 Old 09-01-2012, 07:02 PM   #1
sviki's Avatar
Posts: 35   (View Stats)
sviki is an unknown quantity at this point
Default Oil leak! - Suggestions appreciated
Noticed oil smell yesterday and today I looked under the car and there was a big oil puddle. Freaked me out. Looked under the car tonight but not sure if it's the seal or what.
It's above the oil pan. Please take a look at the attached picture, I think that's where the leak is coming from. Oil plug and filter are tight, doesn't seem to be leaking from there.
sviki is offline   Reply With Quote
 Old 09-01-2012, 07:04 PM   #2
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
doubt it, look to the right of the oil return line (what you circled) it's dripping down there too..hmmm fuck. I really doubt that came from spraying too
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
 Old 09-01-2012, 07:06 PM   #3
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
When did you fill the oil last? Miss on the fill?
07 MS3
The original Genpoo Hater
 Old 09-01-2012, 07:21 PM   #4
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
That is not miss fill cause that does not seam like a brand new oil.
@sviki I cannot see taht picture well but i believe that is the oil line, the one that the oil returns to the engine from your turbo. Can't really tell by the pic though. Is that genpu cause the oil return line on the genwon is different. I have taken my turbo a couple of times and that gasket on the line was bad and was dropping some oil. Double check it!
dead-zone is offline   Reply With Quote
 Old 09-01-2012, 07:23 PM   #5
Will fuck up ur day
Chimmike's Avatar
Groans: 433
It was already noted to be coming from another source as its dripping from somewhere on the right
07 MS3
 Old 09-01-2012, 07:41 PM   #6
sviki's Avatar
I think it's leaking from the oil return line (wasn't sure what that was called). I let it run for few seconds while I was under the car and that's where the oil started coming out of.
I think the rest of the oil is from the oil spraying because it's everywhere.
I checked it couple weeks ago and the level was good. I changed it about 4K miles ago.
If it's the oil return line gasket, is it simple to replace and do I have to get it from a dealer or does AutoZone carry it?
It's gen 1 btw.
I appreciate your input.
 Old 09-01-2012, 08:28 PM   #7
khonzo's Avatar
Posts: 77   (View Stats)
khonzo is infamous around these partskhonzo is infamous around these parts
Groaned at 99 Times in 25 Posts
dealer will prob be your best bet for that. or autozone will have gasket paper if you wanna just make your own
khonzo is offline   Reply With Quote
 Old 09-01-2012, 08:46 PM   #8
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
I suggest finding the leak... Then fix it
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
Fatguy729 is offline   Reply With Quote
 Old 09-01-2012, 08:48 PM   #9
MS6FL's Avatar
Posts: 1,753   (View Stats)
MS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the world
Groans: 43
That seal is like 5 bucks from Mazda and a PITA to install. Get a loooong 8mm wrench...
“From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley
MS6FL is offline   Reply With Quote
 Old 09-01-2012, 10:43 PM   #10
dead-zone's Avatar
First check if it is really the seal! As I said I am not sure because I cannot see it good from the pic. If it comes from somewhere higher but it runs on the line check the banjo bolt on the turbo. As ms6fl said, the seal pretty cheat at mazda.
 Old 09-02-2012, 06:57 AM   #11
sviki's Avatar
Well, doesn't look like it's the oil return line. I wiped the oil and let the car run until I saw some oil come out - it's above the return line and can't really tell where it's coming from.
I guess I'll have to take it to the dealer. Sucks because they won't open until Tuesday.
 Old 09-02-2012, 08:23 AM   #12
sviki's Avatar
Do you guys think I should put it back to stock before I take it to the dealership?
I only have SRI, SSP, and RMM.
I've done oil changes myself and have all receipts.
 Old 09-14-2012, 08:42 AM   #13
sviki's Avatar
It turned out to be oil pipe, according to the dealer, not the return line.
I appreciate everyone's input.
1st log! Any input appreciated NCZ13 MazdaSpeed 3/6 - ECU Computer Tuning 8 09-17-2011 09:20 PM
Any type of help appreciated. popester112 MSP - Turbo Induction 13 08-31-2011 03:41 AM
Much Appreciated Airman3454 Gen2 MS3 General Discussion 23 06-10-2011 03:14 PM
assistance appreciated Chriscote MazdaSpeed 6 - Engine, Transmission & Driveline 19 07-21-2010 12:47 PM
Any help would be appreciated...UR TP miztigerszou52 2010 MS3 - Engine, Transmission & Driveline 4 05-18-2010 08:25 PM
Page generated in 0.31676 seconds with 27 queries
