![]() Join Date: Sep 2012 Location: Buffalo ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score You check the connection to the app on the pedal? Tapatalking
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score you didn't notice that when you bought it?
__________________ it's fun to do bad things |
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score Does the car start? ![]() Have you driven the car since purchasing?
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
![]() Join Date: Mar 2012 Location: Woodbury, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 520
| Not Ranked : 0 score Is there a CEL? It could be the position sensor being all dumb like mine and putting it in doghouse mode. Basically you give it gas but RPM's raise veryyy slowly and don't go past 2k or so. Happens to me maybe once every 3 months. Basically to fix it: Disconnect battery.... wait 5 minutes.... reconnect battery... zoom zoom drive away Try that, assuming you didn't disconnect battery when you replaced the TB initially. |
(Thread Starter) | Not Ranked : 0 score Car was purchased through a auction. Car starts idles rough for about a minute then dies, while running its dumping a neighborhoods worth of smoke out the back. No gas response during any of this. Pedal is plugged in along with the tb. Brand new maf sensor. |
Groans: 136
| Not Ranked : 0 score Sounds like you bought a car without testing it out first, and you bought a car with a blown engine. Check compression and timing chain tautness. Tapadatass
__________________ |
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | Chimmike (11-15-2012), jack_hammer (11-15-2012) |
Groans: 549
also, if you pay up and become VIP, you will be opened to a world of knowledge that is well worth the cost of admission.
__________________ it's fun to do bad things | ||
(Thread Starter) | Not Ranked : 0 score Timing chain was tight. I'll do a compression test tonight. If the motor was bad what about the no gas response what so ever |
Groans: 433
| Not Ranked : 0 score before doing compression test, do piston height test via a screwdriver and cranking the motor by hand. If bent rod, you could throw thru the block just doing something like a compression test. Also, check for mods. Sounds like the car was heavily modded at one point, lol. check for vacuum leak/leak after the MAF.
![]() Join Date: Dec 2010 Location: Delanco, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 897
| Not Ranked : 0 score You never answered if you have any codes. You should.
__________________ [SIGPIC][/SIGPIC] ROB MS6GT 2006 Liquid Platinum Metallic Mazdaspeed 6 Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows |
(Thread Starter) | Not Ranked : 0 score Yea I have a cel. I don't have a scanner on hand. One of the codes was pedal possision sensor. |
| Robust Mongoloid ![]() Join Date: Aug 2009 Location: South Charlotte, NC
Rep Power: 6481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,137
Groans: 399
| Ok............ I'll be the one to say it. Are you sure you're stepping on the right pedal?? Lets just make sure we got that outta the way first.
__________________ ______________________ Built By NATOR Tons of Ricer Mods
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
Just curious but how much did you pay?
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors | |
| Not Ranked : 0 score Awesome ^^
| The Following User Says Thank You to KevMS6 For This Useful Post: | 09Speed3Z (11-16-2012) |
| The Following User Says Thank You to Stealthvr4 For This Useful Post: | kgb (10-08-2018) |
Groans: 399
| Your sarcasm detectors obviously need new batteries OP.......
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score Does the idle sound ok? I mean if your rods were so far gone you would be able to hear it. 1: Piston height check. The two outsides should match and the two insides should match. 2: all ok? Pressure test. What is normal? about 180 (ish) 3: Is there oil in the car? 4: How do the spark plugs look? 5: Is your intercooler missing a hose? ![]() 6: How do you know the code being thrown if you haven't got a reader to pull it?
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
| The Following User Says Thank You to jm211 For This Useful Post: | chuckms6 (11-16-2012) |
get a code reader and see whats up. the $120 harbor freight is perfect for what it is, i love mine. also check all of your fuses. engine bar fuses can cause weird symptoms if they are blown.
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() | |
| Not Ranked : 0 score Hmmm; Perhaps this could be your problem.
(Thread Starter) | Not Ranked : 0 score 2 codes 2119 & 2138. Car idles until gas pedal is pushed in, then traction light comes on with check engine and car dies. I'm gunna try swapping the electronic gas pedal out. |
![]() | | #24 | ![]() |
Tapatalking
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Check plumbing from PCV valve to intake manifold. Check all air lines out of IM are in good order. If the previous owner had a catch and removed it and did not add the OEM hoses back before it was impounded it could run the way you describe it.
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I cleared the codes instslled new" app". Same problem exists, car starts and revs at 1500k. when I tapped the gas before traction light came on and car died. Now traction light comes on but car stays running with no pedal response. Still running rich with black smoke. Any help greatly appreciated. Same 2 codes presist |
![]() | | #28 | ![]() |
Edit, I guess you have. I'm out of ideas. Tapatalking
![]() | | #29 | ![]() |
| Not Ranked : 0 score I'll buy it 2500$ cash. I suggest starting taking the simple stuff apart. (assuming ALL fuses checked) Since its not the TPS, maybe check the fuel line or in tank pump to make sure air isn't getting in. I don't fuckin' know.. ![]() Remove all intake, intercooler, inspect TB, EGR, hoses, Plugs, Do a piston height check, HPFP, was there a boost gauge installed?
![]() | | #30 | ![]() |
| Not Ranked : 0 score op try to find a scantool that does live data or an ap. at idle you should be around 14.7 afr, +-8 ltft, and -19inhg vacuum. if any of these numbers are off it will help direct you to your problem. also, try running it withough the maf plugged in and checking for air leaks. check your fuses with a test light as well.
![]() | | #31 | ![]() |
| Not Ranked : 0 score Might be time to start checking circuits and wiring too. Tapatalking
![]() | | #32 | ![]() |
![]() Join Date: Dec 2011 Location: Union OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Neutral : +1 score Go VIP and get the factory manual. On page 8,279 of 10 million there's a procedure in there for essentially resetting the TPS or actuator. I lost my throttle input after changing my starter, and following this did the trick. It's something along the lines of turn the key on for 10 minutes, off, run for some amount of time, blah, blah... EDIT: I had P2119, too.
__________________ 2007 MAZDASPEED3 GT MS SRI | CS TIP | JBR RMM | JBR RSB | CS Struts/Shocks | Whiteline ALK Last edited by tjamison; 12-05-2012 at 10:13 AM. |
| The Following 2 Users Say Thank You to tjamison For This Useful Post: | chuckms6 (12-05-2012), Stealthvr4 (12-05-2012) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score just for shits and giggles, post the VIN |
![]() | | #34 | ![]() |
Jm1gg12l561103263 Last edited by Stealthvr4; 12-05-2012 at 11:09 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Yeh, it looks to have some front and rear collision history, almost as if damaged before sale even. Vehicle salvage history: VIN number - JM1GG12L561103263 |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
![]() Join Date: Nov 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Did you ever solve this? |
| The Following 3 Users Say NO Thank You to Bluemica2373 For This Un-useful Post: |
![]() | | #38 | ![]() |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Do you realize that you are responding to a thread from 2012? And responding to OP who last posted anything here in January of 2015, over three years ago! Chances are very high that he has long since moved on. This is not what I would call an auspicious beginning. Maybe start a new thread if you are having a specific issue that we might help you with? Just a thought . . .
| The Following User Says Thank You to MSMS3 For This Useful Post: | monkey.bones.007 (10-09-2018) |
![]() | | #39 | ![]() |
![]() Join Date: May 2013 Location: CO
Rep Power: 2406 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
![]() Sent from my SM-N960U using Tapatalk | |
| The Following 2 Users Say Thank You to monkey.bones.007 For This Useful Post: | MSMS3 (10-10-2018), Thor Hammer (10-09-2018) |
![]() | | #40 | ![]() |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score ugh, why do these guys always look so familiar?
__________________ 94 M MS6 IS350 |
| The Following 2 Users Say Thank You to Pu Manchu For This Useful Post: | monkey.bones.007 (10-10-2018), MSMS3 (10-10-2018) |
| Terrible response with BNR S3! | EmPeEs6 | MazdaSpeed 3/6 - Big Turbo Builds | 17 | 07-16-2012 05:52 PM |
| In Response To An Allegation | Haltech | Automotive News | 1 | 09-28-2011 09:41 PM |
| Throttle response | MaverickX3 | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 06-28-2010 01:12 PM |
| Race Roots Response.. | Race Roots | Mazdaspeed3/6 General Discussion | 78 | 01-17-2010 08:43 AM |
| The HKS CORPORATE response to the HKS SSQ BOV | clown_car | MazdaSpeed 3/6 - Turbo Induction | 5 | 01-30-2009 09:02 PM |
