![]() Join Date: Jan 2011
__________________ 2007 MS3 Last edited by a.finnimore; 02-02-2011 at 06:07 PM. |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 959
Groans: 59
| Not Ranked : 0 score Oh boy.
__________________ [SIGPIC][/SIGPIC] Better to remain silent and be thought a fool than to speak out and remove all doubt. -Abraham Lincoln |
| The Following 4 Users Say Thank You to kpacker51 For This Useful Post: | FreeFlyFreak (02-03-2011), Huligan (02-04-2011), lyonsroar (02-02-2011), ZipprSuitdSungod (02-03-2011) |
![]() Join Date: May 2010 Location: Omaha, NE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 318
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score In.
__________________ **Remember the good old days when wheels fit properly and people lowered their cars to improve handling?** |
| The Following User Says Thank You to lyonsroar For This Useful Post: | pinetar (02-04-2011) |
(Thread Starter) | Not Ranked : 0 score I'm stoked to have asked a dumb question to you guys! I just wanted to know the facts behind why this is a bad practice so I could further explain it to my buddy. Although the flame on is fine too!
__________________ 2007 MS3 |
![]() Join Date: Feb 2010 Location: OH & NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,558
| Not Ranked : 0 score Do you even know what the clutch does? |
| The Following User Says Thank You to spoolin00 For This Useful Post: | PunjabiPlaya (02-02-2011) |
![]() Join Date: Dec 2010 Location: Los Angeles
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,061
Groans: 209
Groaned at 92 Times in 38 Posts
__________________ ![]() // 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 // 4 Gallon E85 by Stratified My Photography - DarkSidePhotoshoot.com
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score Why would you want to? Oh, and punch your buddy in the balls. Hard.
__________________ 2009 MS3 sport MGM |
Groans: 356
also when the car is off the gears and mechanisms are still since there is no power delivered from the motor to the input shaft, clutch is not needed because separating the motor and transmission will not change the static condition of the transmission's mechanism. so to answer your question.... it makes zero difference to engage or disengage the clutch when shifting a car that is turned off , because the only reason for pushing the clutch in when the car is on is to slow down the transmission enough to be able to engage the next gear.
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE | |
| The Following 7 Users Say Thank You to rodrigo For This Useful Post: | AZSPEED3 (02-04-2011), ccruz619 (02-03-2011), Night Wolf (02-03-2011), Post pwned (02-03-2011), silverspd3 (02-03-2011), SIXual Panda (02-03-2011), thanox2 (02-03-2011) |
![]() Join Date: Mar 2010 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Technically you can change gears with no clutch when the car is running too, if you match the rpm and don't grind them! What's the point of shifting gears when the car is off, are you practicing your 2-3 shift? |
Groans: 793
| Not Ranked : 0 score Msf never ceases to provide lulz at 5:30am. That gives a whole new meaning tongue term, "bench racing". |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score It's not going to hurt your car so long as you aren't forcing the shifter in gear.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
![]() Join Date: Nov 2010 Location: Montréal, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,093
Groans: 58
__________________ Mazdaspeed3 2008.5 black mica. [SIGPIC][/SIGPIC] SRI - COBB / TIP - COBB / Accessport - COBB / RMM - TRZ / HF cat DP to come | |
| Not Ranked : 0 score |
Groans: 58
![]() Join Date: Sep 2009 Location: NE PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,832
Groans: 109
| Not Ranked : 0 score well, the only reason for doing this i would say is if you're in a dealership and want to play around with the tranny to see how it feels. One time the guy at the mazda dealership yelled at me.. i laughed and told him i drive and speed and he shut up and went back in his office. (this dealer couldn't even sell speeds haha) There is no reason the tranny would get hurt. Nothing is moving. If you break something then i'd highly suggest you don't buy the car... i mean, if a tranny gear can't slide in under no pressure... what happens when you use it with the engine placing all it's power through it?
__________________ Mk7 GTI |
![]() Join Date: Jun 2010 Location: Ottawa
Rep Power: 617 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 526
| Not Ranked : 0 score I disagree a bit here... If nothing is moving in the trans and the clutch is not pushed in, then the syncros are not able to do what they normally do which is Match Speed... Seeing how there is Zero Speed, when you force the shifter to a gear and the clutch is locked, it hits and has to be pushed left or right on the shaft. The Selected gear has to move rather than just shifting the clutch a bit Either way, it's not massive damage, but I ask, why do it in the first place...
__________________ |
| The Following User Says Thank You to Brian MP5T For This Useful Post: | Mizzle (02-03-2011) |
Groans: 793
| Not Ranked : 0 score Gears meshing properly while driving normally will cause more wear or "damage" as it may be, than shifting with the engine off and displacing the gears with a bit of force. Last edited by Tokay444; 02-03-2011 at 04:52 PM. |
![]() Join Date: Jan 2010 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 946
Groans: 53
| Not Ranked : 0 score Why do people get into arguments that they can't back up and then come on the internet to try and justify their insanity? If you can't explain why, it's more than likely you have no clue what you're talking about. If you don't know what you're talking about.... shut up.
__________________ You know.... Moose stuff |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Neutral : +1 score I have one word for all of you guys. Simplify. Why would anyone in their right mind do this? When you shut the car off and you're ready to exit, a lot of people like to leave the car in gear (usually first or reverse) while parked. It's the equivalent of putting an automatic in park, in a sense. I do this all the time. If I forget to put it in gear right after I shut it off and I've already exited the car, I'll just push the shifter into first without getting back in the car to push the clutch in. There is no resistance. It glides right in, just like my cock into hot MILF pussy. Ya know, a lot of you guys are really bright, but you tend to over think things a bit. |
| The Following 2 Users Say Thank You to Dash08 For This Useful Post: | Cataphract_40 (02-03-2011), emag remrofni (02-03-2011) |
(Thread Starter) | Not Ranked : 0 score I would never do this simply no reason to, but a buddy of mine always sits in his car and shifts gears without engaging the clutch. (looks like an idiot) and I wanted to see if there was any mechanical no-no for doing this. Thanks for all the input.
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
| Not Ranked : 0 score I give you thanks for those two sentences
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
| The Following User Says Thank You to Cataphract_40 For This Useful Post: | Dash08 (02-03-2011) |
![]() Join Date: Nov 2010 Location: NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 530
Groans: 68
| Not Ranked : 0 score I would hope he's using a microfiber cloth so as not to scratch the surface to wipe all the spittle off the windshield from making the engine noises while sitting there shifting. Oh, and don't let that idiot into YOUR car.
__________________ [SIGPIC][/SIGPIC] 2011 MS3. Tech Package. Ventureshield Clear Bra. Rally Armor urethane mud flaps. WeatherTech FloorLiners. Valentine 1. DashDaq XL. Mods to follow after the enhanced PIDs are released. |
| The Following 2 Users Say Thank You to ZipprSuitdSungod For This Useful Post: | ClutchEngaged (02-03-2011), emag remrofni (02-03-2011) |
Groans: 53
| Not Ranked : 0 score My guess is the guy got into the OPs car and moved the shifter around when the car was off without pushing in the clutch. The OP most likely freaked out because someone was molesting the only thing he's ever had that was worth owning. When the OPs friend asks him why he just had a massive coronary for nothing, the OP proceeded to tell his friend a magical tail of unicorns and wrecked transmission with out any idea what he was talking about. Then OP comes onto MSF to hope that someone could justify his fairy tail so that his friend wouldn't not call him out on his douche-baggery.
__________________ You know.... Moose stuff Last edited by amoosenamedhank; 02-03-2011 at 05:14 PM. |
| The Following 5 Users Say Thank You to amoosenamedhank For This Useful Post: | ClutchEngaged (02-03-2011), I<3Groceries (12-06-2012), Speedaway (02-03-2011), Tokay444 (02-03-2011), xfeejayx (02-04-2011) |
![]() | | #24 | ![]() |
Groans: 793
| Not Ranked : 0 score Hella thanks^^^ |
![]() | | #25 | ![]() |
Rep Power: 223 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38
| Not Ranked : 0 score It would feel so unnatural to do that without depressing the clutch.
__________________ Car Mods: Walmart SRI, Home Depot TIP, Dollar General Racepipe, Local Hardware Store Shifter Bushings, Junkyard Rear Motor Mounts, Short Shifter Plate Kit coming from Fingerhut. Driver mod: Asian quickness! |
![]() | | #26 | ![]() |
Groans: 793
| Not Ranked : 0 score I had a car blow a clutch slave cylinder. Drove around for a week with no clutch at all. Had to shut my car off at red lights and start it with my foot on the gas in first gear. Never had any tranny problems. |
![]() | | #27 | ![]() |
![]() Join Date: Dec 2010 Location: Atlanta, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
Thanks, chriscarron! | |
![]() | | #28 | ![]() |
| Not Ranked : 0 score [QUOTE=dkapetansky;716957]After reading this, I got real curious, so I ran outside, hopped into my '07 MS3, and started checking this out. Basically, chriscarron is right. I was able to upshift in any gear, without even touching the clutch, and with no weird noises from the drivetrain. Downshifting was a different story, though; I was never able to get into a lower gear without using the clutch. So maybe now I'll save a smidgeon of clutch friction material for posterity. Glad it worked for you, sometimes I do it for fun but not that much, after all, there's no point lol On another note, I was at the dealer earlier test driving a new speed3, and the salesman started the car, shook the stick left to right like 10 times, I guess to check if it was in neutral, then put it in first drove it out of the parking lot, then put it back to neutral and did that shit again....WTF is with people who shake the stick back and forth, is it really to make sure it's in neutral or is it some kinda macho move " oh look I can drive stick babyyy"...seriously drives me nuts, if some of you guys do this, why??? |
![]() | | #29 | ![]() |
Groans: 793
| Not Ranked : 0 score It's called power shifting and it nothing new. We all knew it works. It's worked for well over 50 years. And the only reason YOU couldn't downshift, was because YOU, weren't doing it correctly. |
![]() | | #30 | ![]() |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score I have never shifted my car ever. This sucks because i can only go places which are down hill from my current location. I think its worth it though. My clutch gets no wear at all!
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
| The Following User Says Thank You to SgtP For This Useful Post: | Tokay444 (02-04-2011) |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2008 Location: Monterrey / San Antonio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score this is such a mazdas247 question
__________________ yes it's modded. |
![]() | | #32 | ![]() |
Groans: 53
| Not Ranked : 0 score [quote=chriscarron;717386]
If you see people doing it now... I would say your guestimation is pretty on... either isn't a very experience driver or thinks it looks cool cuz he saw it on some movie.
__________________ You know.... Moose stuff | |
![]() | | #33 | ![]() |
![]() Join Date: Nov 2010 Location: Lake Carmel, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 773
...go figure. My uncle would actually do that while in the tractor out in the field.But Dash08 pretty much got it. That's the only reason people would even care to put the car in gear after it's been turned off. | |
![]() | | #34 | ![]() |
Groans: 58
![]() | | #35 | ![]() |
| Not Ranked : 0 score Fucking Stick Gigglers...
| The Following User Says Thank You to Brian MP5T For This Useful Post: | Speedaway (02-04-2011) |
![]() | | #36 | ![]() |
Groans: 209
| Not Ranked : 0 score Stick jiggling is a terrible habit. I admit that I tend to do it subconciously sometimes. No homo.
![]() | | #37 | ![]() |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
I do pull it to the left to make sure it's in neutral before i let off the clutch when i'm parking. but one pull to the left is all you need. any more than three and your playing with yourself | |
![]() | | #38 | ![]() |
Groans: 106
| Not Ranked : 0 score I jiggle that shit all day. Its to play with something big once in a while...
![]() | | #39 | ![]() |
![]() Join Date: Oct 2012 Location: Tampa bay florida.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groaned at 68 Times in 30 Posts
I wiggle the shifter left and right also. It's habit. Back in England I didn't have to depress clutch to start the car so I fit were in gear it would lunge forward or back. The tranny is a noisy beast on the ms3 for sure. Just today turned car off in garage and pressed down on the clutch and changed 1 to 2 to 3 man the noise I could hear! Not for the faint hearted.
__________________ [SIGPIC][/SIGPIC] British Expat living in the land of the "3" 2013 W/tech | |
![]() | | #40 | ![]() |
![]() Join Date: Dec 2011 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 966
Groans: 127
Groaned at 24 Times in 17 Posts
| Not Ranked : 0 score thread from 2011, fag.
__________________ 2007 BlackMicaMPS6| MDM RMM| Forge V2 BPV|Cobb SRI| M2 Downpipe|Denso ITV22's|Cobb AP| Cobb TiP|AutoTech Internals|CP-E TMIC| MDM SSP| SPC Ball joints |Bilstein Shocks| RPM Sport springs| XCarLink MP3 Adapter| 30% window tint| Powerslot rotors| Hawk HPS Pads| Sharkfin Antenna FreekTuned ![]() |
| The Following 7 Users Say Thank You to blackmicamps6 For This Useful Post: | Brian MP5T (12-08-2012), bryansawiseone (12-06-2012), dantes5823 (12-06-2012), Easter Bunny (12-06-2012), smoogs12 (12-06-2012), SWAY (12-06-2012), uncorked11 (12-06-2012) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/shifting-gears-no-clutch-when-car-off-71362/ | ||||
| Is it bad to switch gears in my car when it is turned off without the clutch depressed? : MechanicAdvice | This thread | Refback | 12-11-2014 09:08 AM | |
| Clutch/Shifting Problems | babah5 | 2010 MS3 - Engine, Transmission & Driveline | 20 | 07-24-2010 04:46 PM |
| Problem in 5 and 6th gears | Zak | MazdaSpeed 3/6 - ECU Computer Tuning | 20 | 12-18-2009 05:15 PM |
| Celebrity Drive: Tennis legend Martina Navratilova is a total car nut, likes shifting the gears herself | Haltech | Automotive News | 0 | 05-02-2008 06:50 AM |
| S-Tronic Test Run: Shifting the gears of Audi's new seven-speed twin-clutch transmission | Haltech | Automotive News | 0 | 03-30-2008 11:11 PM |
