![]() Join Date: Feb 2018
Rep Power: 0 ![]() Thanks: 0
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score I'm confused. You broke the EBCS nipple for the bleed line to your TIP and got 11psi? Then you remove that hose...which is essentially the same thing, and now you get 15-16....? Broken, removed, or whatever of the bleed line will maintain proper boost control, but your fuel trims will be fucked.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) Last edited by Fstrnyou; 03-02-2018 at 03:59 AM. |
| The Following User Says Thank You to Fstrnyou For This Useful Post: | KiwiFlavor (03-02-2018) |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score In other words.. Yes that nipple is important. Every nipple is important.
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
| The Following 2 Users Say Thank You to KiwiFlavor For This Useful Post: | Db09ms3 (03-02-2018), Thor Hammer (03-02-2018) |
(Thread Starter) | Not Ranked : 0 score Thank you! I'm a little short financially so would it be fine to drive it for a while before replacing the BSC? |
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Thor Hammer (03-02-2018) |
| Not Ranked : 0 score Is it the line or is it the nipples? Know that if your EBCS nipple breaks, you can cause overboost.
![]() Join Date: Sep 2012 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
| Not Ranked : 0 score Getting suspicious about this one....
__________________ Corksport: SRI & TIP, Strut Tower Brace, Coilovers CP-e: RMM JBR: Rear Sway Bar (with Moog End Links) TWM: Full Replacement Shifter Cobb: AP AutoTech: HPFP Internals Ebay: Test Pipe |
| Not Ranked : 0 score Stock EBCS in this case: Broken source line will overboost. A broken bleed line will boost normal.
(Thread Starter) | Not Ranked : 0 score Sorry guys im a mess. I thought it was just the line at first but i checked it out and it was the nipple of the BCS too so I made a new post. But yes a little piece of the nipple of the BCS broke off and i tried to put the line back in and and i dont know how but i couldnt get more than 11psi of boost. When i took the line to the BCS completely off, then it went back up to normal psi around 15-16psi |
Groans: 211
I have a good used EBCS if you want it, no charge. PM me. All the nipples...
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| The Following User Says Thank You to Thor Hammer For This Useful Post: | Db09ms3 (03-02-2018) |
| Not Ranked : 0 score You have any extra nipples? Me love you long time!
Groans: 211
| Not Ranked : 0 score How much for these shipped? PM me.
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 | |
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | Thor Hammer (03-06-2018) |
| Not Ranked : 0 score i'm in for the nipple thread! op, be carefull, breaking nipple may get costly! If it is really the discharge from EBCS to TIH, it isn't that bad to drive few days without it. you have to temporary plug the TIH hole to avoid a leak at iddle for that side. And that little air wasted by the EBcS under full boost may not be a huge thing to drive your fuel trim crazy. If it is any other connections between turbo and WG, then, you can overboost and break the engine....
![]() Join Date: Jun 2009
| Not Ranked : 0 score OP, take up the offer for the free EBCS. Just be careful or you will break one off again. It is a common issue with many, many threads and posts here you might have found had you done a search. The permanent fix is something like the Grimmspead EBCS. It is a drop in replacement that the OEM wire plug will fit. Its nipples are brass. Will not break. I like hard nipples.
| The Following 3 Users Say Thank You to MSMS3 For This Useful Post: |
| Well I broke her | MortalMechanica | Mazdaspeed3/6 General Discussion | 7 | 06-18-2015 10:34 PM |
| This broke | mazdaspeeding | Mazdaspeed3/6 General Discussion | 10 | 01-04-2013 05:47 PM |
| HELP! i broke it | TheNewGuy | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 02-26-2010 06:49 PM |
