Mazdaspeed Forums
-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforum.org/forum/forum/f505/)
-   -   Rock Auto - What doesn't fit?? (http://www.mazdaspeedforum.org/forum/forum/f505/rock-auto-what-doesnt-fit-124869/)
Chimmike 09-17-2012 03:42 PM
Let this be the beginning.
I have 2 so far that I need to add. Potentially a third.
cnyms6 09-17-2012 03:57 PM
AC compressor didn't fit
dale_gribble 09-17-2012 04:03 PM
I have found a few times where parts listed for my Speed6 is wrong on Rock Auto because for some dumb reason, a lot of parts were listed to work with 2.3L motor and Mazdaspeed MZR even though this isn't right. I mean, the parts sort of fit, but they are different enough to be a PITA; In other words, the part will fit and not leave you stranded, but its just different enough to cause the OCD in you to flare up. A lot of part manufacturers must have assumed the 2.3L and MZR are basically one in the same and didn't do a lot of research.
Specifically for me, the thermostat and radiator. The thermostat on the 2.3L has a longer neck, by about 1.5" then my MS6. The MS6 neck is shorter to clear the power steering hose. The longer neck does fit and will work, but the power steering hose has to be scooted over a bit. The supposed MS6 drop in radiator from them has different lower mounts and the auto trans cooler hookups. I massaged it to work because I was in a pinch, but I will eventually get my stock radiator repaired and reinstalled.
LilGator 09-17-2012 04:24 PM
Blower motor for MS6 doesn't fit. They list it under "2.3L L4 Turbocharged", but it's definitely not a match.
TiGraySpeed6 09-17-2012 09:24 PM
I'll see if I can look up some of the bad part numbers tomorrow, but last I looked, only one passenger side front cv axle, out of 6 different axles, both pass & drivers side, actually fits the speed6.
I also have the specs, dimensions & such that I'll add to feed the search engines and help folks be able to identify speed6 axles from 2.3 na axles which are much smaller
jack_hammer 09-17-2012 09:33 PM
i bought two rear ABS sensors. they both fit. in fact, they say "fomoco" on them. however, i think one is broken. i'm still working on determining that, though...
Haltech 09-17-2012 09:35 PM
Lol someone in SoCal Nator was just pointing to me about this $63 axle they wanted to buy from them.. I hope they see this thread.
theschrum 09-17-2012 09:43 PM
Rock auto is an awesome site for parts, but I always reference the part number to a regular 2.3l before I purchase from them though. I wouldn't be suprised if 20% of the parts listed for our cars didn't fit.
TiGraySpeed6 09-18-2012 01:57 PM
Rock Auto- MS6 axle listing has been improved, but still not perfect. At least it's better than it was. Only a single CV appears to be incorrect.
I can guarantee that Cardone # 608190 is correct, that one was in my car for a couple of months till the rebuild failed- just lucky there. They're usually not bad. It's reasonably safe to "assume" the rear axles would be right, the application shows '06 & '07 only, and hey, they're rear axles....
The first one in the list is certainly incorrect (MZ8338A), and is used as an example of what to watch out for in the pics below.
The entire list- much shorter than it used to be:
http://stable-networks.com/ms6r/imag...RA-cvaxles.jpg
See anything amiss with this application list?
http://stable-networks.com/ms6r/imag...um/RA-fail.jpg
Here's a good application list:
http://stable-networks.com/ms6r/imag...um/RA-good.jpg
Mazdaspeed6 Front CV Axle specs compared to the N/A 2.3 CV axles:
Dimensions:
The Speed6 axles have a much larger nut, 35mm -vs- 32mm, on the splines/hub side. This is the one I've been using a 36mm socket on, by mistake apparently.
This nut size can also be referred to as M24-1.5 on the Speed6, and as M22-1.5 for the smaller NA axle.
Spline section diameter on the speed6 is 32.5mm, and is only 29mm on the NA axle.
Passenger side is also longer for the Normal 6 2.3, since there is no PTO to deal with
- top is the Speed6, bottom is normal 6 passenger side
http://stable-networks.com/ms6r/imag...pd6-vs-6_1.jpg
SleeperHatch 09-18-2012 02:10 PM
Quote:
Yes I see this thread lol. I ended up just buying a OEM axel
DashingDomin8r 12-28-2012 12:31 AM
Exedy Clutch kit doesnt fit.
lopezsr20 03-29-2013 02:17 PM
Does anyone know if the ball joint moog MDBJ4869 they offer for the speed fits?
Or the DEEZA Part # MDH201—
MazdaSpeedster 04-06-2013 07:53 PM
I ordered a cabin air filter last week for my speed 6. I received it today and it did not fit.
TiGraySpeed6 04-06-2013 08:47 PM
What's the part number for the filter which doesn't fit?
802MS3 05-22-2013 01:18 PM
Strut mount kit for the 3 -
Mevotech MS76201 does not come with the strut boot and bump stop, even though it shows both of those in the pictures.
More Information for MEVOTECH MS76201
Details
spd6demon 07-31-2013 08:15 AM
The shaft pivot seal doesn't fit, too big in diameter. I just re-used the old seal but took the spring ring (or whatever its called) out of the new seal and put it in the old one. Been about two weeks and no leaks :smile:
TiGraySpeed6 07-31-2013 08:29 AM
Can you post the part number you ordered from RA, or any other details?
Knowing RA, they have some that do fit & some that don't so any details you can provide on what didn't work would be great!
spd6demon 07-31-2013 08:50 AM
Part # 221620
There was only one shift shaft seal that came up for the 06' ms6. The seal didnt fit no matter how hard I tried. Seal is slightly too big for housing. Also the new seal wasnt as thick as OEM
Mandinca 08-01-2013 01:18 PM
Quote:
Originally Posted by spd6demon (Post 2187377)
Part # 221620
For what the OEM costs why didn't you go to Mazda ?
The radiator doesn't fit. The brackets for the fans are all wrong and one of the hose fittings on top is different. It would be nice if it did fit since RA's is $119 and the only other place I could find one was OEM at $350
I also bought a PCV valve from them and the jury is still out on its functionality.
soul.survivor 08-01-2013 01:23 PM
Fel-pro donut exhaust gasket fits but isn't thick enough to make a seal.
spd6demon 08-01-2013 06:30 PM
Quote:
My friend actually ordered it for me. Didn't think rock auto's would be different. Guessed wrong lol.
Rcimp 01-23-2014 06:53 AM
I ordered the LUK clutch kit and it fit fine, I also ordered two axles that fit fine to. I ordered two front bearings with hubs and they did not fit.
Bearing with Hub: PRECISION AUTOMOTIVE 513211 - Did not fit.
Clutch Kit: LUK 10064 - Fit
Axle: EMPI 803952 - Fit
Axle: EMPI 803957 - Fit
Clutch Slave Cyl: WAGNER SC143568 - Fit
season_of_ages 03-02-2014 01:47 AM
Radiator was mentioned. Of course, this will include the drain plug. Thread is too small to fit oem radiator
Sent from my SM-N900T using Tapatalk
madspd6 03-02-2014 02:41 AM
The one EMPI Drivers side front axle #803967 for the speed 6 fits fine too as i have it.
I also called EMPI and about 5 months ago they were working on tooling for the passanger side, guy said new tooling takes between 5-6 months to perfect.
arias valentia 09-24-2014 06:25 PM
I got the engine gasket set, 4 exhaust valves and a pcv valve from them and I havnt had any issues except a minor seaping around the valve cover that I attribute more to the some rusty (+1 missing/snapped) cover bolts.
So far I guess i was lucky :)
Anyone know about the rack and pinion boots?
maddocx240 09-29-2014 08:32 AM
Has anyone ever tried the oxygen sensors for the speed 6? I might need one and wanted to know if they are the right part.
twiztdspeed 10-29-2014 07:22 PM
Ngk 02 sensors should be ok but the dorman intake manifold runner control or ebcs has the wrong male pluge
Turbo_Steve 10-29-2014 07:34 PM
The ngk/ntk o2 sensor part number 24357 worked perfectly for my 08 speed 3.
They list part number 24354 for the speed 6. I am not sure if the connectors are different between the 2 cars but this is probably why it has a different part number. If it is pictured with the heat shield it should be the one you want.
Slick6 11-13-2014 11:25 AM
I overhauled most of the suspension on my MS6 last summer with rockauto parts. Only a few parts gave me problems.
The Beck/Arnley rear lateral links don't fit a MS6. The part number is 1016605. I'm not sure about the Mevotech or Moog lateral links, but with the Beck/Arnley ones I could not adjust rear toe at all.
The Beck/Arnley control arms fit. I've had them on my car for over a year and haven't had a problem with them. These are the part numbers:
Rear upper CA's - 1017042
Front upper CA's - 1015535 (Left) / 1015534 (Right)
Front lower rear CA's - 1015533 (Left) / 1015532 (Right)
For the Front lower front CA's, I bought Dorman #520809 which fit perfectly and have held up well.
KYB Strut mounts #SM5540 fit but after about a month they began making noise, so I would avoid these.
ibcrusn 11-20-2014 07:20 PM
I forgot to post this some time ago but the Beck/Arnley 037-6112 intake gasket fits perfectly. Their TB gasket fits 100% as well I just don't have the P/N handy.
season_of_ages 11-21-2014 10:40 AM
I read there was a TSB regarding the passenger control arm where the MS6 would pull to the right. Are these the updated control arms? After installation, do you experience any kind of pull while driving?
Slick6 11-21-2014 11:47 AM
The updated control arms are supposed to correct differences in caster between the left and right wheels. I don't think these will fix caster differences, but I went from 4 degrees of caster to about 5 degrees after installing them, FWIW. Then again, I had the front subframe lowered and installed SPC balljoints when I replaced the UCAs, so I can't say for sure if the increased caster was a result of the control arms.
I don't have any pull while driving after installing these and getting a good alignment.
myspeed90 07-22-2015 04:14 AM
throw out bearing
Bought a throw out bearing for my genwon and it was wrong. Claimed to be for the turbo engine but its definitely wrong. Ended up going to Mazda and buying. Part # N4115
dead-zone 09-01-2016 02:20 PM
WIX Cabin Air Filter fitted perfectly gen1.
ACDelco rear coil springs were about half inch longer, though no noticeable change in car height or handling. The springs hardness feels same as the stock one, if not even slightly firmer.
MEVOTECH Rear LCA also fitted fine.
cjbevington 11-27-2016 03:15 PM
I had to return an A/C compressor. The return was really easy, that place is awesome for parts (when they fit).
Lex2007 09-08-2017 08:54 PM
Do not use National # 510096 front wheel bearing for Mazdaspeed 3. It fits but the wheel speed sensor won't get the correct signal and you'll get DSC and ABS dash lights.
skyms6 09-15-2018 06:50 PM
has anyone purchased a clutch from rock auto ? if so which one do you recommend im looking to purchase one from them
thanks
Solarsurge 09-15-2018 10:49 PM
Quote:
thanks
That LUK clutch in the picture is the OEM clutch. That's a steal for $200 considering it comes with the pilot bearing, release bearing, and alignment tool.
Edit: You MUST replace the flywheel bolts if you replace the flywheel or have it cleaned up. They are one-time use only. Don't forget about those.
skyms6 09-15-2018 11:07 PM
do you think i need to replace the fly wherl ?
Solarsurge 09-15-2018 11:14 PM
Quote:
It is 100% necessary for the flywheel to have a clean, perfect mating surface for the clutch to grab. If the clutch wore down to the rivets or damaged the flywheel at all, it will have to be replaced or at least resurfaced. Fidanza is a cheap option and it's lighter, which is just a bonus. OEM Flywheel is hella expensive. If the flywheel is undamaged, clean it well with denatured alcohol. Be VERY careful to only use a TINY bit of lubricant on the splines and be careful when you re-grease the fork and release bearing. That shit's gonna spin at 6000 RPM, which will send any excess lubricant all over the place. If any lubricant at all gets into the clutch, you're gonna have a bad time.
Page generated in 0.20751 seconds with 11 queries
