![]() Join Date: Mar 2015 Location: Princeton, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 48
Groaned at 7 Times in 3 Posts
(Thread Starter) | Not Ranked : 0 score Anyone know where I can find another one? Doesn't have to be oem… I can't seem to find one on rockauto, oem mazda searches, or forums.
__________________ 2007 Mazdaspeed 3 |
![]() Join Date: Apr 2016 Location: Richmond, VA
| Not Ranked : 0 score It's a bolt, and an insignificant one at that. Just find one that fits the hole lol But if you want that OEM Mazda fitment: https://www.tascaparts.com/vintage-m...1a?parent=1118 Last edited by Solarsurge; 09-18-2018 at 11:01 PM. Reason: Fixed link for genuine OEM part from Tasca |
| The Following User Says Thank You to Solarsurge For This Useful Post: | furinax (09-21-2018) |
![]() Join Date: Jun 2009
About $15 from a dealer, if you need the bolt only. You can order online from any dealer. The one for our cars has an "A" at the end of the part number because our wheels are wider, and the bolt needs to be longer. Or get a metric bolt gauge and measure the bolt hole size and get some appropriate "M" bolts in the measured diameter long enough to reach. Third image is a metric bolt and nut gauge. Lots of different brands. Widely available. If you are going to work on a car with metric fasteners, you need one of these. Buy once and use every time you have the question. About $10.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 09-20-2018 at 01:39 PM. | |
| The Following User Says Thank You to MSMS3 For This Useful Post: | furinax (09-21-2018) |
(Thread Starter) | Not Ranked : 0 score Thanks for your help, but I really did some searches on google, etc to no avail. I don't consider myself an expert at searching but I figured if I do "spare tire bolt" or "spare" I would at least get the part. But the closest I got on my own search was this: https://www.realmazdaparts.com/oem-p...w0LWdhcw%3D%3D Which was clearly not the right part. The fact that the MS3 has a different bolt than the Mazda3 makes me glad I asked here. I'll look into getting both parts.
| The Following User Says Thank You to furinax For This Useful Post: | MSMS3 (09-24-2018) |
