  • 1 Post By
  • 1 Post By MSMS3
 Old 10-11-2017, 12:47 PM   #1
Posts: 2,826   (View Stats)
If you want power and smooth, seamless, performance with correct AFR's and are not boosting above 20 psi, the correct and best BPV is the OEM model. It is quite sophisticated and simply works.
Running in full recirc mode is best for this engine, as farting already metered air to atmosphere screws up the AFRs during and right after the shift.
If you want arm pit fart sounds, then you are, with respect, a ricer and not really interested in performance. Going after that sound at the expense of performance is grade school school yard antics, IMHO, just to impress juvenile friends.
There are no performance gains by using an aftermarket BPV unless your stock BPV is leaking. That is not likely until you get heavily modded and are safely boosting above 20 psi. Yes, it's that good. In fact, a few years back one leading car magazine compared the stock Mazdaspeed BPV with the most popular aftermarket BPV/BOV and found that it held boost longer and higher.
FWIW, if you have a good aftermarket intake, you should be able to hear the BPV release at a throttle lift during shifts. That is incidental and not intentional.
drive_sideways likes this.
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
Throttle noise/ engine noise under28world 2010 MS3 - Engine, Transmission & Driveline 9 05-04-2015 06:25 PM
bearing noise vs wheel noise? drag0nfire Mazdaspeed3/6 General Discussion 14 06-20-2012 07:32 PM
shart (shaft) play noise on stock turbo ?? jracer MazdaSpeed 3/6 - Turbo Induction 18 03-29-2010 05:20 PM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 05:00 PM
Page generated in 0.22920 seconds with 21 queries
