Like Tree41Likes
 Old 01-13-2012, 06:47 PM   #1
BobbleHead's Avatar
Posts: 2,237   (View Stats)
Groans: 186
@Raider
thanks for checking. I don't have VVT rattle on cold starts but occasionally I have smoke from my exhaust. Although it hasn't since i got my AP.
 Old 01-13-2012, 07:35 PM   #2
RidenDirty's Avatar
Posts: 58   (View Stats)
RidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to beholdRidenDirty is a splendid one to behold
So excited about this cause I dont have to come out of pocket the $1k I was told it would cost me and I get a new turbo too....double win!!! And all this because Mazda is too cheap to put in a $5 tensioner in the design.
Originally Posted by black07spd View Post
@Raider
Take your oil cap off and reach in and see if your timing chain is loose..thats how we found mine, I dont have noise yet but the chain is noticeably loose it could start making noises at any time.
RidenDirty is offline   Reply With Quote
The Following User Says Thank You to RidenDirty For This Useful Post:
BobbleHead (01-13-2012)
 Old 01-18-2012, 05:33 AM   #3
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
What's this 5 dollar tensioner of which you speak?
And checking the chain for slack needs to be done with the engine at operating temp.
The chain tensioner is oil pressure actuated.
No oil pressure, no tension.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 6 Users Say Thank You to Tokay444 For This Useful Post:
ak_spray (07-29-2012), Juyoung (12-19-2012), KevMS6 (04-20-2012), Kris Speed3 CWP (01-27-2012), Raider (01-18-2012), Tomas (01-20-2012)
 Old 01-18-2012, 05:58 AM   #4
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Groaned at 16 Times in 7 Posts
Got one of you freeloaders in my bay right now.
It's so obvious when you guys stock out. You leave things loose...bolts have markings on them that indicate they have been tampered with...Mode 6 data in the PCM isnt filled, incomplete monitor flags..
Not that I give a shit because I'm making my 4 hours either way.
It's just funny, the stories people come up with to protect their warranty coverage.
He might be talking about a little chain guide that most engines have between the cam gears. One could easily be bolted to the oil control valve and keep the timing chain from slapping the valve cover.
sidekick likes this.
timjs is offline   Reply With Quote
The Following 7 Users Say Thank You to timjs For This Useful Post:
laxplayermjd (01-18-2012), memin (01-20-2012), pipe (01-22-2012), sidekick (12-25-2013), Teethkikr (01-22-2012), thehead (02-12-2012), TheProYodler (01-29-2016)
 Old 01-18-2012, 06:05 AM   #5
My issue is that this chain problem happens stock or modded, and really needs to have a longer coverage period, as most have surpassed that extension. Obviously Mazda knows this, and is just making sure that they do not have to cover the majority of the cars.
edmsmallcash likes this.
 Old 02-29-2012, 07:38 PM   #6
CurrentlyPissed's Avatar
Posts: 26   (View Stats)
CurrentlyPissed is a glorious beacon of lightCurrentlyPissed is a glorious beacon of lightCurrentlyPissed is a glorious beacon of lightCurrentlyPissed is a glorious beacon of lightCurrentlyPissed is a glorious beacon of lightCurrentlyPissed is a glorious beacon of light
It's funny that people even stock out. Most dealerships have no problem turning a blind eye towards most mods. They want the freebie work to hit their gross labor. They could give two shits less. An inspector is not going to come out especially over a car with a recently updated warranty extension. They have more important things to do. (I service write for a Nissan Dealership)
CurrentlyPissed is offline   Reply With Quote
The Following User Says NO Thank You to CurrentlyPissed For This Un-useful Post:
kunfu (05-06-2012)
 Old 02-29-2012, 09:12 PM   #7
timjs's Avatar
I've found that it seems to depend on the workload the dealership normally sees.
No body wants to do warranty work when there is customer pay work to do.
As you know, (and most people do NOT know) is that warranty pays so little, it's borderline criminal.
Technicians are still forced to be paid by the same ancient method that was designed long ago, and made sense when the auto industry had plenty of work.
Now, cars are so fucking reliable, there's no work. Our shop had 13 mechanics back in the mid 90's (from what the old timers have told me) and now the shop BARELY supports 3. Shit, I sat around for 5 hours today not making a single dime before I went home early.
Sorry for ranting, but you get my point. Take your car to a busy shop that would rather do 30k's and used car inspections instead of warranty, and they will screw you over modifications. Take your car to a smaller dealer that doesn't have the work volume of the larger dealer, and they will happily take the 4+ hours of work to replace your timing chain.. it's that simple. Technicians only get paid while they are working, so ANY work is better then NO work.
With that said, I'd rather do oil changes all fucking day than do another timing chain. I'm sick of them.
 Old 02-29-2012, 11:32 PM   #8
What is the warranty time/actual time for the MS3 chains?
 Old 01-18-2012, 05:59 AM   #9
Actually, the VVT comes out of adjustment, causing the problem. It is not just a loose chain issue.
And for anyone over 70K, you are SOL, period. Got it fixed or reported before then to the dealer? You have a chance. Otherwise...
 Old 01-18-2012, 06:16 AM   #10
tjamison's Avatar
Posts: 187   (View Stats)
tjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond repute
I'm going to get my 07 MS3 to the local (45 minutes away) Mazda dealer early next week. The VVT is obvious, but I hope they don't give me too much hassle on the smoke - It's not as bad as some I've seen, but worse than most. I bought the car a month ago, so I don't have a stack of service receipts. I'm interested if they'll give it the ventilation kit or turbo. Funny that I got an aftermarket warranty, but won't even have to use it on these major items. I'm sure something worthy will come up in the next 45K miles.
tjamison is offline   Reply With Quote
 Old 01-20-2012, 08:34 PM   #11
All2envyMS3's Avatar
Posts: 151   (View Stats)
All2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond reputeAll2envyMS3 has a reputation beyond repute
I'm in the same boat...(extended warrenty 50 deductible) I have had that loud start up noise just like in the vid posted. And my turbo has smoked every now and again since oct.
Question, Got the car may of last year with 45k miles on it. Changed the oil at 49k with a receipt. then at 54k miles I did a oil change my friends house, with the required oil weight. Rotella 5-40
Will they hassle me for not being able to prove that oil change?
2008.5 MGM MS3 GT
Last edited by All2envyMS3; 01-20-2012 at 08:38 PM. Reason: I'm an idiot who doesnt proof read
All2envyMS3 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-warranty-extension-program-turbo-vvt-actuator-102153/
Ïðîáëåìû Mazda6 MPS - Óêðàèíñêèé Ìàçäà Êëóá :: MazdaClub.UA This thread Refback 06-28-2015 12:11 AM
Just got this 09' MS3. 64k Has a few mods. Am in love. : mazda This thread Refback 04-22-2015 01:52 PM
Mazdaspeed3 Owners! A little insight please. : mazdaspeed3 This thread Refback 04-08-2015 11:27 AM
Mazdaspeed3 Owners! A little insight please. : mazdaspeed3 This thread Refback 03-30-2015 06:29 PM
Mazda 3's are often suggested for their price, performance, and cheaper upkeep. What about an '07 Mazdaspeed3 GT? : whatcarshouldIbuy This thread Refback 07-29-2014 04:13 PM
Finally got myself a Speed6! - Page 4 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-12-2014 11:12 AM
What does /r/mazda think is a good price to pay for this car? : mazda This thread Refback 02-05-2014 12:03 AM
Cumberland Motor Club ? View topic - Sudden Power loss This thread Refback 02-04-2014 07:37 AM
VVT issues This thread Refback 11-15-2013 06:15 AM
Mazda 6 MPS/Mazdaspeed6: èçâåñòíûå ïðîáëåìû - Ñòðàíèöà 7 - MAZDA Club Belarus - Áåëîðóññêèé Êëóá MAZDA - Ôîðóì This thread Refback 11-03-2013 12:07 PM
Noob guide to Preventative Maintenance and Modding - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-27-2013 04:30 PM
vvt actuator and turbo warranty extensions ? Mazda MPS Owners Club This thread Refback 05-11-2013 02:14 PM
Ticking in the engine bay - need help!!! - Page 5 This thread Pingback 04-27-2013 06:32 AM
Mazda6 MPS - :: MazdaClub.UA This thread Refback 10-31-2012 03:13 AM
Car being diagnosed tomorrow This thread Refback 09-29-2012 06:20 PM
Mazda MPS Owners Club • View topic - vvt actuator and turbo warranty extensions This thread Refback 09-01-2012 09:03 AM
Rattle noise when engine is cold This thread Refback 08-14-2012 12:58 AM
Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum - View Single Post - New Member This thread Refback 06-04-2012 11:17 AM
MAZDA Club Belarus - MAZDA - - - Mazda 6 MPS/Mazdaspeed6: This thread Refback 05-19-2012 01:44 AM
Google INTERIA.PL - szukaj: wt actuator mazda engine This thread Refback 03-26-2012 11:13 AM
Mazda 6 MPS 300+ HP This thread Refback 03-12-2012 11:12 AM
Long time, no cobra :( - SVTPerformance This thread Refback 02-13-2012 12:39 PM
Mazda6 MPS - :: Mazdalub.UA This thread Refback 01-24-2012 11:27 PM
Mazda 6 MPS/Mazdaspeed6: - 7 - MAZDA Club Belarus - MAZDA - This thread Refback 01-24-2012 01:55 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 01-23-2012 08:04 AM
VVT Warranty Extension Program notice from Mazda - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-20-2012 09:02 AM
New Member - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-19-2012 09:38 AM
Another Smoking Turbo - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-17-2012 09:41 AM
Blocked Wastegate Actuator hose to Turbo inlet supersswa MazdaSpeed 3/6 - Turbo Induction 1 01-07-2012 01:05 PM
atp turbo pricing question, lines and actuator cost 300$?! leo766 MazdaSpeed 3/6 - Big Turbo Builds 32 11-08-2010 11:30 PM
GS EBCS with a stock turbo/actuator 06Speed6 MazdaSpeed 3/6 - ECU Computer Tuning 1 05-27-2010 07:49 PM
Government ends warranty program for GM, Chrysler Haltech Automotive News 0 07-21-2009 10:20 AM
Page generated in 0.55661 seconds with 29 queries
