![]() Join Date: Aug 2019
Rep Power: 0 ![]() Thanks: 0
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| What modifications are on the car. Please post the entire list, as that will help us diagnose your car.
(Thread Starter) | Not Ranked : 0 score Bnr s3 turbo 3 bar map 3.5" intake High pressure fuel internals 3" catted down pipe 3" custom exhaust with 14" magnaflow glass pack 3.5" turbo inlet pipe Cobb electronic boost controller Cobb accessport (freektuned by Justin) Go fast bits bov Cpe tmi Oil catch can Engine has between 70k-80k miles |
| Thanks. Now it would be useful to have some WOT datalogs that replicate the problems you're trying to diagnose. To take a WOT datalog properly, find a flat and empty stretch of road. In second, third, or fourth gear (preferably third or fourth), get up to around 2500RPM, start datalogging, and then go WOT from around 3000RPM up to about 6000RPM, then end datalogging. Post the logs on the forum, and we'll see what we can see. Please make sure that you are datalogging at least the following: Accelerator Pedal Position Actual AFR Boost Pressure Boost Air Temp Calculated Load Coolant Temp HPFP Actual Pressure Injector Duty Cycles Intake Temp Intake Valve Adv. Knock REtard Long Term Fuel Trims MAF Voltage MAF Airflow (g/s) RPM Short Term Fuel Trims Spark Advance Throttle Position Wastegate Duty Cycles
