 Old 01-21-2015, 11:47 AM   #1
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
Default Oil Consumption
So hopefully I'm not crucified for this. After a couple hours of searching, I just couldn't find what I was after. Most oil consumption thread on here talk about insane amounts. Like a quart every 1,500 miles. Yikes. That would drive me crazy. On my GenPu I never bothered to watch it super closely. (I had a warranty and knew I wouldn't be keeping it forever) But on my Speed6 I am over the top on my maintenance and level of ocd. I had run Rotella T6 with OEM filter since I bought it over a year ago. I never saw any consumption. Always at the full line or really close. After Russ's thread about valves getting dirtier faster from the T6, on my last oil change I switched to Pennzoil Ultra Platinum 5w-30 still OEM filter. I'm at 2,700 miles on this oil. I change at 3,000. I have noticed I'm about 1/3rd down from the top dipstick notch so that's about a 3rd of a quart right? Has anyone else noticed this? Anyone else made the switch like this with similar results? I find it odd. PP and T6 get such good/close UOA's that I did not expect this.
Now before anyone jumps my shit about where the oil could be going...my car is up to date on all maintenance including a new turbo.... In the last 8K miles it got a new KO4 directly from Mazda before my Certified Pre-Owned warranty expired, new PCV Valve, JBR Stage 2 OCC, cleaned, intake, valves, TB, etc, etc. If a full list is need I will give one but I think those are the important ones, oh and compression is even across the board. It's not high consumption so I don't thing it's the rings.
If you actually read a'll of that, thanks! I know I can and probably will just switch back to T6 butI figured I can't be the only one.
2007 MS6 GT:
HTP 3" Full Intake, CS TMIC, AutoTech Internals, APv3, Forge Version 2 BPV(Blue+1 Shim), CP-E Catted DP, Whiteline RSB, CP-E Rear Diff mount, CP-E RMM, CS transmission mount insert, JBR Stage 2 OCC, JBR Boost tubes and recirc hose, Bilsteins B6's all around, Techna-Fit SS clutch and brake lines with ATE fluid, FreekTuned!
Big Dog is offline   Reply With Quote
Massive oil consumption Mandinca MazdaSpeed 6 - Engine, Transmission & Driveline 136 02-01-2017 03:41 PM
Oil consumption Neubreed MazdaSpeed 3 - Engine, Transmission & Driveline 72 07-01-2014 11:21 PM
oil consumption?? MS6Blaze MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 02-13-2014 07:19 PM
Your Meth Consumption drummerboy1864 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 52 05-08-2013 04:29 PM
Fuel consumption? tokoam MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 17 01-06-2013 07:19 PM
Page generated in 0.22455 seconds with 20 queries
