![]() Join Date: Apr 2017
Rep Power: 0 ![]() Thanks: 19
![]() Join Date: Oct 2013 Location: Sebastopol, Ca
| Not Ranked : 0 score I generally like to use whatever the manufacture has suggested to use. If you haven't already you can try to suck out the as much fluid as possible from the reservoir and fill with fresh fluid. Run the wheel lock to lock a few times and repeat from above until all fluid looks new.
__________________ Corksport stage 2 sri/tip, Autotech Internals, RSB, CBE, Forge bpv, Koni FSD, Mazda Sport Springs, ITV22, JBR PMM, JBR TMM, JBR RMM, Damond SSP JBR SSB, CX piping with TR6, DM OCC Dizzy Tuned " I just don't need a stage 6, 16 puck, teflon diamond plated clutch that can snap a femur downshifting." -Raider |
| The Following User Says Thank You to Orangatang For This Useful Post: | arnold600 (03-26-2018) |
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
| Not Ranked : 0 score the whine is caused by cavitation(air being sucked into the system). The reason it is going away once warm is because the oring/joint is heating up and swelling, sealing the tiny gap from the cold temps. Fairly commong for an oring or loose fitting to start showing symptoms of failure in cold temps. FYI: The oring between the resevoir and the pump is a very commong failure item for the 6s. If rockauto didn't have it, you could take your line to a local hydraulic shop and they can usually custom make a replacement for fairly cheap. Otherwise I'd grab a used one.
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... |
| The Following User Says Thank You to GroceryGtr For This Useful Post: | arnold600 (03-26-2018) |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
| The Following User Says Thank You to shamie For This Useful Post: | arnold600 (03-26-2018) |
| Not Ranked : 0 score sometimes not. Air molecules are smaller than fluid molecules. So its not uncommon to have just enough of a seal gap to allow air in, but not fluid out.
![]() Join Date: Oct 2009 Location: Maple Ridge, BC, Canada
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Is it still making noise after the fix? |
![]() Join Date: Sep 2018
| Not Ranked : 0 score last time i have changed my steering pump.when I opened up the hood and found the power steering pump has been leaking all over the place. First step > https://www.steeringlpsr.com/ where my friend works. They did very good job ![]() But first think, if something was wrong with your car check it ! |
| The Following User Says NO Thank You to Aharahel32 For This Un-useful Post: | Thor Hammer (09-26-2018) |
(Thread Starter) | Not Ranked : 0 score UPDATE: I fixed this issue a while ago but never posted. Turns out it was the O-Ring between the pump and reservoir. Seal kit from rockauto. 5$ fix. |
| Not Ranked : 0 score Last time my PS pump had wine, I gave it cheese.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | arnold600 (09-26-2018) |
| Steering wheel whine at low speeds | dutchbuffalo | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 02-20-2013 03:23 PM |
| Power steering pump whine/noise | kish89 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 01-09-2013 02:52 AM |
| Power Steering Pump Whine | PonchoKid | 2010 MS3 - Troubleshoot/Diagnostics | 18 | 08-26-2012 09:04 PM |
| Power Steering Whine? | Bubba Ho-Tep | Gen2 MS3 General Discussion | 24 | 03-11-2012 08:34 PM |
| does anyone hear the power steering whine at low speeds as you turn the wheel. | dimaxxxl | 2010 MS3 - Engine, Transmission & Driveline | 14 | 02-17-2010 12:11 PM |
