 Old 03-07-2009, 07:43 AM   #1
wassup61's Avatar
Posts: 1,232   (View Stats)
Default PID tuning explained
Since there is some confusion in the CP-E explanation of PIDs, I have decided to make a practical definition.
PID laymans explanation.
kP is the scalar of the function. The higher this value the more likely you are to spike, however, this is also the overall gain of the system and it weighs on all the values within the system
kD is the intensity of the slope. The higher this number, the slower the turbo will try to reach peak boost, if it is too high, the turbo will not hit the desired boost target. This value is affected by the scalar kP term.
kI or the summed error factor is how much effect the targeted boost has on the behavior of the turbo. The higher this number, the more closely you will adhere to the targeted value of boost (given the correct kD). If it is too low you will creep, if too high you wont hit the target boost value and cut (this ties in with the kD term)
Do not be fooled into thinking this is a linear process. Any one value that is overweighted (especially kP and kD) can actually cause systematic inversion.
-Jeff at PG
All wagon, No traction
The Following 2 Users Say Thank You to wassup61 For This Useful Post:
6-Speed-6 (03-11-2009), Phantom (03-10-2009)
 Old 03-07-2009, 08:02 AM   #2
boostedminime's Avatar
Posts: 251   (View Stats)
boostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant futureboostedminime has a brilliant future
Groaned at 16 Times in 4 Posts
kewl mang thanks for the tread
2010 mazdaspeed3 (current) jbr rmm, jbr stage 2 intake, jbr shifter bushings, cpe hpfp, obx cbe, catless downpipe, cobb fmic , bosh 3 bar map , jbr 3 port ebc,jbr IM and TB thermal gaskets, jbr egr delete, HKS ssqv,jbr short shift plate .
boostedminime is offline   Reply With Quote
 Old 03-07-2009, 08:25 AM   #3
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
great thread!!!
 Old 03-07-2009, 10:20 AM   #4
elsinc01's Avatar
Posts: 6   (View Stats)
elsinc01 is an unknown quantity at this point
thanks!
elsinc01 is offline   Reply With Quote
 Old 03-07-2009, 04:10 PM   #5
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
thanks bro im spiking to 18 psi thats my target but then i slowly falls off so would i need to lower the kp and the ki
boosted3 is offline   Reply With Quote
 Old 03-21-2009, 02:44 AM   #6
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
so what values should be tried?
what's the scale for these values?
like kp can be between x and y
kd can be between a and b
and ki can be between p and q
 Old 03-21-2009, 09:47 AM   #7
wassup61's Avatar
Kp between 1-40 (40 is the most I would want to go, as this makes everything super sensitive)
Kd between 50-999- you will never hit peak boost at 999 and you will spike too much at 50
Ki between .050 and .999 - you will never hit peak boost at .999 and you will boost creep or cut at .050 if you are anything but stock.
 Old 03-21-2009, 04:27 AM   #8
buddhabum's Avatar
Posts: 254   (View Stats)
buddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond reputebuddhabum has a reputation beyond repute
"I don't speak Spanish" - Ron Burgandy
'06 MS6 Black Mica
Street Unit Block, CP Pistons (9.0:1), Pauter Rods, CPBoost Top-mounted Turbo Exhaust Manifold w/ Tial 38mm External Wastegate, Custom 3", CP-E FCF (No Boost cut, 3.25" MAF), CP-E PnP Standback V2, CP-E HPFP, CP-E FMIC Core w/ Custom piping, Denso Spark Plugs, Custom Inlet w/ 3.25" MAF Housing, VCTS Delete, EGR Block-off, Saikou Michi OCC, Fidanza Flywheel, HD Signature 18x8" MSR Wheels, HTR Z III's 235/40/18, BS Delete, TWM Stage 2 SS Kit, Dashhawk, Perrin EBCS.
buddhabum is offline   Reply With Quote
sb tuning? johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 0 01-04-2009 11:53 PM
SEMA 2008: Cobra Jet Mustang arrives straight from dragstrip, 400-hp figure explained Haltech Automotive News 0 11-07-2008 08:30 AM
VIDEO: Ford F-150 SVT Raptor explained by Mike Levine Haltech Automotive News 0 11-04-2008 01:00 PM
Tuning bova MazdaSpeed 3/6 - ECU Computer Tuning 11 03-24-2008 12:28 PM
Page generated in 0.29129 seconds with 26 queries
