  • 1 Post By Jeff23spl
 Old 10-25-2018, 01:01 PM   #1
Posts: 2,235   (View Stats)
An alternator with shorted diode will become a load on the electrical system as well as a load for the engine to run until it get hot enough to catch fire.
when installing a new battery, i would check the remaining load by reading miliamps going out of the battery. Start with the 0-10amps scale in case the alt is short. The lowest number will read just after a while when the bcm turn off all the load that stay on for a minute after engine shutdown. Compare your results with the Mazda specs and if it is higher remove the fuse 1 by 1 to find where the load comes from...
When the engin runs, you should read between 13.5 and 14.5 volts (usually 13.8) but confirm your meter on another car if you get strange numbers...
Once this is done and you repaired the electric problem, if it is still hard to start you may check elsewhere.
i dont get if you just replaced the rings without machining the cylinder bore but it could be a major reason of blow by to pop up a dipstick. (Round rings in an ovale cylinder)
thatguy0o0 likes this.
MSMS3 (10-28-2018), thatguy0o0 (10-25-2018)
Leaking oil Dip Stick MS3 RussM MazdaSpeed 3 - Engine, Transmission & Driveline 11 02-28-2017 01:51 PM
Ms6 stock with light tune dip stick blow out Jarods7920 Mazdaspeed3/6 General Discussion 9 01-13-2014 11:53 AM
Dip Stick Blowing Out...? AutoXRacer MazdaSpeed 3 - Engine, Transmission & Driveline 58 01-18-2009 09:52 AM
Page generated in 0.22199 seconds with 21 queries
