 Old 08-19-2017, 01:00 PM   #1
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Default Running hot.
Just noticed this recently. Never checked my coolant temp before and it seems like I've been running hot for a long time. Sometimes it peaks to 240 degrees, highway driving is around 220. Thermostat, sensor or something else? The fan kicks on usually after I turn the car off.
Sent from my XT1565 using Tapatalk
tom10122 is offline   Reply With Quote
 Old 08-19-2017, 01:55 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Word on the street, the thermostat usually fails open.
On my 6, the fan usually comes on at about 218ish. Cruising temps are around 200. If you have a 6, the A/C will kick the other fan on.
Make sure your coolant is topped off and no air trapped anywhere. Check for blockages in front of the radiator. Maybe you have a Walmart bag in there.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
tom10122 (08-19-2017)
 Old 08-19-2017, 02:05 PM   #3
tom10122's Avatar
No blockages or anything but it seems like the wrong coolant is in the car, it's green. My understanding is that Mazda oem is yellow right? Would that do it?
 Old 08-19-2017, 02:12 PM   #4
Fstrnyou's Avatar
Mine is pinkish? It's the Asian stuff.
Different coolants don't cool different, but the wrong compounds in the coolant could adversely effect your system components.
Other rides:
History:
 Old 08-19-2017, 02:59 PM   #5
SpoolinSpeed3..757's Avatar
Posts: 48   (View Stats)
SpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of light
Mazda factory fl22 coolant is dark green in color
Sent from my SM-G930P using Tapatalk
SpoolinSpeed3..757 is offline   Reply With Quote
 Old 08-19-2017, 04:21 PM   #6
Fstrnyou's Avatar
Other rides:
History:
What are you running with? LingLaang Gen2 MS3 General Discussion 38 09-01-2015 12:13 PM
Anyone running XXR 522 on their MS6 chapy18 MazdaSpeed 3/6 - Wheels & Tires 0 04-16-2014 04:32 PM
Anyone Running This? 89T Mazdaspeed3/6 General Discussion 3 02-04-2013 10:34 AM
fan not running exentix MazdaSpeed 3 - Engine, Transmission & Driveline 2 07-13-2012 06:03 AM
Page generated in 0.26459 seconds with 22 queries
