![]() Join Date: Jan 2017 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
(Thread Starter) | Not Ranked : 0 score So, I was curious which of these two oils would be better for my application. I figured I may as well start a thread in case it could help anyone in the future. Via https://bobistheoilguy.com/pennzoil-q-a/ "Pennzoil Ultra Platinum™ with PurePlus Technology is formulated to contain additional cleansing technology and additional friction modifiers to maintain lower friction between moving parts." "Pennzoil Platinum® Full Synthetic motor oils with PurePlus™ Technology provide excellent performance in low temperatures thanks to the superior low temperature pumpability of PurePlus™ base oils. Pennzoil Platinum® Full Synthetic motor oils with PurePlus™ Technology SAE 0W-30 and 0W-40 will still pump in temperatures as low as -40°F!" What this translates to is basically better additives, and possibly better low temp durability/performance. I assume for the regular MS3 owner PP will be more than adequate, but PP Ultra will provide added protection if wanted. Edit: Checked out https://bobistheoilguy.com/forums/ub...pics/3160117/2. These guys really liked to beat around the bush, but what I gather they're generally interchangeable. The only difference being "Ultra has a better add pack, higher TBN and about the best Nocak. Both are approved for dexos." Anyone care to explain that in simpler terms? AFTER RESEARCH AND OTHER CONTRIBUTIONS THE DIFFERENCES ARE AS FOLLOWS: -PP Ultra has a better pack and mixture of additives. -PP Ultra is possibly better in low temperature environments. -PP Ultra is more suited for high HP applications -PP Ultra is better at combating fuel dilution than it's counterpart. Member contributions: From GroceryGtr "I work with the pen oil guys and asked them about the difference when it first came out. They designed this specifically for some of the higher hp applications oems have and to address some of the unique issues presented by DI engines as they are becoming more common. That said they did point out that the regular platinum formulation will work just fine from a lubrication perspective." From GotoVato "From what I've picked up, the biggest difference between the two comes down to fuel dilution properties. Platinum was pretty good at combating it, ultra platinum was even better. The harder you drove, the better ultra platinum was for you. If you were a lighter footed driver regular platinum would be just fine. Last edited by MunkieJunkie; 01-23-2017 at 03:28 PM. Reason: Formatting |
| The Following 3 Users Say Thank You to MunkieJunkie For This Useful Post: |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Rotella
__________________ Max Bolted and Built Stock K04 |
| The Following 2 Users Say Thank You to sheston For This Useful Post: | sharksinspace (01-20-2017), Yatta (03-02-2017) |
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 263 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score It's ULTRA better!!!
__________________ Genpoo stuff |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score Rotella t6 or German Castro 0w-40
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following User Says Thank You to tegxsi For This Useful Post: | Yatta (03-02-2017) |
| Ultra Rotella ![]() Sent from my Pixel XL
Groans: 111
| Not Ranked : 0 score Just use any full synthetic good oil, as long as you make sure the engine doesn't burn it and you change it when you should it's all good. If you want to go bananas about it then use a true synthetic like Redline. Over the winter I use the God of 0w40 full synthetic oils (because the true synthetics burn with a lot more soot even though they create a lot less vapours) which is the Mobil 1 0w40 - I'm not sure if you can source it over there though. If you think of using the Mobil1 mind that the 0w40 (New Life it's called here) is the only decent oil from them, don't use the X3000 or other crap. During summer I prefer using true synthetic oils like Redline, Motul Ester Sport (beware, Motul generally makes full, not true synthetic oils, the ones with esters are the ones you need), or Millers CFS NT which you can source in the US and Canada but probably for about the same price I source here the Redline, which is about $20/quart. If winter in your location is not harsh then as I said, just use a good oil. Also, it may not make sense to go true synthetic if you don't hood your car too much or go to the track. Over here the Pennzoil stuff is branded as Shell. So Pennzoil Ultra is Shell Helix Ultra and it's a pretty decent oil and yes, you can use that no problem. Oils are like tires, or like cars. You need to find a good product that suits your driving habits. You can't get Michelin Pilot Sport Cup 2s to drive around town 20 miles a day, and you can't get Michelin Energy Saver or Pilot Primacy to go do track events. Or you can't buy an awesome MX5 to get your kids to school, you'll need a 3/6/CX 5/9 for that, or a B series if you do farming. However, people will tell you that "this" is a better tire/oil/car/blender than "that", which may be true to an extent or from a point of view/analysis, but these statements contain only partial truth, not the absolute truth. So you need to use your judgement a bit as well, and even try a few different products before you take a final decision. So whatever oil you chose switch away from it the second you see oil consumption significantly more than you used do (also accounting for the weather and the type of driving you did). The Shell Rotella... well, this oil was initially released on the market as diesel truck oil. It had a lot of detergents and creating a strong film, but it was not suitable for high RPM engines. A lot of performance car owners (subaru, honda, mazda, and so on, engines with tight tolerances that needed a 0 or 5 grade weight for cold and 30/40 for the hot weight) gummed up their engines and piston rings back in the early/mid and even late 2000's because the oil was evaporating quite quickly and people were rrunning into various engine issues because of that (cracked ringlands, ovalled cylinders, huge carbon deposits on the valves and pistons on the DI engines, you name it). Pretty much everybody was blaming the driving habits (you added an intake, put in supposedly better oil, so you must be driving like an animal, right?), but people who were opening up those engines (if there was an engine left to open, and didn't open itself on the highway) were like "wtf?!". Now the Rotella is also rated for use in petrol engines. New times - new and better additives, right? So it must be suitable for our engines, and if you use some sort of port injection (single port meth, or multiport meth/Ethanol) you should be fine.
| The Following 2 Users Say Thank You to mituc For This Useful Post: | krimsonviper (11-09-2017), MunkieJunkie (01-21-2017) |
(Thread Starter) | Not Ranked : 0 score Thanks for the info Mituc, but the main purpose of the thread was to just compare PP to PP Ultra. I completely agree, though. If I really wanted to run a true synthetic I'd run Motul/Redline/Amsoil. But when I ran Rotella T6 I always changed at 3k miles, and checked at every fill up to make sure it wasn't burning too much. The additives in it are great, and the high Zinc content is great for turbos. However, it's not equal to other synthetics and I think that's where people go wrong. |
Groans: 111
| Not Ranked : 0 score Get the Ultra Platinum then, 0w40. About the high zinc content oils:
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| The Following User Says Thank You to mituc For This Useful Post: | krimsonviper (11-09-2017) |
(Thread Starter) | Not Ranked : 0 score Again, thank you for the info but discussing whether or not a high zinc content is good for engines was not the purpose of this thread. I've ran Rotella for many many miles and had zero issues. If the PP or PP Ultra was a high zinc content oil i could understand how it would pertain and be relevant/useful to this thread. |
Groans: 126
| Neutral : +1 score If Rotella wasn't good for our engines for any reason; I'm positive that we as a community would know by now.
Groans: 111
| Neutral : -1 score Inspect your intake valves and the top of the pistons.
Groans: 126
| Neutral : -1 score Dirty valves are the nature of DI and an issue on these cars regardless of oil type, what does that have to do with Rotella? Enough guys have run it for long enough sans issue, and while coming back with clean and problem-free oil analysis results, that you cannot convince me that it's harmful to use in our MZRs.
Groans: 111
| Not Ranked : 0 score I'm not trying to and actually I don't think it's harmful for these engines. At least in the past it used to contaminate the engines significantly more than other oils despite the fact that the additives package for trucks gave it a significantly higher fuel contamination resistance.
![]() Join Date: Nov 2016
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Platinum 5w30 should be fine, I would change it at the latest every 3500 miles. I like the t6 in mine.
__________________ 2008 Red MS3 sport CS RMM, JBR side mounts Corksport Stage II intake Test pipe Autotech Internals Stock heat range NGK's .26 gap. stratified stage 3 93 and E85 tunes "America is all about speed, hot, nasty, badass speed." |
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
| Not Ranked : 0 score I work with the pen oil guys and asked them about the difference when it first came out. They designed this specifically for some of the higher hp applications oems have and to address some of the unique issues presented by DI engines as they are becoming more common. That said they did point out that the regular platinum formulation will work just fine from a lubrication perspective. Sent from my iPad using Tapatalk
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... |
| The Following User Says Thank You to GroceryGtr For This Useful Post: | MunkieJunkie (01-23-2017) |
![]() Join Date: Dec 2016 Location: Mississauga, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score From what I've picked up, the biggest difference between the two comes down to fuel dilution properties. Platinum was pretty good at combating it, ultra platinum was even better. Coming from the veloster turbo world that was a huge topic all over the forums. The harder you drove, the better ultra platinum was for you. If you were a lighter footed driver regular platinum would be just fine.
__________________ 2011 ms3 Cobb AP, Forge bypass valve, HPFP internals, Cobb downpipe, Custom fmic w/mishimoto core, Cobb RMM, Cobb EBC, KW coilovers, whiteline RSB, stop tech fluid, stop tech SS brake lines, hawk HP+ pads, ACT 6 puck clutch, ATP 3071r, HTP 3.5" intake, Damond catch can, TunedbyNishan |
| The Following User Says Thank You to gotovato For This Useful Post: | MunkieJunkie (01-23-2017) |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I thought the community was pretty clear that Rotella was not the oil to use if you were running full E. Black death.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
| The Following 3 Users Say Thank You to shamie For This Useful Post: |
Groans: 126
| Not Ranked : 0 score Is that limited to only Rotella? My understanding, as someone who has not heavily researched running E due to lack of availability where I live, was that the black death is an issue with our fuel pumps and running E in general when people start going too heavy on the mix.
| Not Ranked : 0 score I also assumed the black death was due too a high E/mix content all the time, not necessarily any oil.
| Not Ranked : 0 score Yes its if you run full E with oils that don't have a certain formula (which I can't find right now). I know that Castrol Edge and a Royal Purple among many others had the formula. Rotella did not.
(Thread Starter) | Not Ranked : 0 score Thanks for the info guys, it's updated. |
| Not Ranked : 0 score I did quite a bit of reading on this while writing this thread (More info regarding Rotella T6 in our engines) it's quite interesting. If you roll up the oil specifications, it comes down to a couple important things for DI motors: Total Base Number (KOH/g, ASTM2896) which is the reserve alkalinity of an oil to neutralize contaminants and NOACK as mentioned above (ASTM D5800), which measures the evaporative loss of oil. Basically, you want a lower NOACK #, and a higher TBN. This would be an oil that can neutralize contaminants and minimize evaporative loss of oil. Based on my reading, it seems the NOACK may be more important, since the TBN number can be mitigated by more frequent oil changes. There seems to be a tradeoff of TBN vs. NOACK, that is based on the ones I read, higher TBN oils had lower NOACKs and vice versa. Pennzoil Platinum Ultra does not publish their TBNs, but the NOACK is higher than Pennzoil Platinum which would lead me away from it. Presumably their TBN is higher, but it isn't published so who knows. Pennzoil Platinum does fine in our cars, but I would keep the oil changes under 5k miles (4k-4.5k).
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
| The Following User Says Thank You to dale_gribble For This Useful Post: | MunkieJunkie (01-23-2017) |
![]() Join Date: Feb 2017 Location: Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score The Pennzoil Platinum Euro 5w-40 is what I use. Rotella T6 is cheap and considered a group III (low quality) oil. Group III oils are made through severe hydrocracking, which means they started out as crude oil. In the USA group III oils are allowed to be called "synthetic" due to looser regulations, but in other countries are considered non-synthetic. In our motors, using group IV and group V oils adds to the reliability aspect because of higher detergent levels and reduced calcium levels. LSPI is the main reason as to why these motors blow rods. Using higher quality/detergent oils can decrease the chance of this happening to your car. Check out the article posted by Stratified about LSPI and previous posts by Lex concerning oil types and LSPI. Good group IV and group V oil brands: Redline Amsoil Euro Pennzoil Platinum Euro Mobil 1 European Formula Last edited by flapjack; 02-23-2017 at 11:26 PM. Reason: Spelling |
| The Following User Says Thank You to flapjack For This Useful Post: | mituc (02-24-2017) |
![]() | | #24 | ![]() |
![]() Join Date: Sep 2009 Location: Port. St Lucie, Florida / Queens, New York
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,472
Groans: 129
| Not Ranked : 0 score I have been using pennzoil platinum since my car had 1k miles and now it's at 80k. I haven't noticed any oil loss with every oil change, seems to be doing it's job. And I change my oil every 3.5k miles Also how would you know if your pennzoil is European ? I buy my oil from Walmart, cheap as fuck
__________________ NATOR NJ/NY/FL 09 MS3 tuned by Nishan ![]() |
![]() | | #25 | ![]() |
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... | |
![]() | | #26 | ![]() |
Groans: 111
| Not Ranked : 0 score ...and probably mid-SAPS.
![]() | | #27 | ![]() |
| Not Ranked : 0 score So to resume for our speed3 the best : Winter : 0W-40 Mobil 1 Summer : 5W-30 True Synthetic Do you know if this oil => Liqui Moly 2041 Could be a good choice for summer use ???
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 |
![]() | | #28 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// | |
![]() | | #29 | ![]() |
Groans: 111
| Not Ranked : 0 score Liqui Moly makes good oils. Also 2041 is a 5w40 oil so a lot better than whatever 5w30 for our cars. Especially on factory turbo cars it's best to use a 40 hot weight oil, summer or winter. Then if you have a larger turbo it's recommended to use a w40 oil for the extra film strength under high(er) load. Otherwise our engines would tolerate from the factory even a w50 oil during hot summer days. A 10w50 would work but it's better if it's a 5w50 or even a 0w50 if you can find such oils in your area.
![]() | | #30 | ![]() |
winter : Mobil 1 0w40 summer : Liqui Moly 5w40 I will have GOD oil for my speed3 ???
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 | |
![]() | | #31 | ![]() |
| Not Ranked : 0 score I like the idea of 0w for winter, but here in Colorado... Temp Delta is crazy... it will be in the 60’s today; its why I no longer run snow tires, just really good all-weather...
![]() | | #32 | ![]() |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
End hijack. Please continue senseless, largely un-knowledgeable, unfocused discussion about motor oil.
__________________ 2013 'speed3, silver Stage Bro | |
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Presume you mean DWS. That's what's on my GF's car LOL. Blizzaks are made in both categories, which most don't realize. But most who have Blizzaks have the "studless" category Blizzaks not the performance winter Blizzaks. I've found the studless category Blizzaks to be epic rubbish on a dry road.
![]() | | #35 | ![]() |
![]() | | #36 | ![]() |
Groans: 111
With a good full or true synthetic oil you don't have to worry about the film strength during cold starts of a 0w oil either, they will perform just fine.
| The Following 2 Users Say Thank You to mituc For This Useful Post: | WAMBUSHHHH! (03-04-2017), Yatta (03-06-2017) |
| Pennzoil Platinum $10 off coupon @ AUTOZONE | dan7225 | Hot Deals Section | 0 | 05-14-2013 09:50 AM |
| Pennzoil viscosity error | edwhayes | CX-7 > Engine, Transmission & Driveline | 14 | 04-21-2012 06:21 PM |
| Pennzoil Platinum/Valvoline Syn | skawt01 | 2010 MS3 - Engine, Transmission & Driveline | 9 | 07-10-2010 11:59 AM |
| Those who want Pennzoil Platinum 5/40 Euro | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 12 | 01-14-2009 10:08 AM |
