15Likes ![]() |
![]() Join Date: Nov 2010 Location: Poughkeepsie NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
(Thread Starter) | Neutral : +4 score It starts out with 3 stages to help guide you on your want to making a solid car. The second section is a listing by stage with a link to almost every part for the speed 6. If the stages don't help the community i will delete it but i figure new people can use this to build their cars and to find parts easier instead of asking. Hope it helps Additional Info is Welcome! General Build Thread To start out I want to say that this thread will favor the Cobb AP over any tuning device since I feel it is the best on the market. Other tuning devices are CP-E, Hypertech, Unichip & Versatuner So here are the stages. Note: there is no particular order to get these products and this is just a general guide Stage 1 - -I recommend start out with buying the Cobb AP. it can be used on a stock car/also allows for monitoring the car. -short ram intake or cold air intake with supporting turbo inlet pipe -Upgraded bypass valve or blow off valve -Upgraded spark plugs -Rear engine motor mount -3 inch test pipe Stage 2 - -3 inch exhaust -Upgraded downpipe -Top mount intercooler/front mount intercooler ( preferably fmic over tmic for better cooling ) -Upgraded fuel pump for higher than stock boost levels and power -Upgraded rear differential brace and mount. -Upgraded Passanger Side Engine Mount, Transmission Mount & Front Engine Mount (note: all of the above mods will work well with the stage 2 tunes on the Cobb AP or may need a slight tweek in the tune.) after stage 2 is where the power mods come in. you can go as far as you want with it. both stage 1 & 2 will give you everything you need to support these power mods. (note: all mods after will require some sort of protune/etune. it is recommended to speak to a professional or someone who is very knowledgeable in tuning the speeds. there is someone over on mazdaspeed forums named djuosnteisn who seems to be e/tuning alot of peoples cars and many of them seem to be very happy with it. http://www.mazdaspeedforum.org/forum/foru...ne-list-89893/ ) Stage 3- -Meth kit -Intercooler Sprayer -Turbo Upgrade -Depending on turbo upgrade a new turbo inlet and 3"intake -Turbo Manifold -Upgraded Wastegate Actuator -Engine Upgrade like pistons and rods or new motor -Upgraded Radiator -Ported Intake Manifold -Ported Throttle Body -Upgraded Clutch -Upgraded Flywheel -Upgraded Ignition System Additional Supporting Mods- Additional monitoring system Turbo Timer Boost Gauge Upgraded short shifter & bushings Shifter Cable Relocation Front & Rear Sway Bar Lowering Springs and Coilovers Balance Shaft Delete Thermal Insulating Gasket Boost Controller Oil Catch Can Front & Rear Strut Bar EGR Block Off Plate Injector Seals Map Sensors & Harness Overboost Protection This is all i can think of right now. Of course people are welcome to add more if i am missing any. -------------------------------------------------------------- First off here is a list of the main sites to buy parts from for Mazdaspeeds in general:
There are many different brands for each category. Below is a list for each, by stages in no particular order Stage 1 Tuning Solution Cobb Ap is a one of a kind product. Here is a link to Cobb with detailed information on it - COBB Tuning - MAZDASPEED AccessPORT . this link is only for the 2006-2007 mazdaspeed 6. There is a seperate link for the speed 3's Other Tuning Solutions VersaTuner - VersaTuner - tuning software for Mazdaspeed, Mazda MPS and Mazda CX-7 CPE- ??????? I don't see it on their site anymore CPE Standback (note: again please note this thread was set up using the cobb ap in mind due to the preset maps available for it.) Intake Systems Short Ram Intake- cobb - COBB Tuning - MAZDASPEED6 SF Intake Kit cp-e - MazdaSPEED6 XcelNANO corksport with inlet - Mazdaspeed 6 Short Ram Intake CorkSport Power Series Cold Air Intakes CP-E - MazdaSPEED6 Xcel Injen - Injen Cold Air Intake for Mazdaspeed 6 #SP6071 - Revolution Performance Motorsports! Inlet Pipes Cobb - COBB Tuning - MAZDASPEED Turbo Inlet Hose Corksport - CORKSPORT Power Series Turbo Inlet Pipe HTP - http://www.hitunedperformance.com/msproducts.html CP-E - MZR 2.3 DISI Nviscid Upgraded bypass valve or blow off valves HKS- MazdaSPEED6 HKS Blowoff Valve Kit | Custom Performance Engineering Cobb - MAZDASPEED XLE Bypass Valve Turboxs Hybrid BOV - Mazdaspeed 3 & 6 Hybrid Blow Off Valve - TurboXS GFB BOV - http://www.gfb.com.au/products?page=...ategory_id=179 Rear Engine Motor Mount JBarone - Rear Motor Mount 80a Durometer [MS6MollyRMM] - $90.00 : James Barone Racing, Custom Fabrication CP-E - MazdaSPEED6 Engine Mount | Custom Performance Engineering AWR - AWR Rear Motor Mount for MAZDASPEED 6 Test Pipe Corksport Race Pipe - CORKSPORT 'Power Series' Racepipe For Mazdaspeed 6 SLS - Protege Garage - SLS Test Pipe - Mazdaspeed6 Stage 2- Catback Exhaust Cpe Single 3" Exhaust- http://www.cp-e.com/products/mazdasp...exhaust-system Cpe Dual 3" Exhaust - http://www.cp-e.com/products/mazdasp...exhaust-system Corksport 80mm 3.1" Exhaust - http://www.corksport.com/corksport-p...st-system.html Magnaflow 2.5"/2.25" Exhaust - http://www.magnaflow.com/02product/s...ne=all&id=7597 GHL Duel 3" Exhaust - http://www.therpmstore.com/store/p/5...daspeed-6.html Custom Exhaust from a local exhaust shop Downpipe Corksport - http://www.corksport.com/corksport-p...-downpipe.html CP-E - http://www.cp-e.com/products/mazdasp...-3-ss-downpipe Ebay - http://www.ebay.com/itm/06-07-Mazda-...item1e6a5fe6f5 Top Mount Intercooler Corksport - http://www.corksport.com/corksport-m...tercooler.html CPE - http://www.cp-e.com/products/mazdasp...nt-intercooler PTP - http://www.pt-performance.com/showPr...4&cID=7&pID=52 Front Mount Intercooler Corksport - http://www.corksport.com/corksport-p...-fmic-kit.html Corksport Version 2 - http://www.corksport.com/corksport-m...am-intake.html CPE - http://www.cp-e.com/products/icy2011...nt-intercooler CX-Racing - http://www.cxracing.com/mm5/merchant..._Code=JDMZDSPD Altered Custom - http://www.alteredcustoms.net/Altere...it-MS6-p5.html Custom / Make Your Own Upgraded Fuel Pump KMD Fuel Pump Internals - http://www.kmdtuning.com/index.php?_...productId=1153 PTP Fuel Pump Internals - http://www.protegegarage.com/1663-hi...azdaspeed.html Autotech Fuel Pump Internals - http://edgeautosport.com/autotech-hi...p-upgrade-kit/ CPE Upgraded Fuel Pump - http://www.cp-e.com/products/hpfpump...fpump%E2%84%A2 Upgraded Rear Differential Brace and Mount. CPE - http://www.cp-e.com/products/mazdasp...erential-mount Turbine Tech Mount - http://www.streetunit.com/Turbine_Te.../ttms6rdfm.htm Passanger, Transmission Mounts & Front Engine Mounts AWR Kit - http://store.awrracing.com/products/...%252d2007.html Stage 3- Meth Kit Labante - http://superpowercharger.com/watermeth.htm Devils Own - http://www.alcohol-injection.com/en/172-speed-6 AEM - http://www.aemelectronics.com/water-...hnr91626repqu7 Turbo Upgrade BNR Stage 1-3 - http://bnrsupercars.com/ ATP General List - http://www.atpturbo.com/mm5/merchant...egory_Code=MS6 3" intake/inlet For UpGraded ATP Turbo ATP Inlet - http://www.atpturbo.com/mm5/merchant...egory_Code=MS6 ATP Intake - http://www.atpturbo.com/mm5/merchant...egory_Code=MS6 CPE Intake - http://www.cp-e.com/products/mazdasp...%A2-air-intake CPE Inlet - http://www.cp-e.com/products/mazdasp...%E2%84%A2-pipe HTP Inlet - HTP - http://www.hitunedperformance.com/ht...nlet-polished/ Jbarone Full 3" Intake System - Coming Soon Turbo Manifold Steedspeed - http://www.steedspeed.com/mazdaspeed...urbo_manifolds DNP - http://edgeautosport.com/dn-performa...ifold-ms3-ms6/ OBX - http://www.ebay.com/itm/OBX-MAZDASPE...item335689b238 Creative Performance - http://www.streetunit.com/Creative_P...e_p/cp1234.htm Full Race - http://www.full-race.com/store/turbo...-disi-mzr.html CP-E - http://www.cp-e.com/products/feature...turbo-manifold Engine Upgrade Pistons CPE Pistons - http://www.cp-e.com/products/mazdasp...3-disi-pistons CPE Magnum Stage 2 Pistons - http://www.cp-e.com/products/mazdasp...stage2-pistons Arias - http://www.protegegarage.com/948-product-948.html Rods CPE - http://www.cp-e.com/products/mazdasp...r-23-disi-rods New Motor CPE Stage 1 - http://www.cp-e.com/products/feature...-i-short-block CPE Stage 2 - http://www.cp-e.com/products/feature...ii-short-block CPE Stage 3 - http://www.cp-e.com/products/feature...ii-short-block Ported Intake Manifold MAPerformance - http://www.maperformance.com/maperfo...3-ms3rev3.html Grimmspeed - http://www.grimmspeed.com/catalog/pr...roducts_id=233 Ported Throttle Body Grimmspeed - http://www.grimmspeed.com/catalog/pr...roducts_id=234 Upgraded Ignition System HKS - http://www.therpmstore.com/store/p/3...MX-5-CX-7.html Additional Supporting Mods- E85 Gas - http://www.e85fuel.com/find-an-e85-station/ Additional Monitoring System Dashhawk - http://www.dashhawk.com/ Aeroforce Scan Guage - http://www.aeroforcetech.com/products_interceptor.html Auterra - http://www.therpmstore.com/store/p/5...hDyno-SPD.html ScanGauge II - http://www.therpmstore.com/store/p/3...-Computer.html Boost Gauge (note: there are a ton of aftermarket companies & sizes so i am only listing a few) 52mm Prosport - http://prosportgauges.com/52mm-boost-gauge.aspx 52mm Prosport Digital - http://prosportgauges.com/Digital-boost-1.aspx Upgraded short shifter TWM Stage 1 & 2 - http://www.twmperformance.com/shorts...rtshifters.htm Shifter Bushings Twm - http://www.twmperformance.com/bushin...ushing-kit.php Jbarone - http://www.jamesbaroneracing.com/sto...roducts_id=107 Shifter Cable Plate Jbarone Kits include Plate/weight/bushings - http://www.jamesbaroneracing.com/sto...ex&cPath=40_98 J Speed - http://www.jspeedinc.com/apps/webstore/ Shifter Plate Weight Jbarone - http://www.jamesbaroneracing.com/sto...ex&cPath=48_92 Front Sway Bar Racing Beat - http://www.racingbeat.com/Mazda-6/Sway-Bars/70100.html Rear Sway Bar Corksport - http://www.corksport.com/corksport-m...bar.html?sl=EN Coilovers KSport - http://edgeautosport.com/ksport-kont...coilovers-ms6/ Balance Shaft Delete GP-Werks - https://www.gp-werks.com/products/Du...aSpeed-6).html PTP - http://www.protegegarage.com/1768-ba...elete-kit.html Jbarone - http://www.jamesbaroneracing.com/sto...&cPath=198_201 Thermal Insulating Gasket Jbarone Intake Mani Gasket - http://www.jamesbaroneracing.com/sto...roducts_id=237 Jbarone Throttle Body Gasket - http://www.jamesbaroneracing.com/sto...roducts_id=243 PTP Intake Mani Gasket - http://www.pt-performance.com/showPr...cID=11&pID=248 Oil Catch Can (note: there are a ton of aftermarket companies so i am only listing a few) Corksport - http://www.corksport.com/corksport-oil-catch-can.html Jbarone - http://www.jamesbaroneracing.com/sto...&cPath=147_151 Protege Garage - http://www.protegegarage.com/1530-product-1530.html Protege Garage - http://www.protegegarage.com/1523-product-1523.html Front Strut Bar Corksport - http://www.corksport.com/corksport-f...daspeed-6.html Speedline Front Lower Strut Bar - http://www.thespeedline.us/servlet/t...06-pls-/Detail Rear Brace Bar Corksport - http://www.corksport.com/corksport-r...daspeed-6.html The Speedline - http://www.thespeedline.us/servlet/t...06-pls-/Detail EGR Block Off Plate Jbarone - http://www.jamesbaroneracing.com/sto...products_id=92 High Pressure Rail Valve PTP - http://www.pt-performance.com/showPr...&cID=3&pID=330 Injector Seals Cpe - http://www.cp-e.com/products/mazdasp...injector-seals PTP - http://www.pt-performance.com/showPr...&cID=3&pID=290 Map Sensors & Harness Harness - http://www.bitwise-motorsports.com/ Bosch Sensor - 3 Bar - http://www.bmotorsports.com/shop/pro...oducts_id/1721 Bosch Sensor 3.5 Bar -http://www.bmotorsports.com/shop/product_info.php/products_id/1772 Overboost Protection Stratified Guardian Angel - http://www.stratifiedauto.com/index....roducts_id=217 Last edited by burn813; 10-17-2013 at 02:35 PM. Reason: cullen eats penises |
| The Following 25 Users Say Thank You to smokeys36shop For This Useful Post: | Amped (07-07-2012), BlackBettyMS6 (04-08-2013), Boborn (12-24-2012), BrianB6 (07-10-2012), dynamix (07-09-2012), EddyV1987 (08-06-2012), ESB Jiu JItsu (08-07-2012), GartzSpeed (11-09-2012), Gatorbait (06-01-2012), James Geese (02-08-2013), Jh8909 (06-01-2012), KevMS6 (03-30-2013), kobberr (09-18-2012), Matx (06-01-2012), MS6FL (07-04-2012), nkimes (03-20-2015), Poohster (06-01-2012), Raider (06-01-2012), smittyMS6 (06-01-2012), speed3codes (06-23-2013), speedms6 (09-18-2012), TiGraySpeed6 (06-01-2012), wasiantimmy (07-26-2012), Whitebullet (10-29-2018), xI Leveler Ix (07-07-2012) |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score Just to add to your list, Full Race makes a killer 2pc downpipe for these cars and RPS as well as Southbend both have clutches near production.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
| Not Ranked : 0 score I would add SPC ball joints to stage 1 (really any stage) - combined with a proper alignment it makes the car a different animal handling-wise.
| Not Ranked : 0 score Shame you're not VIP, I suspect @Raider would reward this effort
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Raider (06-01-2012) |
| Not Ranked : 0 score Damn. this is def $$ MSF Bucks worthy of a reward. but no VIP. I stuck it. FWIW. CPE Standback is doorstop material now. |
| Not Ranked : 0 score If @barone takes time and posts up the links to his stuff, I can add it too. |
| Not Ranked : 0 score List is in need of the MD SM OCC link - OCC KITS MAZDASPEED6 - Performance Automotive Development LLC
(Thread Starter) | Not Ranked : 0 score ti you know im still new with this site lol...i will donate tonight when i get home from work |
| The Following User Says Thank You to smokeys36shop For This Useful Post: | TiGraySpeed6 (06-01-2012) |
| Not Ranked : 0 score pm me when you do, I'll make you rich... |
(Thread Starter) | Not Ranked : 0 score Its true Cpe is no longer selling the standback but i was told they still work with it for people who still own it or buy it used. thats why its up on the list |
(Thread Starter) | Not Ranked : 0 score will do...expect my pm some time tonight then. no idea what you do with the msf money lol but i am sure in time i will find out I do hope this turns into a good thread for people to turn to for helpful info. i have always said that people need a helpful structured guide/list for modding for this car. This thread in total took well over 20 hours of research so far on different companies sites. Raider if you know of a way to make it more appealing to the community here let me know and i will try to correct it the best i can. |
| Not Ranked : 0 score Wow. Well, at least the 5 remaining users are in luck, lol. |
| Not Ranked : 0 score lolz- Smokey you're all good! I'm 800+ posts in and have never pointed out a post to Raider before It's an MSF way of saying Damn Nice Job!
(Thread Starter) | Not Ranked : 0 score I am no longer BROWN |
| Not Ranked : 0 score $ sent |
![]() Join Date: Apr 2010 Location: St. Louis, MO/Boulder, CO/Akron, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 277
Groaned at 13 Times in 2 Posts
| Not Ranked : 0 score smokeys36shop, I want to thank you for this info, I just picked up my used Speed6 since I totaled my 3 and have been looking for a post like this since I'm sure as hell not making a noob "what should I do first" thread. You've make my life 20x easier. Well deserved sticky, nice work. |
![]() Join Date: Oct 2011 Location: Peabody, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,278
| Not Ranked : 0 score This should be a sticky for noobs! Awesome job on the research and time that went into making this thread. Also would like to add a side note. Corksport has a new front sway bar coming out the middle/ end of July for the mazdaspeed 6 and it is 28.5mm. Reasonably priced. Just a FYI for this thread and to add to that they are in the development to a few more items they have not made public yet for the mazdaspeed 6's.
__________________ mods: Do wmi 50/50, freek tune 306hp/350tq. blitz bov, cpe hpfp, tmic, excel nano sri, tip, blue duro rmm, 3" ss catted dp, 3" ss cs cat back exhaust, Cobb AP, sure short cut, counter weight, twm stage 1&2, ms cf shift knob, msd dh, autoexe rear brace, whiteline rsb, tt rear diff mount, awr pmm , winter=stock wheels w/winter tires / summer=18x8 adr hyp black wheels w/bfg force kdw, eibach sportline springs. Soon to come: bt, slotted rotors, cf fi hood |
Added Street Units Exhaust Manifold - StreetUnit Exhaust Manifold Last edited by smokeys36shop; 07-09-2012 at 07:41 AM. Reason: MSF Database - Automerged Doublepost | ||
(Thread Starter) | Not Ranked : 0 score added Injector Seals, Map Sensors / Harness & Overboost Protection to the bottom of the list |
| The Following User Says Thank You to smokeys36shop For This Useful Post: | TiGraySpeed6 (07-25-2012) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score Add Go-Fast-Bits "Respons" BOV to BOV list, Works quite well on the Speed Options include being able to go from Full recirc and Full VTA and Anywear in between with a twist of a built-in knob and Fully adjustable/tunable spring load Link: Respons
__________________ Long Block Built by GPwerks and Loose Screw Motor Sports https://www.gp-werks.com/ http://www.crossoverauto.com ^Any Parts, Great Prices^ |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() Thanks: 0
Groaned at 9 Times in 2 Posts
| Not Ranked : 0 score I used this thred all the time for my car. Thank You |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score please add the JBR balance shaft delete to this list now. Thank you
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. |
![]() Join Date: May 2012
| Not Ranked : 0 score great Thread, Thank you |
![]() | | #24 | ![]() |
![]() Join Date: May 2011 Location: Greenville, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Groaned at 6 Times in 3 Posts
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 Stratified | |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score The stock bpv for me was a piece of crap. Not saying all of them are but mine was leaking. I personally don't like the stock plastic bpv and an upgraded metal one is something worth investing into if you ever plan on turning up the boost or for just holding proper boost levels. My factory boost levels were around 12-13 lbs of boost when I was stock. As soon as I upgraded to a aftermarket bpv I noticed I was where I was supposed to be from the start. That's my experience with it and is a reason why I added it where I did. Again this is a general guide. No need to follow it 100%. I have met people in the past who just love the stock bpv but many who hated it and experienced the same issues I did with holding proper boost levels. |
| The Following User Says Thank You to smokeys36shop For This Useful Post: | TiGraySpeed6 (09-18-2012) |
![]() | | #26 | ![]() |
![]() Join Date: Jul 2011 Location: Bowling Green, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 140
| Not Ranked : 0 score Quite a few links were broken in the OG post so I fixed them and added a couple things along with a section for e-tunes as that's getting more popular. Just need Gary to copy/paste this into the original post. Tried to quote it in this post but it's giving me a database error...
__________________ JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com |
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
![]() Join Date: Aug 2019
| Not Ranked : 0 score Recently took the engine apart on my ms6 and found what I already figured was wrong (cracked piston). I am looking for forged pistons to buy any suggestions on a specific brand? |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/mazdaspeed-6-general-build-parts-thread-115234/ | ||||
| So I had an RX-8 for 10 years and loved it, now I'm looking into something more practical but still fun. Can any of you tell me about the Mazdaspeed 6? Anything I should be weary of or be aware of? : mazda | This thread | Refback | 11-22-2013 07:14 PM | |
| Display Modes | |
| First Pu general thread | ChimmyChong | Gen2 MS3 General Discussion | 15 | 03-31-2011 11:23 PM |
| AM General to build VPG MV-1 people-mover at Hummer H2 factory | Haltech | Automotive News | 0 | 10-21-2009 12:00 PM |
