 Old 07-08-2014, 07:23 AM   #1
sac02's Avatar
Posts: 313   (View Stats)
sac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the worldsac02 is the leader of the world
Default Need some ideas regarding turbo fitment in a Mazda5
Turbo fitment issue, but this is on a Mazda5, not a speed. I'm looking for input/brainstorming
ideas from the MSF braintrust.
Note: If you want to ask why I am putting a turbo on a mazda5 (or just call me a dumbass),
please PM me or search my post history. I feel I've answered that question enough times,
and would prefer to not clutter this thread with that conversation again.
So here is the issue (also see pictures):
This distribution block for the brake lines is going to interfere with the IWG actuator on my
turbo by about 0.75 inches.
Is this distribution block in the way for BT installs on ms3’s, or is this a mazda5 unique
feature?
I measure 10" from exhaust flange to the farthest back portion of the IWG actuator on the
turbo (picture perspective makes it look longer, but it is 10"). I could maybe gain 0.25" by
cutting and rewelding the actuator bracket, or slotting the actuator mounting holes.
It is about 9.0 or 9.25" from the exhaust flange on the engine to the distribution block on the
firewall. Obviously I can unbolt that bracket, but I don't know how much I'm going to be able
to reposition that block with 6 brake lines running into it.
Thoughts?
With time I could work around this, but I am intent on installing the turbo this weekend – so
I’m reaching out to the group to ask what you think.
Top view, you can see the exhaust manifold stud near the bottom of the pic, and the
distribution block is partially hidden in this view, up against the firewall, hidden behind a fuel
line bracket.
Here is an off-axis view from the top where you can see the distribution block better.
Here is on off-axis view further to the side.
Here is a view as far to the side as possible.
And here is the side view of the turbo and the IWG actuator which is the point of
interference.
sac02 is offline   Reply With Quote
 Old 07-09-2014, 07:15 AM   #2
sac02's Avatar
No thoughts?
Maybe I should ask to move this to the BT forum?
 Old 07-09-2014, 07:23 AM   #3
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
That block doesn't exist in the 3s so we haven't had to deal with it. Can the block be undone and relocated? I'm guessing it won't move much being attached to hard lines but maybe you can get just enough to clear the turbo. This is a situation where an EWG turbo really would have come in handy
Blue Pu.
WetzMS3 (07-09-2014)
 Old 07-09-2014, 07:49 AM   #4
sac02's Avatar
Two good points - I wasn't sure if that block was in the ms3, thanks for the confirmation.
You are correct that EWG would have been a good choice in retrospect. My research on turbo'ing NA mz3's did not reveal any issues related to this dist block - or IWG actuator clearance in any form - so I'm thinking this may be a mz5 specific issue.
I had just too much to do last night and was unable to unbolt the bracket and see how much play in those lines. I'm afraid that it will be not much.
 Old 07-09-2014, 08:09 AM   #5
anavrinIV's Avatar
Groans: 63
I read through this yesterday and was going to suggest and EWG turbo until I got to the part where you already had the turbo. So that was out.
I think you need to move it down, not sideways. There will be a decent amount of movement in that block vertically since all of the lines run laterally, if you need just a bit of clearance then you may very well be able to get it just by bending the lines a bit. Brake line is quite flexible and since it's never run in dead straight shots anywhere you can often flex it to get some clearance
Blue Pu.
cpe TIP fitment, test pipe fitment dhsieh911018 Gen2 MS3 General Discussion 2 03-06-2012 03:34 PM
Redesigned Mazda5 will cut emissions 15% Haltech Automotive News 0 01-20-2010 12:50 PM
Page generated in 0.28113 seconds with 21 queries
