Like Tree7Likes
 Old 03-25-2013, 06:06 AM   #81
865ms3's Avatar
Posts: 2,602   (View Stats)
35k miles
ford fluid(recent to try to fix)
jbr fully mounted
jbr knob and bushing. no ssp
always noticed 2nd gear was slightly notchy. over the past couple weeks it has gotten worse. i changed to ford fluid and it didnt help.
its gotten worse of the past couple of weeks. low rpm shifts its starting to grind. no pop out yet. i had a few pop outs at an autocross...but as soon as i took my jbr knob off it stopped. im assuming it was from the weight of the knob under hard braking.
i plan to bring it to mazda this week sometime and see what happens.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
 Old 03-25-2013, 10:04 AM   #82
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
fork pads and or syncro probly worn
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
865ms3 (03-25-2013)
 Old 03-25-2013, 11:18 AM   #83
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
86K miles
I beat that tranny bitch like she owed me $5 and I needed it to buy some crack. Now she won't stay in 2nd gear on throttle lift.
phate (03-25-2013)
 Old 03-25-2013, 03:57 PM   #84
RallySportDirect's Avatar
Posts: 1,452   (View Stats)
This is a very interesting thread to read. The last couple of days I thought mine was a bit too notchy from first to second. I am going to have to keep an eye on things, hopefully this isn't an issue because I've only just hit over 700 miles on the car.
Tanner
 Old 03-25-2013, 05:31 PM   #85
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
Tanner
Change your gear lube early before you have issues.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
The Following User Says Thank You to ibcrusn For This Useful Post:
RallySportDirect (03-25-2013)
 Old 03-25-2013, 05:47 PM   #86
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
My car grinded 2nd ever since I've had it. Started to happen more so called dealer and scheduled it for same day I did my 35k service they said they would "check it out". When I went to pick my car up the guy said they test drove it and it was fine. They did fomoco fluid and that's it. Got 45k miles now and modded much more since then so don't even bother with dealer. I'm fully JBR mounted I had RMM and just did PMM and TMM yesterday and shifting couldn't feel any more solid. No grinding as of now, JBR ftmfw!
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
 Old 04-04-2013, 07:19 PM   #87
Hatchbackfan's Avatar
Posts: 161   (View Stats)
Hatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the worldHatchbackfan is the leader of the world
2012 ms3
I had the 2nd gear pop out issue at 16xxx miles I was partly bolted took all the mods off my car went to the dealership not to bad of a fight and 2 weeks later they told be they replaced the 1st and 2nd gear syncros as well as the fork. Got the car back after about a week 3rd gear begin grinding 2 mts later pop out issue there took it to Mazda they wouldn't cover it under warrenty quoted me 4 grand to fix 3rd gear. Long story short looked on eBay found a junkyard selling a tranny out of a totaled speed with 3k miles on it bought shipped installed by local shop for $1500 total driven last 12k miles on no issues.
Hatchbackfan is offline   Reply With Quote
 Old 04-06-2013, 06:15 PM   #88
mazspeedshiz's Avatar
Posts: 153   (View Stats)
mazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond reputemazspeedshiz has a reputation beyond repute
This may sound really stupid but could short shift plates have an effect? My 3rd gear had the popping out issue and it was a bad fork which wore down the synchros around it. I had bought the car used and didn't know it had a twm stage 2 already ( I've never driven a speed before so I didn't know the throw length) I found the twm during a shifter adjustment and after a sure shortcut install. I said to myself this can't be right at first. My throw from first to second was literally so short it threw me off. Second wouldn't engage at all unless you pulled hard on it. Regardless I feel like these plates without the right adjustments could be giving the tranny a hard time, acting almost as if we have our hands resting on the shifter in gear (every stick owner should now not to rest your hand on the shifter in gear as it wears down the nylon pads on the fork) which eventually causes misengage/grind on the synchro. Anyways my theory is that adjustments need to made, even from stock to make sure 2nd and 3rd have a good engage.
mazspeedshiz is offline   Reply With Quote
The Following User Says Thank You to mazspeedshiz For This Useful Post:
MS3CB (09-10-2013)
 Old 04-06-2013, 06:57 PM   #89
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
I'm pretty fucking sure the dealer won't warranty shit with another fluid in there.... Unless stated all dealers recognize FoMoCo fluid as being a good alternative
 Old 04-09-2013, 11:37 AM   #90
cghms3's Avatar
Posts: 82   (View Stats)
cghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant futurecghms3 has a brilliant future
My 09 speed 3 would not shift into 2nd when cold going around a corner. I would pull over, and start over, and gently shift into 2nd, and it worked. Problem would not happen all the time - I never go (well, almost never) go wot in 1st, but do go wot 2nd - 6th. I always use the "fingertip shift" method, never forcing it into gear. I also rev match when I downshift from any gear, and I never downshift into 1st, my thinking is it puts too much of a load on the trans. Anyway, I got the TWM full replacement linkage, and switched to Redline trans fluid, and now it never has a problem getting into 2nd, especially when cold and going around a corner. The shifts are more mechanical and deliberate, so no fast shifting, but I never did even before the mods. One thing I did notice though (before and after mods) is that when shifting from 1st to 2nd,I have to pull it slightly to the left, and shifting from 5th to 6th, I have to pull it slightly to the right - anyone else notice that? anyway, no grinds/pop outs
cghms3 is offline   Reply With Quote
 Old 04-19-2013, 01:27 PM   #91
PL ENDO's Avatar
Posts: 883   (View Stats)
PL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the worldPL ENDO is the leader of the world
Groaned at 31 Times in 12 Posts
car:2012
mileage: Purchased 254 problem started 8670
How it happened/progressed: down shift and it was popping out once in a blue and got worse
When it happened ie down/upshifting: now wont go into 2 at all
Stock? or what mods? corksport dp back, custom front mount, cobb TIP/SRI, sonic coil over, sure street PMM/TMM sure race RMM
Using FoMoCo fluid?: stock
Was it covered/repaired: they will not cover under warranty
Did it happen again?: Remains to be seen
currently fighting to get fixed under warranty BBB claim filed will be using this thread to help show defective transmission parts
PL ENDO is offline   Reply With Quote
The Following User Says Thank You to PL ENDO For This Useful Post:
Payne Racing 67 (04-19-2013)
 Old 04-19-2013, 01:41 PM   #92
PL ENDO's Avatar
Originally Posted by Payne Racing 67 View Post
Well, the dreaded 2nd gear popout/grind is a well known issue for our platform. I'm currently in the process of getting mine fixed(and fighting Mazda for my warranty). It aggrivates me immensely to know that it's such an issue, has happened to multiple cars, and not only do they not fix the issue at production, they give many of us an issue as far as covering it. I've decided to start an official thread on this and see if we can get somewhere with it. Also, in the case of mods/waranties, there are 2 laws: The Lemon Law: Lemon Law Statutes, Brochures, and Fact Sheets As well as the Magnuson-Moss Act, which basically states that a dealer/car corporation cannot deny warranty work based solely on the fact that you have aftermarket parts. They have to actually physically be able to prove the mods caused your issue/failure.
So what I want is:
Year/Model(speed3/6)
Mileage 2nd gear started acting up/went
Stock? or what mods? Shifter parts ie sts, knob, etc.
Using FoMoCo fluid?
I need anyone who's ever had an issue to post.
2010 Mazdaspeed3
10,500 Miles
Went to downshift to 2nd gear, in a parking lot and it popped out when I let the clutch out. It progressed from there throughout 2 days, to finally not going in at all on an up/downshift
At the time I had intake, blowoff valve, Cobb Accessport, Full Exhaust, full motor mounts, Stage 2 tune
It was covered, and they replaced the trans.
Now, at 35,000 miles the issue has happened again.
Pretty much the exact same situation but at a slower pace. @Raider; would you mind helping me with this? Maybe make it a sticky if you think we should?
@dantes5823; @amggilly305; @NJSPEED3; @TWOptSL0W; @ArcticSpeed3; @bf360; @rigor; @Blck350z; @MS3-a(sore)ASS-rex; @johnheer; @kramer; @JimmyMac; @occschemguy; @MS6 Alan; @clos561; @06Speed6; @mazspeedshiz; @Captain KR; @kteevan;
ok i want everyone in this thread and had this problem that has had it taken care of and not come together. i see this is a problem that Mazda is aware of but has yet to fix this by upgrading the Teflon on the fork to aluminum or brass something better. ppl talked about lawyering up to get the M-M act to help well if we can get all of us together with proof of all these failing forks we would have a better case. not only that but lawyer cost can be split up between everyone and included in the law suit to have a recall on the trans to replace the faulty forks. what you think?
nybe0010 (04-19-2013)
 Old 04-19-2013, 01:59 PM   #93
nybe0010's Avatar
New thread I saw today there are brass pads on forks but you have to buy the whole thing they won't put them on used forks. I am confident I have this same issue but dealer test drove my car and said it was fine. They babied it obviously but during higher rpm I have problems in 2nd and 3rd. With the mods in my sig would they tell me to get lost if I tried to warranty it for the 2nd time? First time all they did was the fomoco. Mazda needs to do something about this!
 Old 04-19-2013, 02:26 PM   #94
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Payne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the world
Groaned at 64 Times in 49 Posts
That was my purpose for making this thread. Also, my uncle is a lawyer and may be able to help. On top of that, @SPEED6 KILLAH; may be able to help being the Mazda master he is.
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
The Following User Says Thank You to Payne Racing 67 For This Useful Post:
SLOWHATCH (04-19-2013)
 Old 04-19-2013, 05:05 PM   #95
PL ENDO's Avatar
i seen that 12 min after it was posted and sent the guy a email to find out more about the brass insert if brass or aluminum would be better since it looks like any machine shop can do this. but thanks for the info.
 Old 04-19-2013, 05:12 PM   #96
PL ENDO's Avatar
i made a thread in the transmission gen2 area but no one posted anything useful other then i should have stocked out. yet the only power adder was the dp and its not much it still is catted and the dealership actually told me the mods i had on the car was not the ones that cause this problem so i should be good. they took pictures of the car and told me to comeback tomorrow and it will be taken care off then 3 hours later they said warranty is voided and im SOL and would have to pay for any repairs or them to look at the transmission. worst part is corporate Mazda said if i can get another dealership to look at the car and them to support me and say my mods did not cause the problem they may reinstate my warranty and fix the trans.
i should buy a new trans and just have them pay for the fix rather then them fixing it so i can install the new brass forks
 Old 04-19-2013, 05:27 PM   #97
phahengpro's Avatar
Posts: 351   (View Stats)
phahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the world
My second gear is rough, at times, after taking off the oem (at about 50,000mi) weight and installing the lighter Cobb weight. It will grind a little at times. I figured it was because of the lighter weight. I don't have any popping out of gear yet.
cheeeoooo likes this.
MS3 traded in after VVT eruption
2013 WRX - no mods and slower
phahengpro is offline   Reply With Quote
The Following User Says Thank You to phahengpro For This Useful Post:
 Old 04-19-2013, 06:22 PM   #98
nybe0010's Avatar
I was wondering same thing I'm gonna play around with SSP and weight try some different things out as well as the "fine tune" of the shifter.
 Old 04-22-2013, 04:00 AM   #99
jm211's Avatar
Posts: 943   (View Stats)
Most users have issues in complete stock form and only then resort to plates, new fluid, shift weight or knob changes. Mazda definitely screwed something up and it hasn't been fixed since 2006.
Try adjusting the shifter cable a little bit.
I gave myself perfectly tight engagement on 1-4 and more wiggle on 5-6. Has been working nicely. That coupled with the mods in my sig and fingertip shifting into second, I haven't had ANY issues. Will be moving to motorcraft in the next few months after I move.
 Old 04-22-2013, 08:57 AM   #100
Its all in the shift fork/pads. Theyre cheap and garbage. Between the forks bending/breaking, and the shit teflon shift pads that wear down way too fast, even under normal driving conditions. That eventually kills the synchro, and from there, the gear
Sent from your moms phone
 Old 04-22-2013, 02:32 PM   #101
jm211's Avatar
Hey Corksport and JBR,
Take my money and make or sublet out quality transmission parts for genwon and 2 plus the 6!
The Following User Says Thank You to jm211 For This Useful Post:
Payne Racing 67 (04-24-2013)
 Old 04-24-2013, 07:55 PM   #102
meltdown100's Avatar
Posts: 113   (View Stats)
meltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond reputemeltdown100 has a reputation beyond repute
Damnit. I've noticed the shitty grinding shifts also going into 2nd, but was under the impression from earlier threads that out 'rock crusher' tranny would make a lot of noise and feel like shit but take all kinds of abuse and hold up fine. Does it to me mostly when cold, at low speed ~20mph or so. Glad I know better now, gonna have to start double-clutching and finger tipping the bitch into 2nd.
2012 MS3, with 7000 miles
Stock trans fluid
JBR heavy knob and SSP
2012 Silver Pu
AP, AT FP Internals, CS SRI & TIP, JBR 70 RMM, JBR SSP.
Old rides:
2004 SVT Focus (no mods)
1970 Dodge Coronet (worked 440 Magnum, 12.1sec 1/4 mile at Atco Raceway on shit tires)
meltdown100 is offline   Reply With Quote
 Old 04-24-2013, 08:01 PM   #103
jm211's Avatar
I always find that heavy(ish) throttle to 3,000 RPM and finger tip slide into second at a certain angle (angle as in that side to side play we have on the shifter gates) gets it in like butter.
 Old 04-25-2013, 01:16 PM   #104
tjamison's Avatar
Posts: 187   (View Stats)
tjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond repute
Default New tranny? Uhm, okay.
2007 MS3
59,000 Miles
Switched to FoMoCo fluid ~300 miles ago
Took car in for an alignment, asked if they would take note of any grinding into 2nd gear. It will grind when cold.
I just got a call saying they are going to replace the entire tranny and it should be covered under my aftermarket warranty. Sweet.
TL;DR - Took car in for alignment & they are replacing my tranny for free. Sweet.
Should I send them a new clutch to throw in while they're at it? OEM, of course.
2007 MAZDASPEED3 GT
MS SRI | CS TIP | JBR RMM | JBR RSB | CS Struts/Shocks | Whiteline ALK
tjamison is offline   Reply With Quote
 Old 04-25-2013, 02:12 PM   #105
dubtastic's Avatar
Posts: 204   (View Stats)
dubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond repute
Groaned at 44 Times in 13 Posts
as the owner of a 2013 this is very worrisome! Do the majority of these occurances take place on modified cars?
dubtastic is offline   Reply With Quote
 Old 04-25-2013, 02:30 PM   #106
tjamison's Avatar
They happen more often on stock vehicles.
You'd better start modding.
2007 MAZDASPEED3 GT
 Old 04-25-2013, 03:43 PM   #107
dubtastic's Avatar
wow, its like a vicious cycle, if you mod they will cite that as the issue, if you dont its going to happen either way...?
How about build dates and vin#'s would that help in narrowing down certain aspects of the fault? Maybe isolating dates... just an idea
The Following User Says Thank You to dubtastic For This Useful Post:
Payne Racing 67 (04-27-2013)
 Old 04-25-2013, 03:59 PM   #108
jm211's Avatar
Seems to happen to every year and both the 6 and 3.
Like others have said the forks and the nylon pads suck.
Get some ford juice and don't rest your hand on the shifter.
 Old 04-28-2013, 09:39 AM   #109
tjamison's Avatar
2007 MAZDASPEED3 GT
 Old 07-18-2013, 06:20 PM   #110
xecuter2's Avatar
Posts: 100   (View Stats)
xecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to beholdxecuter2 is a splendid one to behold
My car is pretty much brand new but I have noticed when down shifting into 2nd I have to be under 30mph for it to engage smoothly without slight grinding/resistance. Even stock it was hard to get into 2nd and I never really tried to shift to it above 30 before my SSP. I can be going 40 and clutch it to the floor and all gears go in smooth except 2nd? as soon as I am under 30 it goes in just fine with no resistance or grinding. This thread is scaring me, maybe I should take off my SSP to see if it changes anything I am not very hard on the car, downshift properly and only apply power when fully in gears.
2013 white PU - | CP-E Down Pipe | CX FMIC | COBB SRI/AP V2 | HTP TIP | AutoTech HPFP Internals | CS OCC/BPV | Denso ITV22/NGK LTR7IX-11 | JBR Bushings/Weight/Knob/TBCBypass/RSB/88a RMM/88a TMM| RichTuned FTW
307/313 Dynocom dyno @ 88f
xecuter2 is offline   Reply With Quote
 Old 07-18-2013, 07:06 PM   #111
load's Avatar
Posts: 410   (View Stats)
load is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the world
Groaned at 9 Times in 3 Posts
This is interesting as I absolutely cannot go into 1st if I am over 5-10 mph, it whines and resists like crazy. I can get into all other gears no matter what speed the car is going.
2013 Black Mica | Freektuned | JBR Power Path Stage II Intake | CS Race Pipe | CS Top Mount Intercooler | Autotechs | CP-E Stage1 RMM | Resonator Delete | Ultimate Racing Muffler
load is offline   Reply With Quote
 Old 07-18-2013, 08:03 PM   #112
JesseFrye's Avatar
Posts: 48   (View Stats)
JesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the worldJesseFrye is the leader of the world
09 58.5k miles
Been grinding while going into 2nd for the past 2 weeks, thought it was all me until it popped out of 2nd twice yesterday and three times today. Even though i'm pissed it actually happened to me, i'm glad it happened while I was under warranty (barely). Time to stock up and take her in.
2009 True Red Mazdaspeed 3
CS SRI | CS TIP | CS SSP | CP-E Stage II RMM |JBR Solid Shifter Bushings | JBR Boost Tubes + Recirc Hose | Tri-Point Engineering RSB | Koni FSD |
JesseFrye is offline   Reply With Quote
 Old 07-18-2013, 08:34 PM   #113
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
The car is trying to tell you something. You shouldn't be pushing into 1st until your damn near stopped.
 Old 07-18-2013, 08:44 PM   #114
JesseFrye's Avatar
What he said^. That's a big no-no
 Old 07-18-2013, 09:33 PM   #115
xecuter2's Avatar
I never go into 1st until stopped pretty much. I can't go into 2nd until under 30 but it did that stock as well now that I can remember. I slow down for my road and basically wait until it goes in nice and easy. Not really reassuring since other people say they can shift to 2nd while going any speed with the clutch in.
Sent from my AOSP DOODLE 2
 Old 07-19-2013, 02:42 PM   #116
load's Avatar
I only tried it once to see if I could.
 Old 08-04-2013, 06:08 PM   #117
xecuter2's Avatar
Reviving this BITCH! Removed the SSP just to see and am really happy with the feel of the car with just the weight and bushings. I can go into 2nd now at any speed though it is a little notchy still above 30, with 0 grinding no matter what. I am going to go amsoil gear oil and maybe grab the other 2 JBR mounts? I assume this is normal as a lot of others with newer cars have issues with 2nd. 5500 miles now and the car is perfect, no need to change anything for a little while until RSB/springs/mounts/BPV bug bites.
 Old 08-04-2013, 11:16 PM   #118
TSlop's Avatar
Posts: 16   (View Stats)
TSlop is a jewel in the roughTSlop is a jewel in the roughTSlop is a jewel in the roughTSlop is a jewel in the rough
Since this got revived I thought I'd chime in:
2007 speed3 and just hit 60k miles last week. Zero issues. No grinding except the extremely rare clutch slip, and never popped out of gear. Owned since new.
TSlop is offline   Reply With Quote
The Following User Says NO Thank You to TSlop For This Un-useful Post:
jm211 (09-07-2013)
 Old 08-05-2013, 02:09 AM   #119
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Say Chi Sin Lo has disabled reputation
I took off my SSP too after a week. My car did not like it one bit. 1st-3rd took Olympic strength, and on top of that, going into gear would be accompanied by the most horrible sounding *THUD!* or *BANG!*.
Maybe I'm justifying my the removal, but I didn't like the click-like shifts (was never sure I was in gear or not). I enjoyed having to actually "throw" it into gear. Besides, the shifts with the short shifter are short enough for me.
xecuter2 likes this.
Say Chi Sin Lo is offline   Reply With Quote
The Following User Says Thank You to Say Chi Sin Lo For This Useful Post:
MS3CB (09-10-2013)
 Old 08-05-2013, 04:16 AM   #120
Tha semaj's Avatar
Posts: 1   (View Stats)
Tha semaj is an unknown quantity at this point
Originally Posted by Mfinlay04 View Post
I've only ever driven my Mazdaspeed so IDK if im experiencing the same issue but I do get a second gear grind occasionally.
110k
Royal Purple MTF
I haven't had it pop out on me, but I did find that if i change the pressure on the shifter I can get it to shift without grinding pretty consistently. If I press to hard to the left when shifting from 1st to 2nd I get crazy grind, 50% wont even go into the gear and is a SOB. I've found by allowing it to be in a neutral position from first to second, I shift with just my pointer and middle finger I get a butter smooth shift. Seems like my alignment is off, if that makes sense. I saw a thread that someone posted about fine tuning the shift knob, i might give this a try and see if that improves the shifting quality.
Basically same here. Haven't experienced the gear popping out but I get crazy grind going into second when pushing hard, like 80% of the time. Haven't tried switching up how to put it into second though like you have. Second usually behaves when driving normal, it's only happened a handful of times like this. I also saw a video about what you're talking about and was thinking the same. Let me know how it turns out for you.
2010 Speed 3
50k
fomoco
bought used @ 15k with cs sri, cs tip, cat delete 3' magnaflow.
Just rolling with it for now.
Tha semaj is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-2nd-gear-dead-thread-134845/
Thoughts on a speed6 : cars This thread Refback 11-17-2014 08:02 PM
Is this a good deal? : cars This thread Refback 05-30-2014 02:35 PM
06/07 mazdaspeed 6 or 2013/14 mazda 6? : cars This thread Refback 04-18-2014 03:25 PM
[NSW] Potential future MPS owner - Common faults? This thread Refback 07-28-2013 10:20 PM
Transmission / clutch help This thread Refback 04-10-2013 09:26 PM
Forum Mazda Performance Series - Zobacz temat - Biegi - hacz?ce/blokuj?ce/ci??ko wchodz?ce/zgrzytaj?ce... This thread Refback 01-26-2013 04:36 AM
Official: "High Gear" Mustang chosen to be SEMA's first all-female build [w/video] Haltech Automotive News 0 06-06-2012 03:50 PM
Page generated in 0.59932 seconds with 43 queries
