![]() Join Date: May 2015
Rep Power: 0 ![]() Thanks: 14
Groaned at 8 Times in 5 Posts
(Thread Starter) | Not Ranked : 0 score Hello everyone, I've been doing research regarding ideal warm idle oil pressure for our engines and have come to find multiple different answers. I have an 07 Speed 3 that has has an oil pressure of about 10-15psi usually (11) when fully warm and idling. My question is more about the condition of my engine, I've been reading that oil pressure should be around 30 when idling. I've also read that an older engines can idle as low as 15psi. My oil is at the correct level, I've checked multiple times. Other than a boost leak which is only in higher rpms, it seems like the engine has been running normally and accelerates fine. (1-3.5k rpms) (There is a decently loud clicking sound though coming from the engine bay at all times, not sure if that makes a difference or not). Do you guys think my engine is shot, or simply just idles at a low oil pressure? Thanks -Kyle Last edited by 1324Kyle; 09-12-2017 at 07:36 PM. |
![]() Join Date: Mar 2017 Location: Guelph, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Stock engine? Usually when people tune their cars they ‘up the idle rpm to around 1000. From what I’ve read, 23psi is where it should be at idle. Of course give or take a bit. If you’re stock and still idling at 750 (???) then it will of course be lower. I’m not sure how much lower. Mine is generally around 22-23psi at idle and then drops as oil becomes more diluted. That’s at 950rpm idle. I’m using 30w oil which I don’t normally use. Normally I use 40w. The ticking noise could be your timing chain/vvt. Sent from my iPhone using Tapatalk
__________________ '06 MS6 GT VRM |
| The Following User Says Thank You to BN00249 For This Useful Post: | 1324Kyle (09-12-2017) |
I've also probably done a significant amount of damage to the engine. A few months ago I checked my oil after weeks of constant beating on her and realized I was about two quarts short of the "fill" line on the dipstick. Yeah I know, I'm a jacka**. Anyways I wouldn't be surprised if I did a decent amount of damage during that time. Anyways, I appreciate your help, and anyone else reading this, if you have any insight on whether or not you think my engine is probably gonna blow up or not soon. I would appreciate all the information I can get. Thanks -Kyle | |
| Not Ranked : 0 score Next oil change run a 5w40 Rotella t6 or even find another full synthetic brand in a 50w. Even if you possibly think your motor is toast. It’s better to not totally kill it and you can just rebuild it. Running thicker oil will yield you more oil pressure and keep you from spinning a bearing. Sent from my iPhone using Tapatalk
![]() Join Date: Oct 2012 Location: Concord, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score How are you checking oil pressure? |
| Not Ranked : 0 score I would re check with another gauge before you start worrying about tearing the engine apart. You can buy cheap mechanical oil pressure gauges at most auto parts stores. Also the general rule of thumb for engines, is 10 psi for every 1000 rpm. I haven't looked into any specifics what our engines typically run at. Just giving the general rule. Last edited by SaveMelMac; 09-12-2017 at 09:50 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to SaveMelMac For This Useful Post: | 1324Kyle (09-13-2017) |
| 0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? | AFcadet | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 08-02-2019 11:09 PM |
| Low oil pressure | Zmcg1995 | Mazdaspeed3/6 General Discussion | 21 | 11-23-2017 03:32 PM |
| Very low oil pressure | pmartz16 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 18 | 06-26-2016 02:45 PM |
| Oil pressure? | drknyte | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 04-10-2011 07:31 PM |
| More oil pressure with the PTP kit? | ptperformance | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 03-18-2009 09:53 AM |
