  • 1 Post By 86AmishMs3
 Old 03-01-2014, 05:49 PM   #1
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Default Mazdaspeed 3 07-09 Carbon fiber hood
Just a little review for those who are interested.
Basically over a month ago, I went off-roading to prevent a car collision. Needed a new hood. Decided to get a carbon fiber OE style hood. I'm not one for visual enhancements, so I was going for some weight savings. Obviously it it weren't for the wreck, would have never done this. You'd be better off not eating so much fatty...then getting the "racers edge"
Anyways I've helped a friend install his Fiber Images...I tried to get that, but the lead time was too long. 3-4 weeks. So I ordered a VIS hood.
Comparison between two:
Weight: Fiber Images - it is carbon fiber laid over a skeleton frame, unlike the VIS which is laid over a smooth fiberglass top, and then it has a frame on the underside. I would say the VIS saves 10lbs where the FI saves 15+
Fitment: VIS - near perfect fitment. There is more gap around the top of the headlamps, but I guess eyelids would fix that. The sides are almost perfect. The Fiber Images I helped install was a little off on one side, you tried to adjust it, the hood was off on the other side. Wasn't huge but it was there.
Visual - Same, both looked good.
Anyways here are my pics
MZRSPEED likes this.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 6 Users Say Thank You to 86AmishMs3 For This Useful Post:
anavrinIV (03-01-2014), Code Monkey (03-03-2014), Mase (03-01-2014), mxlplx71 (03-01-2014), Stretcher (03-06-2014), [R]usty (03-07-2014)
 Old 03-01-2014, 05:51 PM   #2
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
where did you get it and how much did it cost? My hood is long, long, long.......loooooooooonnnnnnnnng overdue for a new hood.
Blue Pu.
 Old 03-01-2014, 05:57 PM   #3
Domino81's Avatar
Posts: 5,081   (View Stats)
If I were you I'd clear it or paint it. I know it's cool to see the weave but I've never seen a carbon fiber hood that hasn't had a hazy gel coat after a certain amount of time.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
The Following 2 Users Say Thank You to Domino81 For This Useful Post:
86AmishMs3 (03-01-2014), Raider (03-02-2014)
 Old 03-01-2014, 05:58 PM   #4
86AmishMs3's Avatar
Groans: 338
Well it doesn't get out of the garage much...if it starts to haze I'll just paint it body color.
And I got it from bodykitsdepot they only had one in stock. Ebay is a viable option as well.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 03-03-2014, 12:19 PM   #5
Masterbaiter's Avatar
Posts: 137   (View Stats)
Masterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond reputeMasterbaiter has a reputation beyond repute
Thanks for the review. I am actually in the process of buying a VIS oe hood right now
Masterbaiter is offline   Reply With Quote
 Old 03-07-2014, 11:44 AM   #6
EvoFire's Avatar
Posts: 389   (View Stats)
I see you aren't running a TMIC, but are there provisions to bolt all the ducting back on? And how accurate do you think it is?
 Old 03-07-2014, 12:44 PM   #7
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Let us know how that works above 120mph.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 03-07-2014, 01:29 PM   #8
86AmishMs3's Avatar
Groans: 338
Works fine. I would feel comfortable going to 170.
Honestly don't know
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
Last edited by 86AmishMs3; 03-07-2014 at 01:29 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-08-2014, 01:24 AM   #9
mituc's Avatar
Groans: 111
No, I meant how it really works above 120mph, not how fast are you comfortable going. I wanted to know if it vibrates, lifts, unsets or anything, and I really meant it.
I'm asking this because I've seen a few CF hoods (not for our platform though) that had to be held in place with lock pins.
 Old 03-08-2014, 02:29 AM   #10
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
I have the vis hood, ive gone 120 with it and haven't noticed any movement or vibs.
seems to fit just like stock to me.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
Fiber Images Carbon Fiber Hood dark_matter MazdaSpeed 3/6 - Appearance 15 07-24-2015 01:39 AM
Carbon Fiber Ducted Hood Andrew85 Appearance - BLACK 112 04-05-2013 07:49 PM
carbon fiber hood for sale eolsen MazdaSpeed 3/6 - Appearance 1 10-27-2009 08:32 PM
VIS carbon fiber hood Gspeed.. does it fit ms3? marcusdigi MazdaSpeed 3/6 - Appearance 3 06-04-2009 09:14 AM
Page generated in 0.31637 seconds with 27 queries
