 Old 08-09-2017, 05:14 AM   #1
Mazduhspeed6's Avatar
Posts: 157   (View Stats)
Mazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to all
Default Just wondering what the best fitting 3inch intake is on the speed6
Just a quick question to all you speed 6 owners.
What's the best fitting 3 inch intake without moving anything? I've read some threads where people said they fit in such intakes without touching their ecu or battery and Im just curious. I have been looking at the Corksport 3inch intake, any thoughts? Is it possible to fit it without any relocation of the earlier said parts or No?
Also I know there's an intake thread, I read some of it and it seemed more like a review thread, so I wasn't sure if this belonged there or not, so yea.
2007 Mazda Speed6 GT
Power: rebuilt stock motor*
JBR full power path stage II intake w/JBR TIP*
ATP catted downpipe w/ second cat delete*
Corksport HPFP internals*
Corksport BeCuse injector seals*
Corksport Turbo*
Corksport 3.5 Bar MAP sensor*
Corksport EBCS*
Treadstone Tr8 w/ RPM CX racing piping kit*
Suspension: Corksport Lowering Springs
Brakes: Still stock
Driveline: Sure Motorsports R6*
Sure Motorsports Juggernaut*
Sure Motorsports Dreadnaught*
Sure Motorsports shifter bushings*
Corksport weighted Black shift knob
Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning*
Mazduhspeed6 is offline   Reply With Quote
 Old 08-09-2017, 09:32 AM   #2
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
07-13 Mazdaspeed ATP 3" Intake and Turbo Inlet: JSC Speed | Performance from start to finish
old school... might probably not the best but will accomplish what you require
track weight 3220
street weight 3370
 Old 08-09-2017, 11:07 AM   #3
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
DAMN! $600 just for intake?? You speed6 owners have it hard..
2012 NASA Spaceship Gray MS3
 Old 08-09-2017, 05:45 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I'm not sure what you mean by best fitting. It either fits or it doesn't. ECU interference is MS3 noise.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 08-10-2017, 05:12 AM   #5
Ok I dont mean fit, as in is it going to bolt in, I know if it's made for the speed6 99% probability is its going to fit. My question though is whats the best fitting 3inch intake without doing any relocating of anything. And from what I read your saying is as far as relocating anything thats horseshit or nicely put unnecessary. And yes I would never pay 600 for a 3inch TIP and intake thats retarded.
Anyways I'm looking at the 3inch Corksport intake, Will from PD tuning, who's my tuner said it's a nice one because it has a true 3inch inner diameter as he said some that claim it, necessarily true 3 inchers on the inside. So thanks fasterthenyou, I appreciate the info, although i think you know what I meant by them fitting as you followed it by ecu relocation is ms3 noise. But i appreciate it all the same because it tells me I dont have to worry about relocation. I love my speed forum guys. It took me a lol bit to get used to all the razzing at first but you couldn't wanna be part of a better group.
Corksport Turbo*
Corksport EBCS*
Brakes: Still stock
The Following User Says Thank You to Mazduhspeed6 For This Useful Post:
KiwiFlavor (08-10-2017)
 Old 08-10-2017, 05:43 AM   #6
Fstrnyou's Avatar
The JBR intakes are measured at ID of MAF housing too. Hence the Tru 3" or Tru 3.5" name.
Nearly all 3" intakes should fit without having to change to a 51r battery. The silicone intakes are thick walled, so they take up quite a bit more real estate than their metal cousins. My Tru 3.5 silicone is massive -> 51r required. 3" metal intake should be no problem.
Other rides:
History:
 Old 08-10-2017, 05:46 AM   #7
KiwiFlavor's Avatar
I can attest to this. I relocated my ECU to the top of my fuse box.
Not sure if it applies to you MS6 guys but there's a thread here somewhere showing you can keep the ECU where it is with a little modification to the battery box.
 Old 08-10-2017, 05:47 AM   #8
Fstrnyou's Avatar
MS6 ECU is where it should be...inside the cabin.
Other rides:
History:
 Old 08-10-2017, 05:48 AM   #9
KiwiFlavor's Avatar
Ahhh damn. I learn something new everyday!
 Old 08-10-2017, 08:05 AM   #10
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
JBR Tru-3.0" silicone version. I didn't have to relocate anything on my MS3, I'm pretty sure it's going to be the same with a MS6 as the JBR recommendations are exactly the same for both car models.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
3inch TIP+intake TRQ STEER FTL Mazdaspeed3/6 General Discussion 17 01-24-2015 05:38 PM
ATP 3inch intake mr.speedy3 MazdaSpeed 3/6 - Turbo Induction 0 10-14-2013 10:21 PM
Page generated in 0.31187 seconds with 24 queries
