 Old 10-13-2017, 04:48 AM   #1
gamma500's Avatar
Posts: 38   (View Stats)
gamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to behold
Default REAR CLUNK REDUX
Several threads describe rear clunk noises often a result of suspension parts, i.e. sway bar mount loose, sway link worn, occasional blown shock,,, In my case I had a rear PS side clunk on hitting road imperfections for a year plus. Occasional looks at the rear suspension didn't reveal any obvious source. Replaced the right rear swaybar link w/o improvement.
Yesterday, took off the right rear hatch interior panels and long story short, found the SiriusXM receiver box's adhesive underpad was shot so the metal box was free to bounce up and down on its metal ledge.
Foam padding and some duct tape anchors and no more clunk !!
To access, remove top plastic where seat belt comes out, plastic panel at rear bottom where hatch latch is, plastic sill trim (rt rear door), rear seat bottom, and lastly, the right side fuzzy panel that covers the right hatch side (remove parcel shelf, hatch floor panel and molded foam inlays and front/bottom of hatch piece right behind the seats held by 2 screws)
gamma500 is offline   Reply With Quote
 Old 10-13-2017, 12:54 PM   #2
Smallville's Avatar
Posts: 32   (View Stats)
Smallville has a spectacular aura aboutSmallville has a spectacular aura about
Thanks for the tip - I've been dealing with rear clunk noises and thought it was the coilovers. I didn't even know we had a SiriusXM receiver box at all. I'll be sure to check this out!
Smallville is offline   Reply With Quote
 Old 10-13-2017, 06:40 PM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Interesting. Noted!
 Old 10-15-2017, 05:19 PM   #4
Smallville's Avatar
Is there supposed to be a SiriusXM receiver here or was that installed aftermarket on your car?
 Old 11-27-2017, 06:24 AM   #5
gamma500's Avatar
That's where it was as it came from the Dealership. If I remove the access panel to the rear tail light, I can reach forward and touch the receiver. Sorry for slow reply...never got a "you got a reply" notice to the Forum.
Mystery Pop/Clunk from rear - MS3 Atticaz MazdaSpeed 3/6 - Suspension & Brakes 49 09-09-2015 04:53 PM
clunk, then no power to rear wheels Seigisama MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 02-24-2014 12:55 PM
Rear clunk speed 6 ms6forthewin MazdaSpeed 3/6 - Suspension & Brakes 23 11-08-2013 12:42 PM
Clunk from the rear lildisco CX-7 > Issues & Troubleshooting 3 10-06-2013 07:46 AM
Rear end clunk itsstock02 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 09-03-2012 04:58 PM
Page generated in 0.25855 seconds with 23 queries
