 Old 02-27-2018, 07:32 PM   #1
blublub's Avatar
Posts: 12   (View Stats)
blublub has a little shameless behaviour in the past
Default No compression
I bought a 2007 mazdaspeed3 last month and the dude told me all it needed was a coil pack. One month later I have replaced all coilpacks, spark plugs, and checked the injectors. I'm getting spark and fuel, just no compression In cylinders 1 and 3. The other two cylinders had good compression, I can't remember the exact numbers. I'm not leaking any oil or have oil mixed in with my coolant. What could cause the total loss of compression in only two cylinders? I've searched the forums and haven't found much helpful information. I apologize if I anger you veteran members with my stupidity
blublub is offline   Reply With Quote
 Old 02-27-2018, 08:13 PM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
I would say if compression is zero.....
Bent/broken valves, piston gone or well fucked, compression tester not being hooked up correctly....
 Old 02-27-2018, 08:28 PM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
A leakdown will tell you where it's failing.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Pu Manchu (02-27-2018)
 Old 02-27-2018, 09:00 PM   #4
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
compression tests would be a complete waste of time if they weren't so easy.
you're gonna have to do a leak down test, and do it correctly.
94 M
MS6
IS350
Another compression thread. 94dsm Mazdaspeed3/6 General Discussion 8 02-23-2018 03:23 PM
Low compression and BNR S4 feldm4n MazdaSpeed 3 - Engine, Transmission & Driveline 0 04-17-2017 04:46 PM
Bad Compression 'MERICA MazdaSpeed 6 - Engine, Transmission & Driveline 14 08-08-2012 12:55 PM
Low compression MaverickX3 MazdaSpeed 6 - Engine, Transmission & Driveline 55 12-10-2010 04:41 PM
Page generated in 0.26698 seconds with 23 queries
