 Old 06-08-2011, 10:43 AM   #1
bamf08ms3's Avatar
Posts: 34   (View Stats)
bamf08ms3 is a jewel in the roughbamf08ms3 is a jewel in the roughbamf08ms3 is a jewel in the roughbamf08ms3 is a jewel in the rough
Groaned at 6 Times in 1 Post
Default magnaflow cbe with corksport racepipe
I am considering buying the corksport racepipe. Does anyone know if the 80mm exhaust flange will bolt up to the magnaflow cbe?
2008 Mazdaspeed 3 - CorkSport FMIC kit with ram air box, Magnaflow 3" exhust, HKS SSQV V2 (Recirc), Dropzone lowering springs, Sure shifter weight, and slotted and cross-drilled rotors.
bamf08ms3 is offline   Reply With Quote
 Old 06-08-2011, 10:46 AM   #2
smokeys36shop's Avatar
Posts: 147   (View Stats)
smokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond repute
i have the corksport downpipe and corksport high flow cat and it bolts up fine to my magnaflow exhaust...no problems at all
i have a mazdaspeed 6 tho
smokeys36shop is offline   Reply With Quote
 Old 06-08-2011, 10:58 AM   #3
bamf08ms3's Avatar
yeah i don't know. Corksport's web site says it might fit some aftermarket cbes, i just need to know for sure.
 Old 06-08-2011, 02:19 PM   #4
well regardless of the make between speed 3 and 6 the sizing of the pipe and connection shouldn't be any different.
wait a sec...you have a 3inch magnaflow exhaust....why the hell wouldnt if work then? the flanges are both the same and they will bolt up together fine...you shouldnt have any issues
if my mazdaspeed 6 - 2.5 inch magnaflow exhaust meets up fine with the corksport 80mm pipe (which is 3.14 inches) then honestly your 3 inch exhaust shouldn't have a problem either
 Old 06-08-2011, 02:24 PM   #5
CorkSport's Avatar
Posts: 3,416   (View Stats)
Some of the systems neck down to 2.5 inches at the cat connection which can cause a problem.
Based on what I can see about their exhaust is it does neck down to 2.5 inches
-Derrick
WWW.CORKSPORT.COM
 Old 06-08-2011, 03:29 PM   #6
bamf08ms3's Avatar
[QUOTE=CorkSport;886811]Some of the systems neck down to 2.5 inches at the cat connection which can cause a problem.
That is what i thought. I still think i am going to get the 80mm have a flange welded onto the magnaflow so that i can get the full benefit of the 3" exhaust.
 Old 06-09-2011, 05:15 AM   #7
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
I have the corksport TP but with the stock cat-back hook up, 65 mm? can't remember, it fits fine. As far as sound goes I think you'll be happy. Shit is loud at start up though, be prepared.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 06-09-2011, 08:38 PM   #8
bamf08ms3's Avatar
bump
 Old 06-09-2011, 08:43 PM   #9
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
here is how i fixed my magnaflow exhaust to make it a true 3inch well 2 7/8 ID
Definitive Exhaust Thread
DONOTBUGME is offline   Reply With Quote
 Old 06-09-2011, 08:49 PM   #10
reconbygod12's Avatar
Posts: 112   (View Stats)
reconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to behold
Groaned at 33 Times in 13 Posts
magnaflow=gay
reconbygod12 is offline   Reply With Quote
The Following 6 Users Say NO Thank You to reconbygod12 For This Un-useful Post:
bamf08ms3 (06-10-2011), DONOTBUGME (06-09-2011), manelscout4life (06-11-2011), sallyspeed3 (06-10-2011), shaftyella (06-10-2011), wolly6973 (06-09-2011)
 Old 06-09-2011, 08:50 PM   #11
DONOTBUGME's Avatar
Groans: 266
Originally Posted by reconbygod12 View Post
magnaflow=gay
Brownie = faggot
The Following 3 Users Say Thank You to DONOTBUGME For This Useful Post:
bamf08ms3 (06-10-2011), manelscout4life (06-11-2011), wolly6973 (06-09-2011)
 Old 06-09-2011, 08:53 PM   #12
Originally Posted by donotbugme View Post
Brownie = faggot
ask me if i care what my thing is
The Following User Says NO Thank You to reconbygod12 For This Un-useful Post:
 Old 06-10-2011, 04:41 AM   #13
Why would we ask you? That would imply that we care about you.
The Following User Says Thank You to sallyspeed3 For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/magnaflow-catback-exhaust-corksport-racepipe-82872/
magnaflow cbe with corksport racepipe - Mazdaspeed Forums » Magnaflow Exhausts - Everything About Magnaflow Exhausts This thread Pingback 06-14-2011 08:34 AM
CORKSPORT Power Series Racepipe ST77 2010 MS3 - Turbo Induction 18 06-04-2010 03:55 PM
Page generated in 0.31689 seconds with 25 queries
