![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score A leakdown test will tell you where the leakage is occurring. The technician is supposed to listen for where the air is leaking from. If I had to guess, yes, I would say the problem is likely in the bottom end, likely cracked ringlands. 15% leakdown on a stock motor is a lot.
__________________ 2007 Mazdaspeed3 GT |
| Confusing electrical problem | ShintaroIchi | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 10 | 08-02-2015 01:30 AM |
| Mostly good compression but shit leakdown results | VA2010MS3 | 2010 MS3 - Engine, Transmission & Driveline | 1 | 07-23-2015 09:43 PM |
| Bad Leakdown | Mofford12 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 10-29-2014 04:26 PM |
| Leakdown test question | torq | MazdaSpeed 3/6 - Turbo Induction | 0 | 08-09-2013 08:29 PM |
