 Old 04-26-2019, 04:34 PM   #1
njdurkin's Avatar
Posts: 68   (View Stats)
njdurkin is an unknown quantity at this point
Default Solenoid in ignition switch - how to control?
Okay, the keyless start system with the fob. When you push on the ignition key switch (without a key) and you have the fob nearby, it activates a solenoid inside the ignition switch which allows you to turn it and start the car. My fob is going bad. Basically useless at this point. Not paying any amount of money for a new one. I want to spoof the signal the fob is sending to the ignition switch to allow you to turn the key switch without the key and start the car. Is it inside the ignition assembly itself? Has anyone messed with this?
I also noticed that there is an immobilizer around the keyswitch when you take the cover off. Is this for a chipped key? If so, it still starts without the key so it must get bypassed when you use the fob.
njdurkin is offline   Reply With Quote
 Old 04-26-2019, 08:49 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Just use the key.
 Old 04-27-2019, 09:07 PM   #3
njdurkin's Avatar
You're so smart. I never thought of that....
 Old 04-27-2019, 11:19 PM   #4
Groans: 60
If you can turn the key cylinder and start the car with a bad fob, and without the key. So could anyone else...
When you figure out the solution to your problem, be sure to let the rest of us know.
 Old 05-07-2019, 01:31 PM   #5
njdurkin's Avatar
Goal: remote start from phone, no key, no fob
I have an old honda civic that I already have set up this way. That is a much simpler ignition system. Only a couple of things to wire up
Problem: this car has a lot more involved ignition system with an immobilizer which I don't know how to get around, that's why I wanted to utilize the smart key system because it seems to bypass the immobilizer step somehow
 Old 05-07-2019, 09:03 PM   #6
Groans: 60
Clone the key info with an flcan or ADS-ALCA to bypass immobilizer.
However the actual column lock mechanism is controlled via serial data from the keyless module. It looks like you would need to physically remove the ignition switch/column lock assembly from the steering column in order to remove the column lock.
Boost Control Solenoid????? coasttime 2010 MS3 - ECU Computer Tuning 14 05-19-2015 05:29 PM
How do I get the boost control solenoid off Dboyle23 Gen2 MS3 General Discussion 4 01-01-2014 03:14 PM
D.O flow control solenoid SLOWHATCH 2010 MS3 - Fuel, Nitrous & Water Injection 35 11-04-2011 10:19 AM
Page generated in 0.25243 seconds with 22 queries
