 Old 01-29-2012, 07:28 PM   #1
2006MS6's Avatar
Posts: 271   (View Stats)
2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of
Groaned at 8 Times in 5 Posts
Default only reading 10psi
so the dealer put in a brand new k04 for warranty work and now my boost gauge is peaking at only 10psi. What could cause this?
06' Speed6
Cobb SRI | Eibach Pro Kit | JBR SSP | JBR RMM
2006MS6 is offline   Reply With Quote
 Old 01-29-2012, 07:41 PM   #2
Bob-o's Avatar
Posts: 1,312   (View Stats)
Help-OEM Boost Control Solenoid
The Following User Says Thank You to Bob-o For This Useful Post:
Downmented (03-02-2012)
 Old 01-29-2012, 07:47 PM   #3
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
sounds like its running just off spring pressure. if it was just worked on by the dealership, i would take it back to them and have them fix what they fucked up. suggest looking at the boost control solenoid
The Following User Says Thank You to TWOptSL0W For This Useful Post:
Bob-o (01-29-2012)
 Old 02-01-2012, 12:45 PM   #4
2006MS6's Avatar
ok, they said theyll look at it.
Quick question though. Now that its only peaking at 10psi, shouldnt i feel a significant difference in power? The car seems to drive fine as far as i can tell.
06' Speed6
 Old 02-01-2012, 02:57 PM   #5
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
no power loss? maybe it's your gauge.
 Old 02-01-2012, 03:54 PM   #6
2006MS6's Avatar
it doesnt feel like it.. would that be a huge difference in power?
what all should i check for leaks? Im gonna replace that cheap clear hose for the gauge that they give you with some actual vacuum hose. dont know what else i would check though.
06' Speed6
 Old 02-02-2012, 08:11 AM   #7
2006MS6's Avatar
ok so that didnt work, ended up running a line straight from the bpv to the gauge without going through the firewall to eliminate kinking and still only reading 10psi.
06' Speed6
 Old 03-01-2012, 11:37 AM   #8
2006MS6's Avatar
ok, so i finally got a chance and picked up a dash hawk. Hooked it up and did some runs. Still only peaking at 11psi and dropping back down to around 10psi. What could be causing this?
06' Speed6
 Old 03-01-2012, 01:17 PM   #9
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
did you ever take it to the dealership?
it's fun to do bad things
 Old 03-01-2012, 04:30 PM   #10
2006MS6's Avatar
No, only because after reading a few threads about the same issue. All of them tried the dealership, said it ran fine and sent them on their way.
06' Speed6
 Old 03-01-2012, 04:36 PM   #11
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
ebcs not connected right or boost leak
07 MS3
The original Genpoo Hater
 Old 03-01-2012, 05:29 PM   #12
2006MS6's Avatar
Where is the boost solenoid located? How can I check if it's bad or connected correctly.
06' Speed6
The Following User Says NO Thank You to 2006MS6 For This Un-useful Post:
Chimmike (03-01-2012)
 Old 03-01-2012, 06:15 PM   #13
Will fuck up ur day
Chimmike's Avatar
Groans: 433
FSM. VIP section. Stick yer virtual nose in it.
07 MS3
 Old 03-01-2012, 06:25 PM   #14
2006MS6's Avatar
If its bad, would that be something covered under warranty?
06' Speed6
 Old 03-01-2012, 06:34 PM   #15
Will fuck up ur day
Chimmike's Avatar
Groans: 433
no man, it could be as simple as vacuum lines being backwards.
07 MS3
 Old 03-02-2012, 05:12 PM   #16
2006MS6's Avatar
if everythings connected but they backwards, how am i supposed to know if nothings leaking? lol i know nothing as far as details go about this car lol
06' Speed6
 Old 03-02-2012, 08:23 PM   #17
Groans: 549
you decided based on other threads that going to the dealer, who caused the problem, won't work. now you can't even determine the correct connection set up of the parts yourself.
hmm, can't take it somewhere. can't do it yourself.
well, i guess you're fucked.
 Old 03-02-2012, 08:29 PM   #18
2006MS6's Avatar
Or maybe, just maybe someone with some knowledge who doesnt get all upset every time someone asks a question could just explain something. Maybe just once!
06' Speed6
 Old 03-03-2012, 04:24 AM   #19
Groans: 549
You've been given a couple suggestions already. Your response was why those won't work. What else do you want?
Sent from my LG-MS690 using Tapatalk
Boosting at 10psi sucks....possible solutions? ESB Jiu JItsu MazdaSpeed 6 - Engine, Transmission & Driveline 17 11-15-2011 01:34 PM
ap not reading pcm??? blcspd 2010 MS3 - ECU Computer Tuning 3 07-09-2011 03:52 PM
Installed CAI and now only have 10psi of boost dbrier MazdaSpeed 3/6 - Turbo Induction 2 06-08-2009 01:57 PM
Only boosting 10PSI ?? glocK23 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 05-18-2009 02:35 PM
took off mbc and only seeing 10psi b-ron MazdaSpeed 3/6 - Turbo Induction 2 07-29-2008 11:01 PM
Page generated in 0.36585 seconds with 25 queries
