 Old 01-20-2019, 01:29 PM   #1
Redsped 3's Avatar
Posts: 4   (View Stats)
Redsped 3 is an unknown quantity at this point
Default Please help Intake runner control solenoid
Recently I’ve been getting a code at idle stating fuel system lean at idle. So I then sprayed all my vac lines with carb cleaner and found that my intake runner solenoid is the source. Just to make sure I smoke tested the solenoid and it was leaking like crazy. I now have 2 more that I bought one being brand new and the other off another Mazdaspeed. After installing the new one my LTFT was at 20.12 same as before so I took it all off again. I then smoke tested both of the the solenoids I got and To my surprise both of them leak out of the top of the solenoid. Has anyone else had this problem and any way to fix it?
Redsped 3 is offline   Reply With Quote
 Old 01-20-2019, 06:23 PM   #2
Posts: 2,826   (View Stats)
Please post a photo of this solenoid in place. "Intake runner solenoid" is not a term often mentioned here and there are quite a few solenoids activating things around or close to the intake manifold. Perhaps we know it by some other name.
Are you completely stock? In your other thread I requested you identify all mods on your engine. This helps enormously in trying to address problems as many known issues are related to changes or the design of particular modificatiins.
Help-OEM Boost Control Solenoid TRSpeed MazdaSpeed 3/6 - Turbo Induction 23 02-16-2016 07:09 AM
CEL P2004 INTAKE MANIFOLD RUNNER CONTROL STUCK OPEN kawaxi CX-7 > Engine, Transmission & Driveline 0 02-26-2015 05:00 PM
How do I get the boost control solenoid off Dboyle23 Gen2 MS3 General Discussion 4 01-01-2014 03:14 PM
D.O flow control solenoid SLOWHATCH 2010 MS3 - Fuel, Nitrous & Water Injection 35 11-04-2011 10:19 AM
Page generated in 0.24045 seconds with 21 queries
