 Old 09-16-2019, 10:17 AM   #1
Roman-dude's Avatar
Posts: 56   (View Stats)
Roman-dude will become famous soon enoughRoman-dude will become famous soon enough
Default source for rubber 32mm bushings for rear sway bar or other suggestions
I have the older 32mm corksport rear sway bar that's been eating thru poly bushings like there's no tomorrow - replacing the last 2 sets after a few months. It appears that there may be a bit of rust on the bar so it's wearing those out quicker. Anyway, it was suggested to go with the rubber ones instead but I am having trouble locating rubber in 32mm size. Moog straight up said they don't make those in that size and doubt anyone else does. Any leads and/or suggestions (short of polishing away the rust off the bar with sandpaper)?
thanks!
Roman-dude is offline   Reply With Quote
 Old 09-17-2019, 08:03 AM   #2
shamie's Avatar
Posts: 952   (View Stats)
Just fix the problem and stop trowing bushings at it. Sand the rust, hit it with Krylon, and install new lubed polys.
The Following 2 Users Say Thank You to shamie For This Useful Post:
Db09ms3 (09-17-2019), MSMS3 (09-18-2019)
Must I drop the rear diff to do sway bar bushings? BoostedRide MazdaSpeed 3/6 - Suspension & Brakes 1 11-20-2015 07:16 PM
Bushings for hotkiss rear sway bar seige123 Revolution Performance Motorsports 5 07-21-2014 11:29 PM
Page generated in 0.22177 seconds with 21 queries
