 Old 03-24-2017, 08:43 PM   #1
turbskies's Avatar
Posts: 178   (View Stats)
turbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to behold
Groaned at 9 Times in 6 Posts
Default Muffler delete without any aftermarket tune?
Was just wondering if you could get away with doing a muffler delete without a tune? I know this is frowned upon, but I don't wanna have to spend 650 on an accessport just to squeeze a little more noise out of the ole rust bucket.
turbskies is offline   Reply With Quote
The Following 3 Users Say NO Thank You to turbskies For This Un-useful Post:
CJ Speed6 (04-27-2017), g00s3y (04-27-2017), MSMS3 (03-25-2017)
 Old 03-25-2017, 11:48 AM   #2
Posts: 2,830   (View Stats)
A little more noise?
It won't increase power at all. Some remove resos. Muffler is all the way back. Yes, it's safe on stock tune because there is no flow increase. You will sound like a farm tractor. Go for it. Paint your car John Deere green with yellow wheels while you are at it.
You do know we have a search function on this board? I guess you're just too damn lazy. Only hundreds of exhaust threads here. Consider at least trying to search.
 Old 03-25-2017, 11:52 AM   #3
turbskies's Avatar
A little more noise? It won't increase power at all. Some remove resos. Muffler is all the way back. Yes, it's safe on stock tune because there is no flow increase. You will sound like a farm tractor. Go for it. Paint your car John Deere green with yellow wheels while you are at it.
You do know we have a search function on this board. Considering at least trying it.
Lol found it right after I posted this, probably should've deleted it, but thanks anyways.
 Old 04-27-2017, 07:55 AM   #4
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
Mine is replaced, not deleted. No codes or problems.
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
The Following User Says Thank You to Bexar For This Useful Post:
turbskies (04-27-2017)
Muffler Delete? speed6_5127 MazdaSpeed 3 - Engine, Transmission & Driveline 13 07-11-2015 02:55 AM
Muffler Delete Map coltonbarrier 2010 MS3 - ECU Computer Tuning 13 07-23-2014 04:28 PM
Res, 2nd Cat, Muffler delete. omgvance Gen2 MS3 General Discussion 18 01-08-2014 09:25 AM
Res AND Muffler delete? clowncar 2010 MS3 - Engine, Transmission & Driveline 33 03-09-2011 08:53 PM
Page generated in 0.26072 seconds with 22 queries
