  • 1 Post By 2009ms3
 Old 09-01-2015, 09:48 PM   #1
2009ms3's Avatar
Posts: 36   (View Stats)
2009ms3 has a spectacular aura about2009ms3 has a spectacular aura about2009ms3 has a spectacular aura about
Default Starting Issue, dies on 1st crank
First off thanks in advance for any advice.
My 2009 speed3 from a cold start will crank once, then just die. All power shuts off and it wont crank anymore, like the battery died. But when I reset the ignition and try again it will start up, sometimes a bit rough but it will. I have tried letting the car sit for a few seconds with the ignition in the on position to let the fuel pumps run and build pressure. It will still do the same thing on first start up. I don't have an AP to check pressures but I don't think its fuel related since it won't continue to crank.
Any ideas?
2009ms3 is offline   Reply With Quote
2010 speed 3 intermediate longer crank starting issue paintballchrs12 MazdaSpeed 3 - Engine, Transmission & Driveline 1 04-01-2014 03:13 PM
Starting issue watdog MazdaSpeed 3/6 - Troubleshoot/Diagnostics 42 03-09-2014 08:30 PM
Mazda3 Crank vs Speed3 Crank relenger MazdaSpeed 3 - Engine, Transmission & Driveline 36 12-19-2010 08:22 AM
Page generated in 0.44019 seconds with 28 queries
