![]() Join Date: Oct 2012 Location: Austin, TX
Rep Power: 282 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 406
(Thread Starter) | Not Ranked : 0 score See attached for what a melted ignition coil looks like... Only fried the number one coil. Unfortunately, the connector on the harness side also melted. Ordered a new one from here: https://www.bmotorsports.com/shop/pr...sihu03j95mi2m7 While it's en route, I have the coil independently wired with .5mm female spade connectors. Should hold me over for a couple days while that new connector ships. Overall, I consider myself pretty lucky. Only fried one coil plug, and had to replace about 6" of wire. Oh, the ground and power wire also fused to each other at the connector. No wonder I was getting the vape show and awful smell.
__________________ 2008 Mazdaspeed3 GT JBR TRU 3.5 Aluminum WP // Corksport TBE // JBR OCC Stage 2 // AP v3 (Tweaked [by me] E40 Tune) // Autotech Internals // Stratified EBCS // TWM Full Replacement w/ Type R Knob // CP-e Stage 2 RMM // JBR/Damond Full EGR Delete // Synchronic DV // NGK 6510s // FMIC [TR8 w/ JBR Pipes] // CorkSport Adjustable Struts/Lowering Springs // Progress RSB Jet Black Wax (06/24/2017) Better compression than Silaramic (02/20/2016) |
| bcm fried | chriswillrise | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 12-16-2014 05:10 PM |
| Help is my car fried - wtf | stokes620 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 03-16-2014 05:57 PM |
| Possible fried ECU and BCM | Blackrider | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 12-11-2012 07:55 PM |
| AP fried my ECU.... | miako1978 | MazdaSpeed 3/6 - ECU Computer Tuning | 47 | 04-30-2011 04:06 PM |
| turbo seals fried | eronenris | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 07-19-2010 11:31 AM |
