 Old 04-03-2014, 12:17 AM   #1
Zmcg1995's Avatar
Posts: 258   (View Stats)
Zmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond repute
Default Low oil pressure
So i took my car to the dealer to get my vvt done due to chain sound on start up and p0016 code. Upon picking my car up, they told me that the p0016 code was gone but that a new code, p0012 was now an issue. They said that its due to low oil pressure that affects the actuator. Ive driven it a little and is seems to run fine. Ive never once seen my oil light come on or even flicker. Has anyone had this problem or know of some causes of low oil pressure? Just trying to find out some things that i can try. I run full synthetic 5w-30 and just changed it within the past month. I pulled my oil filter and looked at it and it looked fine. Nothing obvious blocking it. Ive searched and only thing i found was a thread about low oil pressure after a built engine. One thing i saw was to pull the oil pan and look at it and the screen. Also some said to run thicker oil, 5w-40, but that it might only mask the problem. Any help or knowledge would be greatly appreciated. Just want to get this car running like it is supposed to and not have to worry anymore. I have a full corksport stage 2 intake.. thats it. Thanks
Zmcg1995 is offline   Reply With Quote
 Old 04-03-2014, 10:11 AM   #2
Zmcg1995's Avatar
Bump
 Old 04-03-2014, 05:22 PM   #3
Zmcg1995's Avatar
Bump.. Need some help
 Old 04-03-2014, 07:37 PM   #4
Sensei's Avatar
Posts: 318   (View Stats)
Sensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the world
Did you read this one?
P0012 CEL Code
2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs
Sensei is offline   Reply With Quote
 Old 04-03-2014, 07:43 PM   #5
Zmcg1995's Avatar
P0012 CEL Code
Yeah actually ive read that multiple times and tryed alot of things from that thread.. Tryed wiping sensors off and other things. Thanks for the link though
 Old 04-03-2014, 07:54 PM   #6
Sensei's Avatar
Did you try retiming the motor or check the timing? Just from that thread it looks like some people had they're timing wrong and retimed their motor to fix the issue. The dealership could've messed up your timing since it was fine before the VVT job.
 Old 04-03-2014, 07:56 PM   #7
Zmcg1995's Avatar
I havent checked the timing no. How would i go about checking the timing?
 Old 04-03-2014, 08:19 PM   #8
Sensei's Avatar
I havn't done this yet myself so take my advise with a grain of salt but what I've learn is from the VVT how to thread HOW-TO VVT and other research while preparing to do the VVT and timing chain job myself.
Four things need to be inline for the motor to be timed correctly.
1. The crank pulley and crank position sensor need to be aligned.
2. The crank needs to be rotated against the Top Dead Center Pin aka timing pin this puts Cylinder 1 at top dead center.
3. The exhaust cam needs to be aligned while cyl 1 is @ TDC.
4. The intake cam needs to be aligned while cyl 1 is @ TDC.
3 and 4 are confirmed by putting a special tool on the end of the cams once the crank is against the TDCP. the cam lobes closest to the passenger side should face each other on a 45* angle like so /\.
To just check the timing at a minimum I think you would need the TDCP. You'd insert it in the blind plug and rotate the crank against it and with the valve cover off you could confirm that the cams are in the correct position. Then you can count the teeth on the crank pulley and make sure the 20th tooth is aligned with the CKPS.
Again this is just my understanding of what to do based on reading threads so hopefully someone more experienced can confirm what I said or tell you that I'm completely wrong and point you in the right direction.
Hope this helps.
The Following User Says Thank You to Sensei For This Useful Post:
ItsNox (04-05-2014)
 Old 04-03-2014, 08:21 PM   #9
Zmcg1995's Avatar
Hope this helps.
Thanks alot man. Im gonna read up on it some more and maybe try to check the timing but what they said is that its all oil pressure based and if i have low oil pressure that would cause that cel to go off. ill deff try to check that though thanks for the good info
 Old 04-03-2014, 08:26 PM   #10
Sensei's Avatar
No problem. Definitely do some research and confirm what I said. Like I said I haven't done this myself yet so hopefully all the info I gave you is good.
Also since your VIP go download a copy of the FSM it should have the Mazda procedure for timing the engine in there somewhere. It also has the Mazda troubleshooting for your check engine code.
 Old 04-03-2014, 08:50 PM   #11
Zmcg1995's Avatar
Where do i find that FSM?
 Old 04-03-2014, 08:54 PM   #12
Sensei's Avatar
VIP forum -> mazdaspeed3/6 Shop Manuals -> Then the sticky Mazdaspeed3 Service Manual
 Old 04-03-2014, 08:55 PM   #13
Zmcg1995's Avatar
thanks man
 Old 04-05-2014, 12:18 AM   #14
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Originally Posted by Zmcg1995 View Post
thanks man
Call up the dealer who did. Re-timing should be part of the VVT service and covered at no cost.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 04-05-2014, 09:21 AM   #15
Zmcg1995's Avatar
I tryed that. They said that the engine wasnt timed wrong... They "double checked". They said its a matter of low oil pressure which isnt their doing.
 Old 04-05-2014, 03:25 PM   #16
Zmcg1995's Avatar
so i checked my dipstick today while i was under the hood and it looked low... i just changed it a couple weeks ago and i know i didnt fill it that low.. could i possibly have an oil leak? Maybe a hole in a tube or line? That would causing the pressure to be lower which is why i keep throwing the p0012 code. Any insight or thoughts?
Im not 100% familiar with how the whole oil pressure thing works so just a thought
Last edited by Zmcg1995; 04-05-2014 at 03:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-05-2014, 03:44 PM   #17
ihasmazda's Avatar
Posts: 1,011   (View Stats)
How low was it on the dipstick? Top it off and see if it disappears again...
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
 Old 04-05-2014, 03:54 PM   #18
Zmcg1995's Avatar
It was just below 1/2 and im possitive i filled up up higher than that... Ill top it off and drive it for a little.. see what happens.. Is there a way to check for leaks though?
 Old 04-05-2014, 04:06 PM   #19
ihasmazda's Avatar
if it's a bigger leak it should smoke and smell. also usually can spot something by crawling underneath the car and look around the motor with a flash light...
 Old 04-05-2014, 04:42 PM   #20
Zmcg1995's Avatar
I will jack my car up tomorrow and look around and see if i see anything..
 Old 11-22-2017, 04:28 PM   #21
Shadley's Avatar
Posts: 25   (View Stats)
Shadley will become famous soon enoughShadley will become famous soon enough
Zmcg1995 -
The exact same thing is happening to me, almost to a T. Dealer did my VVT, have p0012 code after, and they're telling me it's due to low oil pressure.
Just wanted to see if you ever figured out the cause and, if so, what it was?
Sorry for reviving an almost 4 year old thread btw - had to ask this though. Thanks!
Shadley is offline   Reply With Quote
 Old 11-23-2017, 03:32 PM   #22
Posts: 2,826   (View Stats)
Originally Posted by Shadley View Post
Zmcg1995 -
Consider PM'ing him. Chances are high that he will not be following an almost four year old thread, and may not even own the car anymore.
Hitting a necrothread is bad form and worthless almost always.
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 08-02-2019 11:09 PM
Oil pressure? drknyte MazdaSpeed 3 - Engine, Transmission & Driveline 4 04-10-2011 07:31 PM
Fuel Pressure PID bewsted 2010 MS3 - ECU Computer Tuning 16 02-03-2011 10:45 AM
Oil pressure RUMBLEFISH MazdaSpeed 3 - Engine, Transmission & Driveline 8 12-16-2010 06:44 PM
More oil pressure with the PTP kit? ptperformance MazdaSpeed 3 - Engine, Transmission & Driveline 17 03-18-2009 09:53 AM
Page generated in 0.42337 seconds with 25 queries
