasked. is your downpipe with or without a cat? what kind of oil do you use? you might also consider a new intake setup with the ventilation hose relocated closer to your turbo inlet. wonder twin powers activate! shape of, a wheel!
__________________ guzzlin' a guinness stout. |
__________________ Current: 07 ms3, JBR: TIP SRI, ETS: TMIC, CORKSPORT: RMM & HPFP, Hypertech Tune, EBay DP + Test Pipe & into stock CB Planning/Dreaming: Cobb AP, Koni Yellows | |
| Not Ranked : 0 score the fix created more vacuum. mazda issued a service bulletin for this. try running rotella t6 (5w-40) and then bump your idle back to normal to see if that alleviates it. bumping up your idle is another solution but not everyone wants their idle near a thousand. the intake is another solid fix and most aftermarket companies provide relocated ventilation via the turbo inlet pipe now.
(Thread Starter) | Not Ranked : 0 score I have a JBR intake and TIP. That would have relocated it already, correct?
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score For stock size intakes I believe only CS has the option of having the ventilation hose relocated to the turbo inlet. Larger +3" aluminum intakes and CP-E TIP have it relocated closer to the turbo.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| Not Ranked : 0 score if you are running this particular intake where it is located on the elbow just behind the maf housing: then it would not. an example of where it is relocated with the fix:
(Thread Starter) | Not Ranked : 0 score Yea. That top pic is mine... Damn. Wasn't aware of that issue when I purchased. Kinda pissed now.
| Intermittent issue | ty.thompson1981 | Mazdaspeed3/6 General Discussion | 15 | 06-05-2015 06:53 PM |
| Intermittent Horn | myslow1 | MazdaSpeed 3/6 - Car Audio & Electronics | 1 | 12-30-2013 12:08 AM |
| Intermittent Fuel Cut - Need Help | kore2000 | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 03-18-2013 05:16 PM |
| Intermittent Hum/grind | helmetface | Mazdaspeed3/6 General Discussion | 23 | 01-07-2013 06:05 AM |
