![]() Join Date: Aug 2017
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score About 6 months, several symptoms started occurring: -Oil consumption of about 1 qt/1000 mi -Noisy chatter on start, disappears after 1 second -Occasional hard starts with warm engine -Occasional misfire MIL Otherwise, the car runs great. No noticeable loss of power, acceleration, etc. At the safety inspection, the shop removed the intercooler, and found no pooled oil, very little play in turbo shaft. Plugs in cylinders 3 and 4 were oil fouled (all 4 plugs were changed about 30k miles ago). The mechanic thinks its failing piston rings and recommended using 5W-40 for now. I trust him, but I would love the community's very knowledgeable (which I have lurked for many years daydreaming about upgrades) input. Any chance this could be a valve problem? |
![]() Join Date: May 2016
Rep Power: 53 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Noisy chatter is most likely the timing chain tensioner. Open the oil fill cap and you can check it. It should be taunt if it was just running or running recently. Do you have a boost gauge? How much vaccum does it pull at idle? It should be 20inHg. I had a vacuum leak and it would have a random misfire at idle and be hard to start when warm. If you have a Cobb AP you can up the idle and see if that helps, it did for me but eventually it went away by itself in my case. I'm curious about your oil consumption myself. I'm going through a quart every 250 miles but no problems other than that (no fouled plugs or misfires) Sent from my XT1565 using Tapatalk |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score Yeah but at that rate you have got to be part of Club Blue Smoke Screen.
| Not Ranked : 0 score |
![]() Join Date: Sep 2016 Location: Georgia
Rep Power: 49 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Well, I have to tell you, I don't think the cats mask the smoke at least not the amount you think. I have has the same problem with no noticeable smoke and running a downpipe. I would do a compression test and check for leaks. If you are running fine and the power is good, I would suspect oil control rings. I agree with the other poster on the chatter, could be the chain. Check it, if it is the problem have it fixed |
![]() Join Date: Sep 2015 Location: Canada, Ontario, Toronto
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
| Not Ranked : 0 score compression and leak down test if those are good, I'd suspect the Turbo is starting to Blow through oil chatter in the morning is most likely VVT hop on it before it cause more damage
__________________ 2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers |
(Thread Starter) | Not Ranked : 0 score Thanks for the replies. I will double chain the chain; I poked it once and it was tight, but I don't remember if the engine was warm or cold. I will plan to do the compression and leak down tests. Hopefully the rings pass the test. It could still be a turbo, even if minimal oil was found and little/no shaft play? |
(Thread Starter) | Not Ranked : 0 score To fix the VVT, you need to completely disassemble timing chain? Looks like a big job, right? |
![]() Join Date: Aug 2008 Location: Kenosha, WI
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score A shot PCV will cause oil consumption too. It's cheap but in a pain in the ass location on these cars. Some say you can swap it from below, but I pulled the IM to do mine. When I'd park the car in the garage after a good hard drive and then come back to it 30 minutes later there would be a faint hot oil smell in the garage. |
![]() Join Date: Sep 2015 Location: Monongahela PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
(Thread Starter) | Not Ranked : 0 score I checked the chain today while warm, there was a bit of slack, maybe 1/4 inch. No where near as bad as this guy: https://www.youtube.com/watch?v=ZQI8SHKPEXI Regarding the oil consumption, I am switching to 5W-40 and will monitor the consumption. |
| Not Ranked : 0 score There should be none when warm Sent from my XT1565 using Tapatalk |
| Not Ranked : 0 score I'd do it sooner rather than later, take it easy, no hard downshifts. Sent from my XT1565 using Tapatalk |
(Thread Starter) | Not Ranked : 0 score If I crank the engine without starting (by holding down the gas petal), "prime" oil pressure for ~5 seconds, the car starts without any rattle. Is this just treating the symptom, or is it an anti-drainback oil filter issue, a la this thread? |
| Low Compression in cylinders 2 and 3 | cbiscut | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 10-16-2017 11:01 AM |
| Sparkplugs fouling/buildup weird. | tom10122 | Mazdaspeed3/6 General Discussion | 5 | 04-07-2017 09:18 AM |
| Cylinder One Spark Plug Fouling - Oil on Plug Thread - Slow Start | conrad51 | 2010 MS3 - Troubleshoot/Diagnostics | 8 | 11-15-2016 05:37 AM |
| BMW already considering four cylinders for next M3 | Haltech | Automotive News | 0 | 05-13-2014 12:10 PM |
