 Old 07-25-2018, 03:43 PM   #1
MPS-Joe's Avatar
Posts: 21   (View Stats)
MPS-Joe is an unknown quantity at this point
Originally Posted by Solarsurge View Post
Your mass airflow sensor is calibrated for the volume of air the stock intake takes in. If you change your intake and don’t re-calibrate your MAF table (tune), your MAF voltage is going to be off so your car thinks you’re taking in different air amounts than you actually are, which is going to throw off your fuel delivery.
Ah right ok, I've not changed anything since owning it and it's been tuned for the mods it has. Never had a problem with trims until now.
MPS-Joe is offline   Reply With Quote
High negative ltft Redlinedgamer 2010 MS3 - ECU Computer Tuning 4 05-24-2017 09:07 AM
Lean Idle and high STFT I_AINT_RICE MazdaSpeed 3/6 - ECU Computer Tuning 9 09-08-2015 08:48 PM
Positive STFT and Rich AFR at the same time portetra000 MazdaSpeed 3/6 - ECU Computer Tuning 6 10-30-2014 07:55 PM
Increasingly negative STFT mrQQ MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 03-06-2013 06:45 AM
High STFT spike BT2010speed 2010 MS3 - ECU Computer Tuning 4 05-09-2012 03:53 PM
Page generated in 0.23542 seconds with 22 queries
