 Old 12-24-2018, 06:43 PM   #1
arvint123's Avatar
Posts: 10   (View Stats)
arvint123 has a little shameless behaviour in the past
Default Mazdaspeed 3 sway bar links
Heya,
So my 09 speed 3 recently has had rear clunking over bumps at low speeds (at the moment i dont have the space or tools to fix it myself), but I am taking it in the shop later for some brake work and i was thinking i might as well try changing out the sway bar end links. I heard very good things about pro-forged and that they keep the stock design of mounting it on...but im stuck with two different part numbers..does anyone know which is the right one for a 09 speed3?
https://www.ebay.com/itm/Proforged-1...53.m1438.l2649
or
https://www.amazon.com/dp/B0096O8XKU...v_ov_lig_dp_it
both check lists say they will work but i've learned not to always trust amazon/ebay's car check list.
Thanks!
arvint123 is offline   Reply With Quote
 Old 12-24-2018, 08:24 PM   #2
mgeoffriau's Avatar
Posts: 17   (View Stats)
mgeoffriau has a spectacular aura aboutmgeoffriau has a spectacular aura about
The Amazon link appears to be for a regular Mazda 3, not a Mazdaspeed 3. When I select the Mazdaspeed submodel on the Amazon page shows that it is not compatible.
2009 MS3 | Pretty Much Stock
mgeoffriau is offline   Reply With Quote
 Old 12-24-2018, 08:27 PM   #3
arvint123's Avatar
Ahhh gotcha, thats what it was. I assumed it was the same for both, Thanks!!!
 Old 12-24-2018, 08:31 PM   #4
mgeoffriau's Avatar
Just checked on Rock Auto as well, the ProForged listing for the MS3 there matches your eBay link.
shocks and sway bar links jdubs09 MazdaSpeed 3 - How-To's 8 03-03-2014 03:55 PM
Installing front sway bar links buckeyepost MazdaSpeed 3/6 - Suspension & Brakes 7 10-20-2012 09:05 PM
front sway end links ericrapp0507@gmail.com 2010 MS3 - Suspension & Brakes 27 08-25-2011 05:59 AM
Progress rear sway bar -- End links too short?? shaun3000 MazdaSpeed 3/6 - Suspension & Brakes 3 05-04-2011 06:15 PM
rear sway bar end links labikesrcool MazdaSpeed 3/6 - Suspension & Brakes 1 11-17-2010 04:41 PM
Page generated in 0.25805 seconds with 21 queries
