 Old 12-06-2018, 12:26 PM   #1
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Remove the speed control relay and see if the car will run with your jumper in place. That will tell you if the resistor is bypassed properly.
If it will run it means that pin 3 on the pump relay has a bad/broken wire inside the fuse box.
Starts then dies Last_Loser MazdaSpeed 3/6 - Troubleshoot/Diagnostics 33 03-17-2014 04:40 PM
With V3 car starts, but dies right away Mr Wilson Cobb Tuning 5 08-31-2013 08:12 PM
Engine starts and then dies Revyspeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-28-2011 07:16 PM
Starts then dies bnoon MazdaSpeed 3 - Engine, Transmission & Driveline 9 01-06-2010 08:24 AM
Page generated in 0.22707 seconds with 22 queries
