Like Tree337Likes
 Old 06-26-2015, 10:24 PM   #761
Police - Grammarhead
Vansquish's Avatar
Fucking welder took his fucking time but he finally dropped off an adapter that will transform my top mount ETS intercooler into a front mount ETS intercooler. Ladies and gentlemen, let me present to you:
There is no bead on the hot side yet as we may have to trim it if needed, and the IC square opening will be ported round for improved flow.
The IC itself will sit at a slight angle, the bottom will rest on the radiator support, the top will lean against the crash bar and be secured with brackets. The hood prop will be gone and the piping will run over the top of the hacked up radiator support. Here is a rough sketch of the idea except that the ETS IC is shorter (obviously not my car in the picture):
We figured with the IC ducting gone from under the hood, there is just enough space to squeeze the piping, will mock up the whole setup hopefully early next week and then order piping and couplers.
NICE! I've been eyeballing my engine bay for the last couple of years and wondering if this was a possibility. I'm looking forward to seeing how it all turns out!
Code Monkey (06-27-2015), Hammology (06-26-2015)
 Old 06-27-2015, 03:38 AM   #762
MSP611's Avatar
Posts: 2,291   (View Stats)
found these cool pics on brake ducting setups, looks like I might be deleting my fog lights for this... cant go wrong in my eyes.
Brake Ducts
MS3 Brake Ducts
In progress:
 Old 06-27-2015, 07:37 AM   #763
Our stock TMIC (and any aftermarket TMIC that replaces the stock one) is vertical flow.
I mocked up several different setups and the ETS seems to fit the bill the best. If you want to run both hot and cold side over the radiator, you will see that the shape of the hood, once you remove the underhood ducting, dictates that the distance between the center of the pipes be around 17".
You could use a Treadstone TRV 1259, but it is rather narrow ad then you will have to run piping like this:
Or you could use something like a TR335 for BMWs, but with a wide IC you will have to run piping like this:
The distance between the inlet and outlet on the ETS seems to be perfect or almost perfect to run the piping in a straight line, here with a hood line:
I will duct the radiator first and then worry about ducting the IC.
Easter Bunny (06-27-2015), torquemaniac (06-28-2015)
 Old 07-01-2015, 04:54 PM   #764
Slow progress is slow but we are getting there. Here is the front view:
And here's the top view:
We will have to trim the top of the radiator support a bit more for piping to clear but it should not be much. The radiator sides are already ducted; rotate the picture 90* ccw for a proper view:
And we plugged the holes in the skirt as well.
Tomorrow or Friday we will mock up piping so hopefully I can order shit this week and we can finish next week or two.
dale_gribble likes this.
The Following 6 Users Say Thank You to Code Monkey For This Useful Post:
Easter Bunny (07-02-2015), Hammology (07-02-2015), ItsNox (07-02-2015), Mauro_Penguin (07-01-2015), torquemaniac (07-01-2015), Voltwings (07-02-2015)
 Old 07-01-2015, 05:52 PM   #765
torquemaniac's Avatar
Posts: 733   (View Stats)
WOW...theres so much space in front of the rad without all the accesories and the crash bar...
2011 CX-7 AWD 2.3 turbo
 Old 07-01-2015, 05:56 PM   #766
11" from the radiator to the grill, IIRC.
 Old 07-01-2015, 10:10 PM   #767
MSP611's Avatar
What material did u make Tht black side ducting out of? Looks like u mounted it with self tapping screws
In progress:
 Old 07-01-2015, 10:21 PM   #768
Will ask the shop tomorrow. There are 4-5 small rivets on the bottom and there will be one bolt there as well going down and connecting the ducting to the skirt. There are 3 bolts on the side.
MSP611 (07-01-2015)
 Old 07-01-2015, 10:27 PM   #769
MSP611's Avatar
Are the 3 bolts on the side self tapping or nuts and bolts?? This looks like a simple great idea. Any pics of how Ur gunna duct Ur intercooler?
In progress:
 Old 07-01-2015, 10:43 PM   #770
Not sure, once I have the car back I will take the whole front apart for "practice" and see how everything is held together.
We have to figure out first how to run the piping and how to close/duct the top before I even start thinking about ducting the IC.
 Old 07-01-2015, 10:53 PM   #771
Vansquish's Avatar
Brake Ducts
MS3 Brake Ducts
As long as you're OK with cutting the bumper cover a little bit, and doing a little bit of fab work (which you'd be doing anyway with brake ducts), you could probably get away with leaving the fog lights in-place. There's quite a bit of space towards the car's centerline behind the vanity covers for the fog-lights. I don't see any reason why you couldn't throw some duct-work in there and keep your fogs too.
The other option, if you wanted to keep the fog-functionality, would be to pull apart your headlights and integrate the fog-unit like in the 2003-05 MZ6.
 Old 07-01-2015, 11:11 PM   #772
MSP611's Avatar
U think I could run the piping and the fogs side by side with the ducting??
In progress:
 Old 07-01-2015, 11:26 PM   #773
Vansquish's Avatar
I don't see why not. If you're already doing fab-work for the piping, you'd just have to go a little farther and make a partial bracket to hold the portion of the fog-light housing toward the centerline of the car in place. Of course, there is the small matter of the crash beam, but you could probably make something work even so.
 Old 07-01-2015, 11:42 PM   #774
MSP611's Avatar
Good pics and I will have a custom crash bar I'm building when I'm home so it shouldn't be a problem like in Ur pics.
In progress:
 Old 07-01-2015, 11:52 PM   #775
MSP611's Avatar
Hmmm I wonder how the bracket will have to work for the tubing on the fog light housing.
Here is the tubing I'm thinking of using for brake duct on both the fronts. I would us the horn as the intake and cover with some kind of mesh. I wonder if I just flush mounted it and sealed the back side of the horn if it would stay.
3'' Adjustable Intake Pipe - Blue https://www.amazon.com/dp/B007O0UOI2..._uenLvbGCA8CQG
This is Wat I'm thinking of using for the rear like the speed3 guys did.
Mishimoto MMHOSE-D2 2" x 12' Heat Resistant Silicone Ducting https://www.amazon.com/dp/B004MED2X2..._pfnLvbEPP3626
Then just hang with zip ties, possibly stainless zip ties for the added strength, and cut holes in the back of the dust shields
In progress:
 Old 07-02-2015, 12:05 AM   #776
Vansquish's Avatar
Not my pics. Those are all from M247...
A custom bar will probably gain you some clearance, but I don't think there should be any real difficulty with room as it is. You could even make it look 90%+ stock.
 Old 07-02-2015, 12:27 AM   #777
MSP611's Avatar
Ya ima try to flush mount the blue horn for the fronts and seal it off wit something then make a bracket possibly... Ya there won't be any bulky crash bar there anymore
In progress:
 Old 07-02-2015, 03:20 AM   #778
MSP611's Avatar
U have a picture of the back of the fog light shroud/bumper cover?? How does it mount I don't remember?? Just click in tabs is Wat I'm guessing
In progress:
 Old 07-02-2015, 10:47 AM   #779
you car now looks buck-toothed
JFSpeed3 likes this.
Code Monkey (07-02-2015), Vansquish (07-02-2015), Voltwings (07-02-2015)
 Old 07-02-2015, 11:05 AM   #780
Voltwings's Avatar
Posts: 3,713   (View Stats)
Lol got me busting out laughing at work.
Easter Bunny likes this.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Easter Bunny (07-02-2015), Vansquish (07-02-2015)
 Old 07-02-2015, 11:07 AM   #781
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
You could leave the foglights alone and just add some intakes to the grill area.
The Following 4 Users Say Thank You to Tyhackman15 For This Useful Post:
BLKSTIG (07-03-2015), Code Monkey (07-02-2015), torquemaniac (07-31-2015), Vansquish (07-02-2015)
 Old 07-02-2015, 11:21 AM   #782
MSP611's Avatar
meh takes up front mount area tht would also mean longer ducting which means more weight
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
 Old 07-02-2015, 11:31 AM   #783
Sure it takes up some space but his front mount clearly isn't in those spaces.... and if we're talking added weight of 6 inches of hose (about 10 ounces lol) then c'mon...
It's more of a, whichever location ends up being easier to mount decision, IMO
Sent from my SAMSUNG-SM-G900A using Tapatalk
The Following User Says Thank You to Tyhackman15 For This Useful Post:
 Old 07-02-2015, 11:34 AM   #784
I need these "spaces" for fresh airflow to the radiator, this is why I designed the front mount the way it is.
torquemaniac (07-31-2015), Tyhackman15 (07-02-2015), Vansquish (07-02-2015)
 Old 07-02-2015, 11:36 AM   #785
then delete the fog, mount up two of these and call it a day lol https://www.pegasusautoracing.com/pr...p?Product=3626
The Following 2 Users Say Thank You to Tyhackman15 For This Useful Post:
 Old 07-02-2015, 11:40 AM   #786
MSP611's Avatar
U can get those on Amazon for way cheaper. And I'm tryin to figure out a way to do it with keeping the fogs which is fully possible since the fog shrouds have a lot of space on the inner portion towards the grille. I just won't be home for awhile
In progress:
 Old 07-02-2015, 11:40 AM   #787
Yes, that will come in due time.
 Old 07-02-2015, 01:40 PM   #788
Vansquish's Avatar
Leave it to the @Easter Bunny; to point out the buck-teeth. XD
 Old 07-17-2015, 05:42 PM   #789
A little update.
Here's some pictures of the piping. We need two more pieces for the hot side (order placed) -- a 90* bend on the intercooler side and a straight coupler on the turbo side. The cold side is all mocked up and looks good. On Monday, my welder should be picking up the pipe that goes into the TB to weld in a BPV flange and a meth bung, and we should be good to go.
The hood will require slight banging in on the inside as right now it just touches the silicone when it is closed.
The crash bar now has nice vibra mounts for the intercooler.
The hot side pipe will have a bracket welded on that attaches to the IM.
You can also see the side ducting. The top ducting will be added the very last, when we have everything else done.
Last but not least, at some point I will have to get rid of that ugly ass radiator overflow tank and ideally relocate the tank somewhere, just look at this elegant solution on a Miata.
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
Mauro_Penguin (08-03-2015), Spec (07-20-2015), torquemaniac (07-18-2015), Voltwings (07-18-2015)
 Old 07-18-2015, 02:52 AM   #790
MSP611's Avatar
A little update.
did u use plastic for the ducting on the sides or sheet metal? u have a better pic of how its mounted I see bolt heads but wat is it screwed/mounted to?
In progress:
 Old 07-18-2015, 10:03 AM   #791
Aluminum (painted black). The bolts go into the stock radiator support frame.
 Old 07-18-2015, 03:04 PM   #792
MSP611's Avatar
did u use self tappers or nuts and bolts? hmmm I wanna do this bad hopefully ill have time to do all this shit.
In progress:
 Old 07-20-2015, 04:17 PM   #793
Spec's Avatar
Posts: 4,472   (View Stats)
Go cheap mode
ItsNox likes this.
The Following 3 Users Say Thank You to Spec For This Useful Post:
Code Monkey (07-20-2015), Easter Bunny (07-21-2015), Voltwings (07-21-2015)
 Old 07-21-2015, 10:23 AM   #794
those cans are actually pretty heavy duty
 Old 07-21-2015, 12:47 PM   #795
RalliartRsX's Avatar
Posts: 366   (View Stats)
RalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the worldRalliartRsX is the leader of the world
Considering the toxic liquid inside known as "Monster energy drink", they better be made out of unobtanium!
RalliartRsX is offline   Reply With Quote
 Old 07-26-2015, 10:41 PM   #796
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Just reread the whole thread. Wow this car really has gone full blown racecar!
Did you ever think about a Cp-e fmic? I vaguely recall them being vertical flow core.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
Code Monkey (07-26-2015)
 Old 07-26-2015, 10:56 PM   #797
The cp-e MS6 has been discontinued for a while and by reading on it, the fitment was a hit or miss, but yeah it is/was vertical flow. I am really hoping to have the car back sometime this week for a test run, the car should be finished except I will have to bead roll the piping or have it welded to eliminate as many couplers as possible.
Easter Bunny (07-27-2015), Mazdazilla6 (07-27-2015), Voltwings (07-27-2015)
 Old 07-31-2015, 06:13 PM   #798
Fuck that Synapse ring with 10,000 bags of rotten dicks!!!!!! It is fucking impossible to squeeze it and slip a nut on the bolt because the fucking bolt is just too short.
I am not sure if I could ground down a bit the tabs on the inside of the ring? In any case, the provided bolts are M4-0.7mm x 12mm, I found bolts in 16mm at the Home Depot, although not stainless steel, shit will have to do for now.
I am going back to the shop tomorrow morning and assuming I can install the valve, I should be able to take the car for a spin. I will only have the B port hooked up, do I just leave the A port open or do I need some sort of a dead plug? @Lex;
The intercooler outlet is ported now for a nice flow.
Easter Bunny (08-06-2015), ItsNox (08-01-2015), Mauro_Penguin (08-03-2015), Micha (07-31-2015), torquemaniac (07-31-2015), Voltwings (08-04-2015)
 Old 08-01-2015, 01:55 PM   #799
aackthpt's Avatar
Posts: 1,450   (View Stats)
You leave port A open. There are some filter plugs you can get if you're concerned but synapse recommendation is to just leave it open. @Lex; doesn't have that problem personally as he runs a+b.
Tapnstalk
2013 'speed3, silver
Stage Bro
Code Monkey (08-01-2015)
 Old 08-01-2015, 08:02 PM   #800
Well, fuck, another fail today.
Went to the shop in the morning, put the fucking Synapse in, tightened everything up, noticed that the intercooler on the driver side was easy to move up and down -- cracked weld. Bill said they would fix it next week. Tried to put the front bumper on, which usually takes me two minutes, no matter how we tried, the shit would just not align. The battery was dead -- I dropped off a special charger for Braille a few weeks ago, but someone disconnected the charger a while ago. Used a Booster Pac to start the car, drove home without the front bumper, Bill followed in his pickup and the bumper.
Fucked around for half a day trying to install the bumper, trimmed some ducting, trimmed some plastic skirt, the passenger side fits perfect, the drivers side no fucking go. In the end I realize it has to be the crash bar, it is sticking out like half an inch further on the driver side, this also explains why the intercooler bracket on that side is longer too.
Will be dropping the car off at the shop Monday morning to have shit fixed. I have no idea how, but the hood line aligns perfectly with the fenders, but with the tmic and the scoop gone there is a huge gap between the hood and the bumper, wtf? In any case, we will need ducting on top of the radiator, now I have a shitload of air flowing happily into the engine bay.
The only positive today is that the car does drive....
Mauro_Penguin (08-03-2015), Voltwings (08-04-2015)
Red Bull Racing drives world's highest road through the Himalayas Haltech Automotive News 0 10-12-2011 12:50 PM
Everything youll want to know about road racing/autocross too jroc Auto-X / Road Racing / Time Attack 18 05-21-2011 07:22 PM
Road Racing or HPDE Pics chad Auto-X / Road Racing / Time Attack 23 04-17-2009 08:03 AM
Scion to go road racing in KONI Challenge Haltech Automotive News 0 06-20-2008 05:50 PM
Page generated in 0.61484 seconds with 31 queries
