 Old 09-22-2018, 10:12 PM   #1
Solarsurge's Avatar
Posts: 577   (View Stats)
If you have to ask how much torque, you're using too much. OEM gaskets should seal properly. Just make sure you clean both mating surfaces well to remove any old gasket material and/or dirt/debris and that there are no dents or bumps on either side.
Page generated in 0.21957 seconds with 21 queries
