Closed Thread
 Old 12-29-2008, 08:32 PM   #81
2nr
2nr's Avatar
Posts: 486   (View Stats)
2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world2nr is the leader of the world
one quick question... if boost cut does such a great job, then how is it that Mark's WG line popped off and his 35R started to do it's thing until the motor popped.... but yet this cut didn't do it's job and save his motor... did it?
2nr is offline
 Old 12-29-2008, 08:32 PM   #82
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
yeah i'm all for removing that shitty fuel cut. i was next to a speed3 one day, didn't realize it at first cause it was dark, then he took off and i saw the badge so i went to catch up to him and my car was cutting like crazy. lets just say i laid off because i didn't want to make a fool out of myself with my car jerking.
bova is offline
 Old 12-29-2008, 08:32 PM   #83
JumpingJackson's Avatar
Posts: 967   (View Stats)
Originally Posted by palerider View Post
are you addressing this to me? or everybody else in the thread who disagrees with you?
my official stance is this.....
those under warranty, who are completely stock should not remove the boost cut.
anybody else should get rid of this mazda ecu bullshit that doesnt exist on any other tuner car in the world.
i can only imagine my dodge and honda buddies the next time we get together as i tell them im lucky my car boost cuts and isnt dangerous like theirs.
You still didnt answer the question. Im not debating whether anyone should or should not remove the boost cut. Im debating if its potentially dangerous.
And no one has disagreed with me that it is potentially dangerous.
JumpingJackson is offline
 Old 12-29-2008, 08:34 PM   #84
If im not mistaken he had a CP-E Standback with the boost clip right?
 Old 12-29-2008, 08:35 PM   #85
As you know Christian has fixed this in the latest AP maps by adjusting the triggers for the fuel cut instead of removing them completely
 Old 12-29-2008, 08:37 PM   #86
2nr
2nr's Avatar
but here's the thing... that clip only does so much. the ecu utilizes other parameters to tell how much air is actually flowing into the motor
2nr is offline
 Old 12-29-2008, 08:38 PM   #87
Also Randy, If removing the boost cut is so safe, why dont you drive around with your wastegate boost tube disconnected. But i dont think you would do that now would you?
 Old 12-29-2008, 08:39 PM   #88
dadasracecar's Avatar
Posts: 741   (View Stats)
dadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the world
It's really hard to argue your point... "potentially dangerous" could mean anything. I understand what you mean and for the most part agree that a properly orchestrated fuel cut has merit. Randy is arguing that the fuel cut in the Mazda ecu has no merit because it isn't properly set up.
My car would still cut with the boost clip set to 8 psi.
2008 BMW 335i 6MT black on black
www.p3performance.net
dadasracecar is offline
 Old 12-29-2008, 08:39 PM   #89
2nr
2nr's Avatar
lol at the thought of that
2nr is offline
 Old 12-29-2008, 08:39 PM   #90
From my personal experience this summer on my cobb flashed car my ECU, did boost cut when i overboosted. I cannot speculate on the ability of the ECU to detect overboost conditions through other means other than the MAP sensor.
 Old 12-29-2008, 08:41 PM   #91
phailerider's Avatar
Posts: 4,639   (View Stats)
is this a serious question?
modding period is "potentially" dangerous. flashing a stage 1 ap tune on your car is potentially dangerous. i could name 1000 things that are potentially dangerous. but this discxussion is about modding for power. the first thing youd want to do is eliminate anything that could restrain it. theres a reason everybodys so excited about this flash... its because its fixing the most imortant holdup this community has had for big power.
it is potentially dangerous. so is a cobb sri. so is eliminating the boost restriction in 1-2. should i go on?
thats why ive stated if you want to stay under warranty, with a stock car. then keep it there. your warranty will be intact, and a safe 240whp/250trq will be what to expect. and then if your car blows with cruise control on the highway, you'll get a brand new engine from mazda all under warranty!!!!
phailerider is offline
 Old 12-29-2008, 08:42 PM   #92
i'll bet 1000 dollars right now that christian cant remove it completely.
 Old 12-29-2008, 08:42 PM   #93
And my answer to that would that it could be "better" to adjust the triggers for the boost cut instead of completely removing it all together. Make it so the fuel cut IS properly setup and so it DOES have merit.
Disabling is a good first step in understanding how our ECU's work. But i feel it would be better to adjust it rather than remove it altogether.
 Old 12-29-2008, 08:43 PM   #94
well if jackson here agreed with you this shit slinging session never would have started in the first place.
you say "cpe needs to investigate". does that mean cobb is stuck? i thought this was a relatively easy fix?
Cobb isnt trying to reprogram the ECU. Cobb is making software to tune these cars. Theres more to the equation then fuel cut... Your MAP and O/C transition is where our problems lie.
Haltech is offline
 Old 12-29-2008, 08:43 PM   #95
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
lean at open/closed transition?
can someone elaborate on this?
does the transition always happen at the same rpm?
phillyb is offline
 Old 12-29-2008, 08:43 PM   #96
And I'll bet if you datalogged that fuel cut when and if it happens he would be able to tune it out and still have the saftey margin provided by a properly setup boost cut.
Thats the whole point of the boost cut is that it DOES happen when something triggers it to go off.
The Key is understanding WHAT triggers it and to adjust it so it doesnt go off unless something is wrong. In stock form unmodified the fuel cut IS a huge issue with the car trying to make power and something definately needs to be done with it. I think that is what we both can agree on.
 Old 12-29-2008, 08:44 PM   #97
2nr
2nr's Avatar
anybody know if there was a waiver for the ATP BCD?
2nr is offline
The Following 2 Users Say Thank You to 2nr For This Useful Post:
dadasracecar (12-29-2008), phailerider (12-29-2008)
 Old 12-29-2008, 08:45 PM   #98
I believe fuel cut and boost cut are two different terms that mean exactly the same thing. From my experience, the MAP has very little influence on the fuel cut once clamped below the stock level.
 Old 12-29-2008, 08:46 PM   #99
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
hahaha i was waiting to become an example.
MarkyMark is offline
 Old 12-29-2008, 08:47 PM   #100
Randy, sometimes i dont understand your thought process or why you would even throw that out there man. If Christian wanted it gone, it could be removed. Every thread seems to be turned into you bringing up Cpe vs Cobb.
Haltech is offline
boosted3 (12-31-2008)
 Old 12-29-2008, 08:47 PM   #101
2nr
2nr's Avatar
lol, sorry bud..
2nr is offline
 Old 12-29-2008, 08:49 PM   #102
phillyb's Avatar
Groans: 1,940
phil eluded to the *fact* that cobb could do this. randy is saying that cobb can't
phillyb is offline
 Old 12-29-2008, 08:49 PM   #103
the only thing that triggers it is when a load calculation is exceeded. or a map sensor that can see is exceeded.
why the fuck would i want either of those on my car. if i reached them id want them set back further....lol
 Old 12-29-2008, 08:51 PM   #104
Probably not, but they are selling them not me. I'm sure they atleast have some sort of warning in their documentation of the risks of lying to your cars ECU about how much boost pressure its running.
I also wonder how many cars (mazda or otherwise) have blown up due to people overboosting with their MAP clamped? That would be an interesting statistic i think.
 Old 12-29-2008, 08:54 PM   #105
2nr
2nr's Avatar
that probably happens every day... and then those people get on the forums get told they are dumb for cranking the boost up that high and they don't try to sue
2nr is offline
 Old 12-29-2008, 08:55 PM   #106
 Old 12-29-2008, 08:55 PM   #107
thats simply not true. i havent been involved in a cpe/cobb throwdown in months. find another example.
this guy mocked the way cpe is reprogramming our ecu and im contesting it.... simple as that.
as far as christian wanting it gone. i dont believe cobb tunes the way cpe does, and i dont believe that he can "completely eliminate it". cpe did with a simple flash. good on all cars.
if christian can do it... then i want a full throttle map/ no cut map on my ap tomorrow. if it works i'll give 1000 bucks to him, the site, whoever. if it doesnt.... i want 1 g in my paypal account tomorrow from jackson. he keeps saying this shit over and over... let him put his money where his mouth is.
worst case i spend a g to save a trip to cpe this week.
 Old 12-29-2008, 08:56 PM   #108
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
Groaned at 31 Times in 16 Posts
maybe christian can remove the cut completely! We do know bova never cuts it was virtually night and day. He went from cut to none at all? Maybe he is lucky who knows. I will let you know if it works out the same for me as i will be fully bolted minus bt!
Deadman is offline
 Old 12-29-2008, 08:57 PM   #109
My general feeling is that at there are dumb people out there that dont know what they are doing or all of the ramifications of what they doing.
People who think Oooh! lets turn up the boost on my vehicle while lying to the cars ECU about the boost without taking the proper precautions. I dont want to be held responsible for when someone takes something i sell and blows their car up with it because they dont know what they are doing. THAT is why i said i would want them to sign a disclaimer *IF* i was going to be selling a tuning device. in the right hands it can be very useful, in the wrong hands they can blow up an engine.
 Old 12-29-2008, 09:01 PM   #110
he said when he first was flashed he still cut and then it went away. id assume after the ecu learned the new "limit". cpe doesnt use "limit"..... its a COMPLETELY different mechanism. its gone COMPLETELY.
this should be pretty clear right now.
my point stands. i want a map from christian that will alllow me to boost 24 psi, with a maf pegged at 5.0. then i'll believe.
 Old 12-29-2008, 09:02 PM   #111
First off why are you so hardwired into thinking this always has to be about cobb vs cpe. Its not.
Maybe Christian doesnt want to be held liable if someone does damage their engine?
But he already said he would send such a map to Whoosh.
The only thing i am arguing with you is that it is potentially dangerous to remove the boost cut and to lie to the ECU about how much boost its running. It has nothing to do with CP-E or Cobb.
 Old 12-29-2008, 09:04 PM   #112
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
I thought Christain got rid of the cut for you...or did this happen before he raised the cut limit?
2008 MS3
Forge BPV, COBB SRI, AP ATR Stg 2+SF v107 FMIC, RPMC turbo inlet, Exhaust Depot DP, CP-E CBE, KMD internals, TT, DH, OF conversion, TRZ Poly mount, Exhaust Depot FMIC,TWM ss w/bushings, ITV22, AIS meth injection
Speedn3 is offline
 Old 12-29-2008, 09:04 PM   #113
Deadman's Avatar
no randy thats what anthony (superskaterxes) said. He has the cold weather fix more or less... I guess Christian spoke to ron directly and said he could take care of any cut he was having.
and yes neither bova nor superskaterxes cut!
Deadman is offline
 Old 12-29-2008, 09:04 PM   #114
bova's Avatar
Groans: 45
um no i didn't say that. when i first flashed it with the new map it never cut ever! so it was fixed from the start, it wasn't anything learned. don't know where you get your info.
bova is offline
 Old 12-29-2008, 09:06 PM   #115
Speedn3's Avatar
For the MS3? If so, can you direct me to the logs?
2008 MS3
Speedn3 is offline
 Old 12-29-2008, 09:07 PM   #116
bova's Avatar
Groans: 45
and also if he can raise the limit and what not, why do you think he can't remove it? kevin already said he can and that they can also stop certain cel's from happening like for O2 sensors and what not.
bova is offline
 Old 12-29-2008, 09:07 PM   #117
because haltech said it nut. i made an offhanded joke about "shitty ap tunes" in a cpe thread AFTER you mocked them.... and here we are.
lol to the christian liability. you love that liability argument dont you? sticking to it like shit on a shoe.
i said it is potentially dangerous. absolutely. almost as dangerous as allowing full boost, in 1st and 2nd gear, for a rookie driver.
 Old 12-29-2008, 09:09 PM   #118
First of all I didnt mock them. Could you please point out where i did this?
Well disclaimers and liability are intimately connected arent they? Its really hard to talk about one without the other.
 Old 12-29-2008, 09:09 PM   #119
Deadman's Avatar
i actually don't hate Randy as much as i did 2 hours ago.. But can you answer this question?
BOVA: and also if he can raise the limit and what not, why do you think he can't remove it? kevin already said he can and that they can also stop certain cel's from happening like for O2 sensors and what not. =D
i was going to ask the same but young bova stepped up
Deadman is offline
 Old 12-29-2008, 09:10 PM   #120
bova's Avatar
Groans: 45
so far just the federal model ms6 maps are done, he was in the process of converting all of them before christmas.
bova is offline
The Following User Says Thank You to bova For This Useful Post:
Speedn3 (12-29-2008)
Closed Thread
Goodbye to Phil Hill... GeezerMS6 Auto-X / Road Racing / Time Attack 2 09-02-2008 08:47 AM
Phil Hill, first American to win Formula One title, dies at 81 Haltech Automotive News 0 08-28-2008 02:00 PM
New England Patriots receiver Randy Moss starts NASCAR team Haltech Automotive News 0 04-30-2008 02:40 PM
Phil Hester resigns from AMD Haltech Computers & Technology News 0 04-11-2008 01:30 PM
Page generated in 0.58633 seconds with 30 queries
