![]() Join Date: Oct 2012 Location: Concord, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score I would re check with another gauge before you start worrying about tearing the engine apart. You can buy cheap mechanical oil pressure gauges at most auto parts stores. Also the general rule of thumb for engines, is 10 psi for every 1000 rpm. I haven't looked into any specifics what our engines typically run at. Just giving the general rule. Last edited by SaveMelMac; 09-12-2017 at 09:50 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to SaveMelMac For This Useful Post: | 1324Kyle (09-13-2017) |
| 0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? | AFcadet | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 08-02-2019 11:09 PM |
| Low oil pressure | Zmcg1995 | Mazdaspeed3/6 General Discussion | 21 | 11-23-2017 03:32 PM |
| Very low oil pressure | pmartz16 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 18 | 06-26-2016 02:45 PM |
| Oil pressure? | drknyte | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 04-10-2011 07:31 PM |
| More oil pressure with the PTP kit? | ptperformance | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 03-18-2009 09:53 AM |
